  #561
Old 04-23-2019, 10:43 PM
bkilby's Avatar
bkilby bkilby is offline
You don't like the idea of a storage tray in place of the speaker? Something about 2" deep?
Old 04-24-2019, 03:43 PM
Coming along very nicely.
1994 Caprice wagon
Old 04-24-2019, 09:32 PM
toddthewelder's Avatar
toddthewelder toddthewelder is offline
I love the idea of it, but being a TJ owner I know that having a storage tray on the dash is a good way to get your stuff in the passenger floorboard, or even out the window. Just my thoughts on the subject, whatever you do is going to be cool though.
80 cj 5
87 GW
Another 87 GW
88 GW
99 Wrangler
07 Dodge 3500
67 Chevy SWB
2 furry shop bosses (Ash & Duke(RIP 2/13/16))
Old 04-26-2019, 08:02 AM
bkilby's Avatar
Thanks babywag!
Todd, I know what you mean about the TJ tray. It was pretty useless most of the time. Too shallow really. I'm thinking a deeper box would keep stuff from flying around. I dunno. I hate to go through the work of fililng in that speaker hole without putting something useful there.
Old 04-26-2019, 10:16 AM
Thanks babywag!
Maybe make a simple lid, wouldn't be hard...
1994 Caprice wagon
Old 04-26-2019, 12:20 PM
bkilby's Avatar
True. I'd like to find a pre-made steel box and just weld it in. Lol. I wonder if Tuffy has something...
Old 04-26-2019, 01:05 PM
Your dash work already looks so awesome with the stereo panels and that bezel so regardless of what you choose to do with the speaker hole, its gonna look good.
I don't like putting things on my dash because I have had too many pieces end up in the defrost vents over the years. Or baked/melted in the hot sun. They also bounce around and reflect off the inside of the windshield sometimes and that can get annoying, too. I only had one car that ever had a dash where I could put stuff on it (my Geo) so maybe its just my knuckleheadedness but that's my 2 cents. Like I said, I think whatever you do, its going to look awesome.
Old 05-18-2019, 03:11 PM
bkilby's Avatar
Finally getting back on the dash again. Had to take a break to get the purple car ready for a car show and road trip. It was a success.
I ended up taking the instrument bezel to a guy to have him TIG weld the face to help hide my welding imperfections. Lol. It looks brutal in this pic but it looks a lot nicer after bead blasting it. It shows a lot of heat but it didn't warp. I forgot to take an after pic.
Old 05-18-2019, 03:26 PM
bkilby's Avatar
So getting back to that ugly speaker hole..... I've decided to cut out the speaker hole and replace it with.....another speaker hole. I couldn't find another speaker with the same bolt pattern otherwise I would have just cut out the two sunken areas and replaced them. But since that didn't happen, that left door open to put in whatever I wanted. I ended up buying a 5x7 dual voice coil speaker. This one is "ultra thin" as I needed clearance to the top of the head unit. This is a Retrosound R-57N.
The plan was to cut a custom speaker grill and graft it into the dash. After a few different designs and test samples, I ended up with this.
I had to keep the metal bars a bit thicker than I wanted as my Plasma cutter isn't built to cut thin material. All it does is burn and melt smaller, more detailed cuts. I had the machine using the smallest (20 amp) tip and turned as low as it would go (20 amps) and it still burned stuff. But it can cut 1.5" if I ever need it too.
Before.....
After....
I still have some clean up to do, but it's not a big deal. Also, I should have marked the screw holes on the back of the grill before welding on. I didn't, thinking the curve of the dash would throw the holes off, but I wish I would have done it anyhow. The plan is to try and weld screw "studs" in place instead of drilling holes. I want to keep the dash smooth on top. That'll be next week.
What's a SUPER Chief - OLD TOPIC MESS UP...REPLY HERE! testuser General FSJ Tech 10 12-06-2015 11:10 AM
Difference between chief and chief "s"? rentalrider General FSJ Discussion 2 04-22-2011 03:33 PM
bought a Chief - going to restore it. what color? sportsidedan General FSJ Discussion 27 10-27-2008 03:30 PM
1977 Cherokee Chief - Lea Adams Dome Cherokees 0 08-21-2005 11:45 AM
Mission: Restore 1977 Chief Boogie77 General FSJ Tech 1 02-13-2003 08:30 AM
