  #1161
Old 02-24-2020, 07:55 PM
Full Size Jeeper's Avatar
I was able to get the bumper, and a few other pieces on today.
Old 02-24-2020, 07:56 PM
Old 02-25-2020, 09:23 PM
I removed this junction bar and used some wire connectors to get everything back together. Most of the wires are now running in the same direction and I could use a smaller box to keep everything dry.
Old 02-25-2020, 09:25 PM
I'am going to mount it up above where the spare tire goes. It is well out of the way and should be safe.
Old 02-26-2020, 07:12 AM
bwwhaler's Avatar
bwwhaler bwwhaler is offline
Looks great, obviously better than and easier to access than in the tailgate. Where did you source the box?
87 GW 360 performer intake Holley 670 HEI
Razor Grill 4"BJ's springs 32's CS-144 Serehill's light and tailgate harness
Old 02-26-2020, 08:49 AM
Harbor Freight. My store has two of this style. This is the smaller of the two. I had to cut out some of the plastic compartments with a small Dremel tool. Also it is no longer water tight. Might try and put a little sealer at the two holes that the wires enter/exit.
Old Yesterday, 12:26 PM
letank's Avatar
letank letank is offline
what tool do you use to cut the offending rusty bits/panel
Very impressive resto work. Sorry to have missed the built.
Yes the early FSJ did not have a good inside metal prep, as you said : none, only the overspray, and as such the bonding of the roof and the support structure being done by spot welding, the seams will rust. By 1982 , as I found out when I cut off some roof bits, the metal received some treatment, the inside roof is treated with some dark primer and painted, photo to follow
you can see the beginning of oxidation at the roof gutter inside seam
and the undisturbed structure, that separated when no spot welds are holding the pieces together
and the oxidation is noticeable at the bottom, on a calif vehicle... but the outer roof was severely oxidized
Old Yesterday, 03:53 PM
This and a grinder with a cutoff wheel. This one came from Harbor Freight.
Old Yesterday, 10:29 PM
bkilby's Avatar
bkilby bkilby is offline
I've had that HF one for years now. It's really nice to reach into areas that a normal cutoff wheel won't get to....but it's really under powered. You have to go slow and apply almost no pressure or you stall the wheel. That said, I'd buy another the day mine broke....if it ever broke.
Nice work by the way.
FrankenJeep (Turbo Wagoneer) build thread Ghinmi Street & Performance 230 10-04-2015 09:11 PM
How tall for a daily driver / mild off road Wagoneer lorenmjones General FSJ Discussion 18 09-11-2014 05:57 PM
Build thread - 3x Grand Wagoneer 89/90/91 sportsidedan General FSJ Discussion 22 09-03-2013 12:11 PM
