Old 01-31-2018, 07:24 AM
posulli88's Avatar
posulli88 posulli88 is offline
Replace lower steering column bearing w/o removing column?
My engine is out right now so I have great access to the lower steering column bearing. It’s bad.. at the bearing I can move the shaft side to side quite a bit. Everything I have read in the TSM and on the forums says to replace the bearing I have to completly remove and open up the steering column. Is there anyway to remove and replace that lower bearing without doing that since I have the engine out?
It’s a non tilt column... thanks.
Old 01-31-2018, 11:30 AM
8man's Avatar
8man 8man is offline
Check the diagram, but if I remember you remove a spring clip that goes around the column at the bottom end and then you can get to the parts to remove and replace. With the engine out you just might do it.
Old 02-03-2018, 06:41 AM
fsj454 fsj454 is offline
Long time member
Lower Steering Shaft
You can but have to remove lower steering shaft. Remove the 2 bolts from lower shaft and remove bolts from keyed shaft top and bottom bolts must be removed to move shaft all the way down so you can pop top of shaft off to remove and replace bearing.It is a bit tricky to do but I did mine that way..WD40 ON SPLINES When you put shaft back on splines must line up with key for bolt to go thru .You mite have to shock with big hammer to remove.
1982 cherokee nt. 454. nv4500 .205. dana 60 f+r. twin stick.hydroboost.hydrolic clutch.rock ram.traction bar.warn 12000 winch.4 wheel disc.flip kit.soa.high steer.cross over steer.4.56 detroit locker.35 spline rear alloy axles. 37s .1990 grand wagoneer aka trusty rusty
Steering column problem engine bay side Phaydon General FSJ Tech 6 04-04-2012 02:33 PM
Steering column issues CJ5 General FSJ Tech 0 10-11-2011 10:17 AM
Steering colum swap question derf General FSJ Tech 15 02-04-2010 09:01 AM
Steering column bearings []V[]AXX General FSJ Tech 11 01-17-2010 01:22 AM
Steering column question M1Garandfan General FSJ Tech 7 08-19-2004 11:03 AM
