Old 01-23-2011, 08:26 PM
Hill Billy Deluxe's Avatar
Hill Billy Deluxe Hill Billy Deluxe is offline
Np208D?
Did some searches. How do I identify a NP208D? Thinking of a 700r4 swap with the Dodge np208 case. .....Tad....
TY, Mike
Bring a case of Budweiser and a can of PB Blaster....
1983 j10 SWB, Headlight relay upgrade.
360/727/np208, 4" Skyjacker Lift, BJ's 1/2" lift frt shackles, 31's, 2 inch body lift, Rear 22gal. Offy Dual Port, Holley 4160, Lincoln Locked AMC 20, BJ's Super knuckle kit. BJ's 8-10" Brake lines, PO Rattle Can painted, Yellow.
Old 01-23-2011, 08:31 PM
Crazy_Jeepman's Avatar
Sloppy Shifter
Why do you want a Dodge T-Case if you plan on running a 700R4? Just get a 700R4 mated to a NP208 out of a Chevy and you are done. Tad did his setup, but it was a major pain in the butt due to clocking issues between GM and Dodge
To answer your question though, Round Tag will say NP208D
Old 01-23-2011, 08:32 PM
mdill's Avatar
mdill mdill is offline
Gone. Not Forgotten.
TY, Mike
Look at the tag ?
Not sure what you are doing but you can go with a 208C or 241C with stock GM parts , you will need a 208C (from a Th350, 700R4, 4L60e .. truck) anyway for the input gear (27 spline) to swap into the Dodge case, then the you have adapter clocking issues to worry about.
The Dodge case (I assume the 208D like the 241D had a yoke rear output)
Mike
Home of ADHD project list
1977 J-10 Honcho 360-T15-D20
Old 01-23-2011, 11:31 PM
I'm learning as I go fella's. thank you for the input. I'll have to dig a little deeper.
I was assuming that the NP208D "Dodge Case" had the coeerrect spine 's and were able to clock correctly on the 700R4 in a Driver side drop set-up.
Old 01-23-2011, 11:59 PM
austinaubinoe's Avatar
similar question: does the np208 in my wagoneer have a 'J'? Like the NP231J that was put in the XJ's, TJ's, etc.
Old 01-24-2011, 05:18 AM
Tad did his setup, but it was a major pain in the butt due to clocking issues between GM and Dodge.
Yes it was and I don't really recommend it unless you have a lot of parts laying around, have some good friends that send you parts and feel like cutting into a very pricey adapter.
That's my understanding. Dodge and Jeep have fixed yokes, Chevy and Ford were slip yokes. No SYE kits were available for 208's when I did mine.
Last 208 swap I did with FSJ parts the 208 was tagged as "208AM".
That might change in the later part of the '80's to a "J", not sure.
Old 01-25-2011, 01:59 AM
Eugene 1's Avatar
Eugene 1 Eugene 1 is offline
TY, Mike
a lot of 4WD suburbans had them in the 80s and early 90s with 700r4
JEEP
2005 Ram 1500 HemI
