Closed Thread
Old 03-01-2011, 02:08 PM
dusty's Avatar
dusty dusty is offline
Diesel Swap FAQ - Diesel swappers Start here -
Alot of the same questions get posted all too often about Diesel swaps So here’s a Tech page for those Newbie or wanna be diesel FSJ conversion guys: If you have suggestions or additions please email me or jeepinpete and we will get it added.
Consider what you type in your title use a 4- letter name for your engine ie.
"Chevy 6.2" vs 6.2 or GM 6.2
"4bta" or "cummins 4bta" vs 4bt
"Ford diesel" "Ford 7.3 Diesel" vs 7.3 or 6.9
Diesel drivetrain options, debates about various engine choices:
A Diesel debate #1
A Diesel debate #2
Diesel opinions, Poll and Swap discussion Ford 7.3L and 6.9L discussion and debate
Pros and cons of different suggestions
Yes your Frame will handle it but…
AMC 401 supporter
GO UM Montana Griz
Old 03-03-2011, 11:37 AM
dusty's Avatar
4BTA and 4BT swaps:
4BTA and 4BT swaps:
http://www.ifsja.org/forums/vb/showthread.php?t=66998
---- tndonors J10 with 4bta, bread truck intercooler and NV4500, pictures of install using cummins accessory mounts.
http://www.ifsja.org/forums/vb/showthread.php?t=81359
---- Dusty's Cherokee Chief with 4bta 91-93 dodge intercooler and dodge nv4500 pictures of motor mounts and Dodge accessories & AC
http://www.ifsja.org/forums/vb/showthread.php?t=54096
----wagonman83’s swap stock 4bt
http://www.ifsja.org/forums/vb/showthread.php?t=81595
---- Coloradofireman
http://www.ifsja.org/forums/vb/showthread.php?t=101438---- more pictures from Coloradofireman
http://www.ifsja.org/forums/vb/showthread.php?t=69246
---- MCinfantry’s WC swap, stock 4bt
http://www.ifsja.org/forums/vb/showthread.php?t=103844 ---- 74 J20 zmjeeps 4bta w/ good fitting intercooler
http://www.ifsja.org/forums/vb/showthread.php?t=127496 --------- Willysdrivers 4bta into wagoneer using dodge 727 transmission and 229 t-case. low mount turbo and stock cummins air to water aftercooler 120hp 4bta
http://www.ifsja.org/forums/vb/showthread.php?t=54096 ---- Misc 4bt discussion some pictures and links
AMC 401 supporter
GO UM Montana Griz
Old 03-03-2011, 11:53 AM
dusty's Avatar
GM / Chevy 6.2 and 6.5 Diesel swaps
GM diesel swaps:
http://www.ifsja.org/forums/vb/showthread.php?t=14988 6.2/6.5 Diesel owners
http://www.ifsja.org/forums/vb/showthread.php?t=18718 --- The Pig smith J20 with a 6.2
http://www.ifsja.org/forums/vb/showthread.php?t=22615 ---- OhioJ20 " My 6.2 GW"
http://www.ifsja.org/forums/vb/showthread.php?t=57990 - some pictures of installs and discussion about the trials and tribulations of a gm swap
http://www.ifsja.org/forums/vb/showthread.php?t=13952 --- Pig Smith lays out his 6.2 game plan for debate
http://www.ifsja.org/forums/vb/showthread.php?t=78632 --- fsjeeper's project wagoneer 6.2L diesel conversion, some discussion 6bt and 4bt.
http://www.ifsja.org/forums/vb/showthread.php?t=10233 --- Starts out about cummins or ford 6.9 IDI or 7.3 IDI decends into details about 6.2/6.5 conversion
http://www.ifsja.org/forums/vb/showthread.php?t=14988 --- GM diesel motor mounts, adapters etc and links to conversion basics
http://www.ifsja.org/forums/vb/showthread.php?t=96969 --- 6.2 wiring harness info & Diagrams
http://www.ifsja.org/forums/vb/showthread.php?t=20734 --- 6.2 in a M715
http://www.ifsja.org/forums/vb/showthread.php?t=82155 --- Diesel Wagoneer in the works
http://www.4btswaps.com/forum/showthread.php?t=1278 --- Colorado jeep guy 6.2 swap in 1988 Wagoneer
http://www.ifsja.org/forums/vb/showthread.php?t=98972 --- SJdiesel’s update 6.2 performance and 700R4. Good details
AMC 401 supporter
GO UM Montana Griz
Old 03-03-2011, 11:54 AM
dusty's Avatar
6bta / 6bt 5.9L & Dodge Cummins swaps
6BT and 6bta Swaps:
http://www.ifsja.org/forums/vb/showthread.php?t=90702 ---- 6BT's are a tight fit, Dodge frame jeep body
http://www.ifsja.org/forums/vb/showthread.php?p=1105743 - FSJ frame strength discussion with 6bt install and reliability links etc.
http://www.ifsja.org/forums/vb/showthread.php?t=120980 ---- TNdonnor is at it again 6BT gladiator with some nice hop ups, twin turbos etc in the planning and build stages.
http://www.ifsja.org/forums/vb/showthread.php?t=59769 ---- Willysdriver using a dodge 6bt 727 transmission, early dodge intercooler and 3.31 axles
AMC 401 supporter
GO UM Montana Griz
Old 03-03-2011, 12:03 PM
dusty's Avatar
Perkins, CAT, Isuzu, Nissan, Mercedes and Other Diesel Swaps
Other diesel Swaps:
http://www.ifsja.org/forums/vb/showthread.php?t=127088 ----- 88 Grand Wag OM617 Mercedes Diesel Build
http://www.ifsja.org/forums/vb/showthread.php?t=44781 ------ Cadillac diesel discussion in archives forum
http://www.ifsja.org/forums/vb/showthread.php?t=44514 ------ Old archived forum debate on a wagoneer conversion
AMC 401 supporter
GO UM Montana Griz
Old 03-03-2011, 12:04 PM
dusty's Avatar
Smog legalities and Diesel Swap Emissions issues / Options
CA legality and Diesel swap issues/options:
http://www.ifsja.org/forums/vb/showthread.php?t=80533&highlight ---- How to do a CA SMOG legal diesel swap and see a ref
other diesel swap issue threads
http://www.ifsja.org/forums/vb/showthread.php?t=59815 http://www.ifsja.org/forums/vb/showthread.php?t=110895
http://www.ifsja.org/forums/vb/showthread.php?t=113418
AMC 401 supporter
GO UM Montana Griz
Old 03-03-2011, 12:05 PM
dusty's Avatar
Technical Resources
Technical Resources for diesels in FSJ's
Intercooler into a FSJ options:
http://www.ifsja.org/forums/vb/showthread.php?t=107674
http://www.ifsja.org/forums/vb/showthread.php?t=163331
Diesel fuel tank options:
http://www.ifsja.org/forums/vb/showthread.php?t=96628 - the fill necks on jeeps are too small to fill up with diesel. heres an answer
Where to Find 4bta’s:
http://www.ifsja.org/forums/vb/showthread.php?t=110827
Other sources:
4BT Transmission choices http://www.4btswaps.com/forum/showthread.php?t=5491
Common 4BT questions http://www.4btswaps.com/forum/showthread.php?t=32
AMC 401 supporter
GO UM Montana Griz
Closed Thread
And you guys hate a SBC under the hood...(Isuzu Diesel Swap) JeepinPete Diesel Swaps 112 12-20-2010 03:24 PM
Diesel Swap Regulations - long post! budojeepr Diesel Swaps 57 02-04-2010 08:26 PM
Diesel Transfercase Swap Questions The PIG Smith General FSJ Discussion 9 04-14-2008 08:10 PM
Diesel swap and Taxifornia??? Louiseven Diesel Swaps 10 01-30-2008 08:10 PM
