Old 02-08-2011, 10:29 PM
USN_Chief's Avatar
USN_Chief USN_Chief is offline
Wagoneer to cherokee drive line Interchangeability
Guys,
looks like i will be getting a 1979 jeep cherokee now I have found a 1988 grand wagoneer that has complete driveline in it about 25 miles from my house for very cheap. Would it be worth getting the 1988 and swapping it over to the 1979? They are both 360 motor vehicles?
Thanks Matt
Old 02-08-2011, 11:36 PM
Crazy_Jeepman's Avatar
Sloppy Shifter
79 wil have 360 GM th400 trans Q-trac transfercase, and pass drop front axle rear pumpkin offset to pass side. 88 will have 360 Mopar TF727 trans np229 transfercase, drivers drop front axle, centered rear axle.
could be done...............but you would need to swap everything and that would most likely include gas tank as well for drive shaft clearance. If you need just the motor that would be easy, anything beyond that, I would consider body swap.............even then
Old 02-08-2011, 11:43 PM
USN_Chief's Avatar
Thanks that is exactly what I needed to make up my mind will just leave the 79 as-is and work with it.
Thanks Matt
Old 02-09-2011, 09:31 AM
seventynine's Avatar
Also...if the '79 is a widetrack Chero the axles will be wider than the GW.
Dean
'79 J10
'77 Cherokee Chief
'79 CJ-7
'79 CJ-5
'46 CJ-2A
'93 ZJ Limted
'79 Wagoneer (RIP)
'13 FLSTN Softail Deluxe
Ordering Drive Line help Ziptie General FSJ Tech 5 06-21-2008 09:28 AM
Drive Line Noise Gramps Old Jeep General FSJ Tech 0 10-07-2007 09:32 PM
Front drive universal joints-1998 Cherokee Bob A. Coy General FSJ Tech 5 03-28-2004 11:12 AM
74 Cherokee parts into 73 Wagoneer Paul General FSJ Tech 2 02-22-2004 05:18 PM
