Old 04-17-2010, 01:55 PM
jeeper54's Avatar
jeeper54 jeeper54 is offline
Change Wag Column?
Anyone change out a steering column on a later model Wagoneer? If so, how hard? Since the turn signal cam and horn button is broke and now apparently ground out to keep horn on and there is no power to the gear indicator light I was thinking of changeing it. Found one cheap enough. Manual shows how but as of late I don't believe my manual anymore. Thoughts? TIA.
Old 04-17-2010, 07:52 PM
jeeper54's Avatar
Never mind! Found the short ( busted up turn signal cam and grounding because of the broken spring). Still no auto cancel on left turn signal and no power to indicator light. I'll keep trying. It's a Jeep thing after all.
Need FSJ GW Steering Column Or HELP! JeepHammer General FSJ Tech 8 12-12-2007 08:00 PM
Advanced Steering column tech - wiring Sitting Bull General FSJ Tech 12 05-04-2006 04:40 PM
Steering column problems / steering shaft does not match new column Chrome General FSJ Tech 3 03-11-2006 09:33 AM
Tilt Column Swap BillyBob535 General FSJ Tech 13 03-17-2004 11:01 AM
