Old 09-02-2011, 12:08 AM
Mikeswagon's Avatar
Mikeswagon Mikeswagon is offline
Can a balljoint be hammered out?
Hello,
i am trying to get an old balljoint out, but that splitring won´t move a bit. I read that pdf that goes around here, but i don´t quite get it...I already broke that spanner tool, it lost a tooth and rendered useless.
Comparing with the new balljoint i get the impression that a large hammer used on the balljoint shaft should get it loose, but it just won´t come out.
Any ideas?
89 Grand Wagoneer, work in progress
360, Edelbrock 1400, Performer Cam/Lifter/Manifold, Carter 4594 el. fuel pump, Skip White HEI
Old 09-02-2011, 03:14 AM
jeeping1974's Avatar
Install one of the nuts onto one of the ball joints and hammer on the knuckle where the arrow is pointing. That should get the knuckle off the axle. As far as getting the ball joints out, a ball joint press is the easiest and best way of doing it.
03 GMC 2500HD - DD/toy hauler
06 Street Glide - Cruiser
Old 09-02-2011, 05:28 AM
grand_wag_85's Avatar
Murphy's Law Poster Child
A pickle fork will help too.
'65 J2000
Old 09-02-2011, 06:16 AM
Crazy_Jeepman's Avatar
Sloppy Shifter
You will never get the split threaded insert out without the balljoint removed.
Where the arrows are you want to hit HARD with a BIG hammer, first use a penetrating oil around Both ball joint studs. I have the top Balljoint boss marked, but you want to focus on the bottom one, hit the top in 3 or four areas first, then work on the bottom one, turn the knuckle to get as much room as you need. If you tap it or hit it like its going to break or use a small hammer you will beat it to death, bigger is better in this case
Old 09-02-2011, 11:01 AM
rreed's Avatar
rreed rreed is offline
Yep, Harbor Fright has a really good ball joint press kit for cheap! And yes you'll want to knock the knuckle off first. From there put some pretty good pressure on the joint w/ the press you picked up, then wail on it w/ a BFH a few times in the areas depicted above, you'll see it start to budge. Tighten press, repeat. It'll soon fall out.
Did the ones on my buddy's Dodge Ram one day, they were rusted in SOLID and this method worked great.
47 Willys
75 CJ-5
81 Scrambler
96 ZJ
Old 09-02-2011, 11:06 AM
derf's Avatar
derf derf is offline
360 AMC
The advice given to me when I was doing it was to just hit it harder with a bigger hammer. Getting them out is quite a workout. But it can be done.
Try out my gear ratio calculator
Old 09-02-2011, 11:33 AM
Mikeswagon's Avatar
Hitting it harder feels like breaking the whole thing...ok, i´ll give it a try. Thanks for helping
Old 09-02-2011, 11:46 AM
Chevelleguy's Avatar
You will need at least a 48oz. hammer, too.
Old 09-02-2011, 02:32 PM
itselliot's Avatar
balljoint
Guten Tag !
A good HARD smack on the joint top (should) do the trick, as everyone has already said. Along with that, some added pressure from a pickle fork will help
http://www.northerntool.com/shop/too...1756 729&mt=b
If that fails, some heat on the knuckle to expand the joint a little and repeat the above instructions while the outside is still hot.
Also,put a wet rag on the area below the knuckle to shrink it just before smacking it .
Veil Gluk!
hpschrot@hotmail.com
616 four 03 44 0 five
Old 09-02-2011, 09:13 PM
Stupified's Avatar
Stupified Stupified is offline
Big hammer means 5 - 10 pounds ! Get a sledgehammer and cut the handle short. Hit the spindle on the side of where the joint is a few good times before you try to drive it out.
73 Wagoneer 360 400/20 D40/D30 3.31
285/70R17 DuraGrapplers
post flipped rear, rough country 6110 chevy front AAL
Camo green Zombie Response Vehicle
Old 09-02-2011, 10:18 PM
Rich88's Avatar
Rich88 Rich88 is offline
X2. A pickle fork IS the proper tool. It applies much more force to separate things than beating directly on it. The one and only time I did this, I beat on it for an hour before giving up and getting a pickle tool. On the 3rd whack it separated nicely.
Old 09-03-2011, 09:48 AM
Mikeswagon's Avatar
always a question of the right tool....
done in a minute with the proper tool :-)
Old 09-03-2011, 02:00 PM
Kuraki Kuraki is offline
When I changed the joints on my F250, 3 came lose with a hammer following the method described here. One would not come loose, no matter what, I could not hit it hard enough to budge, and I'm a pretty big boy. Ended up being enough space between the knuckle ears for me to get an oxy torch in between them and cut the ball joint in half. That let me get the knuckle off and use a ball joint press to squeeze the remaining pieces out.
When that top, tapered half came out it sounded like a .22 LR and shot across the floor almost as fast
1980 Chief - Sold back to PO
1988 Wagoneer - 360, HEI, Electric fan, hydroboost, 727, NP229, WT D44/AMC20, custom 28 gallon tank, 33s In process: TBI SBC swap.
Old 09-03-2011, 03:17 PM
mtn goat mtn goat is offline
ROTFLMFAO @ Mikeswagon
\'82 Cherokee WIDE TRACK<br />258/T176/NP208/D44/20 Rack of Tad, BIG Orange fender, funny blue hood!<br />I must go and tend to my molecules, they need me to grow big and strong...Polymer Power!!!!
piston hammered out?? what do i do next? westcoastflea General FSJ Tech 17 08-04-2009 03:43 PM
high steer balljoint dana 60? 4x4fEvEr Off-Road FSJ Tech 7 01-25-2007 11:06 AM
Good Ford Dana 60 balljoint service set rockjeep44 Off-Road FSJ Tech 1 09-27-2006 10:37 AM
what's correct name / part #, (pics of balljoint bushing...?) TimK General FSJ Tech 4 03-31-2005 10:50 AM
Upper Balljoint help! Help! HELP! Ralph General FSJ Tech 11 05-29-2001 06:50 PM
