Old 01-23-2011, 12:08 PM
Lambrewski's Avatar
Lambrewski Lambrewski is offline
Junction Block Removal
Is it possible to remove the bolt from the engine bay side of the junction block and pull the engine side off without messing with the inside portion of the junction block/fuse box?
The reason I ask:
I'm moving the yellow wire from the starter solenoid to mate with the red wire inside the dash that goes to the splice (at the junction block) - and use the new yellow/red wire from the solenoid as a straight power source for the cab. The rest of the charging loop will be removed (red wire from alt to junction block, and yellow wire under the dash).
Thanks!
'78 Chief S W/T 360cid +.030 & RV cam, AGR steering gear, '80's Astro Van hydroboost, '84 GW steering pump, Edel elec fuel pump, TFI, MSD 6A, MSD eCore 48Kv coil, 8.5mm Spiral, TH400 w/ TCI +2qt pan & shift kit, BW1339, open D44's w/ 3.54's, EDL1406 w/ off-road, 4" spring lift, Rancho, 15x10 MT Classic Locks w/ 33x12.5 Toyo OpenCountry M/T
Old 01-23-2011, 12:29 PM
Crazy_Jeepman's Avatar
Sloppy Shifter
Yes, remove the bolt and with some coaxing it will come off. If I remember correctly there are lock tabs to contend with as well.
Old 01-23-2011, 12:33 PM
Michael_King024's Avatar
Michael_King024 Michael_King024 is offline
yes you can...AND ITS SO MUCH FUN!!!!! ....ASK ME HOW I KNOW!!!!
Big Mike
83 wag limited-360-
89 G.wag -360-
"10-4 rubber duck"
"In GOD we trust..all others pay cash"
-mat. 21:42-
Old 01-23-2011, 03:48 PM
[]V[]AXX's Avatar
[]V[]AXX []V[]AXX is offline
were you bleeding? I was. I needed a tetanus booster afterward too. I got so fed up with the rust problems that I gutted the truck and started cleaning and painting parts.
Old 01-23-2011, 05:03 PM
thinder's Avatar
thinder thinder is offline
Yep it comes right off, but there are actually two plugs, one overlaps the other so dont freak out if one wont come out on its own
86 Grand Wagoneer
Cummins Ve pumped 4bta
47RH
np241
D44 front and rear
Old 01-23-2011, 07:42 PM
bleeding sweatin hollerin cussin,,,LOL...actually the engine bay side was a breeze...but the interior cab side was holy great googly moogly summaamma boogly....especially putting it back together.....definataly a 2 man job to sandwich them back together. also the interior plug it near impossible to align one handed with all those wires....do your self a favor and remove the driver seat to give you more room to maneuver..... and since im fat all under dash work is a PITA!!
Big Mike
83 wag limited-360-
89 G.wag -360-
"10-4 rubber duck"
-mat. 21:42-
401 short block rebuild opinions...... aallison General FSJ Tech 36 02-04-2011 05:30 AM
Block Heater Removal dano73 General FSJ Tech 1 03-29-2010 04:09 PM
Small Block versus Big Block (My apologies to AMC purists) 1986 Woody General FSJ Discussion 55 08-19-2008 01:04 AM
block prep del General FSJ Tech 0 12-18-2006 11:04 AM
Questions on Bodywork/Painting Cont. 4x4n In A Cherokee In Colorado Body 190 08-07-2004 01:50 AM
