Old 08-10-2022, 04:13 PM
SJTD SJTD is offline
Need Pic Of Behind The Dash
Anyone have one or can point to one? Putting the dash back in and have a rod about 5" long with a 1/2" hole on one end and two captive nuts on the other I can't seem to figger out where it goes.
Thanks.
Sic friatur crustulum
Old 08-11-2022, 03:00 PM
Heep-J4000's Avatar
Isn't that going on the topside of the bracket from the pedals!?
It's supporting that bracket onto the firewall
73' Jeep J4000 (named Heep or Desert Dragon) amc 360 V8 converted to LPG with T15/D20 (was my daily work truck for thirteen years and is getting major overhaul at the moment!)
80' Jeep cj5 350 V8 Chevy/sm420/D300 project
70/71 Jeep J4000 parts truck with Buick 350
Former vehicles:
Old 08-11-2022, 03:29 PM
Thanks but no. There are two rods that go from the dash up to the firewall. This one seems to mount under the left rod at the lower end where it meets the dash and heads over to the left. Got some answers on the other site that support the theory that it's unused on mine so I'm leaving it off.
Thanks again.
Old 08-11-2022, 04:54 PM
devildog80's Avatar
devildog80 devildog80 is offline
Possible it attaches to the park brake base for added support from the side kick panel mount to the firewall?
Or is it too short to reach?
I looked through the TSM for '82 Wagoneer, but shows nothing under the dash.
EDIT
As you were.....found your thread on other site, and you have it figured out
'81 CJ5 Base, 258 I6, MC2100, T176 4 spd, 300 TC, D30 Front NT, 3.31, 2-Piece AMC 20 rear NT, 3.31, 4" high arc spring lift
'84 Grand Wagoneer, 401 V8 (.030 over), MC2150 HA Comp, 727 auto, Selec-trac NP229, AMC 20 REAR - D44 FRONT - WT 3.31, 4" high arc spring lift
Rather be driving, than waiting to be modified
Pic request: '86-'91 dash pad removal grandwag89 General FSJ Discussion 3 11-17-2014 12:34 PM
old dash swap (76 out, early style in) bmax65 General FSJ Discussion 11 06-22-2014 05:35 AM
Stuck Dash 76FSChief General FSJ Tech 4 02-24-2010 08:33 PM
Wiring Conundrum (Dash and or Engine) spyderkeeper General FSJ Tech 13 10-19-2008 08:57 PM
