Old 06-01-2022, 10:43 AM
lobelsteve lobelsteve is offline
1990 Grand Wagoneer LS/6l80e/MP1222
Purchased on BAT Feb 2022. Runs great for 194000 miles on a partially rebuilt 360. So probably 8mpg and 110hp.
From having it delivered until now, here is what has been done:
Purchased 2/25/2022
Upcoming parts list:
TC shifter
Lokar 1809, LS starter motor
Motor mount for LS
BJs tank and pump
Novak Radiator/Fan
CPSLS3EROD6L80E LS3/6L80e 4wd with acc drive 19421444
Completed list:
Door lock relays-BJs- need to figure out why Viper remote quit working
Replace temp gauge
Overhead console- rewired harness and replaced computer
Fan and clutch replaced
Weld exhaust flanges
valve cover gaskets
Replace front carpet-check wiring to overhead on driver B-pillar
Check Differentials 3.75 pints each 75w90 or 80w140
Tighten suspension bolts 30 shackle, 50 spring eye
Finish wiring tailgate: review instructions, Tailgate apart and check tracks. Remote? (Team GW) p412 wiring diagram, Delcity switch/wire
Rear camera install
Replace mirrors, check wiring/switch (Ebay) https://youtu.be/uVVyBorJy0Q p422 wiring diagram. p672 is XJ pinout, 674 is harnesses, vs Mitsi switch
E clip , 4 screws m6 20mm for mirror
Tune carb. Black soot in exhaust
Door lock actuators- clean and adjust, front doors
Clean and check cluster, replace bulbs
Replace NSS p756 wiring diagram- reverse lights not working
Coolant gauge- replaced sending unit x2, replace thermostat
weld frame at front drivers side above axle
Exhaust hanger
5.25
Old 06-02-2022, 06:10 AM
IMG_8525 by Steven Lobel, on Flickr
IMG_0518 by Steven Lobel, on Flickr
67484424472__9942644B-3C4A-4AA4-A5CD-FB75E0416508 by Steven Lobel, on Flickr
67543530514__C2D567A0-4F50-42F5-85F9-910941237DC5 by Steven Lobel, on Flickr
Old 06-03-2022, 11:16 AM
SOLSAKS's Avatar
SOLSAKS SOLSAKS is offline
NICE G.W.
dave in NC
you will love those Bilstein shocks !!!
Old 06-03-2022, 12:14 PM
devildog80's Avatar
devildog80 devildog80 is offline
Is that overhead console from a GW?
My '84 does not have one, and I would like to add it.
'81 CJ5 Base, 258 I6, MC2100, T176 4 spd, 300 TC, D30 Front NT, 3.31, 2-Piece AMC 20 rear NT, 3.31, 4" high arc spring lift
'84 Grand Wagoneer, 401 V8 (.030 over), MC2150 HA Comp, 727 auto, Selec-trac NP229, AMC 20 REAR - D44 FRONT - WT 3.31, 4" high arc spring lift
Rather be driving, than waiting to be modified
Old 06-03-2022, 12:34 PM
Thanks Dave. GW came out of Charlotte. Bring a Trailer bid.
https://bringatrailer.com/listing/19...d-wagoneer-49/
Old 06-03-2022, 12:36 PM
Came with non working overhead console. Went through a few computers and then rewired from drivers footwell to roof. Bought one computer that had wires and plug so I was able to de-pin and make it work. The lights/plastic/metal were all there, just needed to clean contacts, do wiring, pop in new bulbs, and replace burned up computer.
Old 06-03-2022, 12:39 PM
devildog80's Avatar
Thanks, will look into that when time comes for interior fixin'.
Old 06-11-2022, 12:00 PM
6/11/22: Took down tank, repaired frame rail. Not much to weld to and I'm a lousy welder. Will clean it up tomorrow. Took off NP228. Took off exhaust. Painted BJ's steel tank. Drained coolant. Tomorrow I need to disconnect everything from engine/transmission and pull it out. Then a lot of cleaning.
NP 228 by Steven Lobel, on Flickr
Frame rail repair by Steven Lobel, on Flickr
Tank rot by Steven Lobel, on Flickr
089E7EB3-6168-4315-BC81-60E6A7580DBE_1_105_c by Steven Lobel, on Flickr
Tank out by Steven Lobel, on Flickr
Front frame repair by Steven Lobel, on Flickr
BECE79BD-6845-4490-A8E8-9BB3D89FE271_1_105_c by Steven Lobel, on Flickr
A1B097BF-C47D-4FB6-A456-5279FF9B8E14_1_105_c by Steven Lobel, on Flickr
Old 06-13-2022, 04:05 PM
Busy weekend. Got 6 hours in on Saturday and Sunday. Unhooked everything, cut off exhaust, pulled the motor. Still cannot figure out why the Viper alarm door remote quit working when I installed the BJs door relay kit. Need to prep the new tank and install pump and sending unit. Run new fuel line to front with regulator and filter. Electrical should not be hard. Besides ignition wire from cab (hoping the Viper does not mess things up), only oil pressure/ water temp / voltmeter gauges. The rest comes from the GM harness. Lots of wires going to nothing at this point. Ignition/coil/choke all gone.
Pretty jeep by Steven Lobel, on Flickr
empty bay by Steven Lobel, on Flickr
360 rear by Steven Lobel, on Flickr
360 side by Steven Lobel, on Flickr
LS3 by Steven Lobel, on Flickr
Old 06-13-2022, 04:10 PM
Just bought twin stick from Rock Laurence. Vacuum thing still works, but I do not want to deal with creating the right amount to keep it working from new motor. Less stuff is better.
Old 08-14-2022, 04:50 PM
Got engine in, twin stick installed. Fired right up but found two fuel leaks. One at Tanks Inc filter/reg output. Maybe defective part.
Got to get driveshafts done, exhaust made.
Would post more pics but having to move everything to Flickr then upload here is a PITA.
Might redo my build thread on hosted server and just add a link.
There are no quality build threads with step by step. Would love to do that. Basically take harness back to the firewall connector and have a list of what goes where. Looks easy enough but all these old jeeps have been cut to pieces. I had a lot of duct tape holding wires crimped together when I got started.
Anyways, here is a link to first start.
5480DA0D-0830-429F-A5A8-F848458473A4_1_102_o by Steven Lobel, on Flickr
Old 08-14-2022, 04:55 PM
https://www.youtube.com/shorts/ZD-iguCzcJ4
Old 08-17-2022, 02:15 PM
AWESOME! Great pictures! It sounds happy! This truck is going to be so fun to drive!
00 Baby Cherokee
Old 08-25-2022, 07:36 PM
SOLSAKS's Avatar
holy smokes, engine sounds so good.
the easiest site on the planet that helps you post photos is
postimages.org
read how to below:
if I can use this site for posting on IFSJA,...anyone can
I lucked up and chose "postimages.org" site for trying my first photo post
easy as pie, and free
after you load the image
it gives you many choices under the photo,....
the one you want to choose is "hotlink for forum posting", ....YOU CLICK THE BLUE FOLDER IMAGE AT RIGHT OF LINK called Hotlink for forum posting
when you click that, it copies the link automatically to your comp....
then go to ifsja and after you type your message hit PASTE,...and that is it
the photo is on the site,....
Overhead Console on 1990 Grand Wagoneer WagonDriver General FSJ Tech 12 05-02-2018 01:43 AM
1990 grand wagoneer paint code SOLSAKS FSJ-PRIS 3 02-28-2018 12:32 AM
1990 gw rear wiper gophman General FSJ Discussion 2 03-15-2015 03:41 PM
GW noob, 1990 worth? and other ?s wap General FSJ Discussion 22 08-11-2012 07:51 PM
Which AMC 360 engines would fit my 1990 GW? JacobNL General FSJ Tech 7 01-25-2011 07:01 PM
