Old 04-29-2022, 01:03 PM
devildog80's Avatar
devildog80 devildog80 is offline
84 Grand Wagoneer Revival
Hey FSJ Peeps,
New to owning an FSJ, and brought home my first recently -
1984 Grand Wagoneer
Been sitting for about 10 years, in the AZ desert on a dirt storage lot, so plenty of work to do
401 ci (said to have only 2000 miles since rebuild)
Auto
4 inch lift with high arch springs
Not a woody (think it was one of the '84's that wood trim was opted out that year)
All mechanicals look like it was just parked some 10 yrs or so back, then not driven again.
Starting with verifying what I actually have, get some electric to it and see if I can roll the windows up tight, go through the treasure trove of other parts and paperwork that came with it.
Looking forward to getting "Pig" revived and back on the road.
'81 CJ5 Base, 258 I6, MC2100, T176 4 spd, 300 TC, D30 Front NT, 3.31, 2-Piece AMC 20 rear NT, 3.31, 4" high arc spring lift
'84 Grand Wagoneer, 401 V8 (.030 over), MC2150 HA Comp, 727 auto, Selec-trac NP229, AMC 20 REAR - D44 FRONT - WT 3.31, 4" high arc spring lift
Rather be driving, than waiting to be modified
Old 04-29-2022, 01:09 PM
devildog80's Avatar
Will get some pics posted.......when I can get them sized small enough to work!!
Old 05-10-2022, 04:47 PM
devildog80's Avatar
Ok, going to try flickr to see if pics work.
Here is my rig
IMG_20220410_131339850_HDR by Scott Weckerly, on Flickr
Old 05-10-2022, 04:57 PM
devildog80's Avatar
More pics
Body is decent enough, tires are shot, interior needs tons of work, and engine is hopeful!
20220410_134212 by Scott Weckerly, on Flickr
20220410_134224 by Scott Weckerly, on Flickr
20220410_134234 by Scott Weckerly, on Flickr
20220410_134527 by Scott Weckerly, on Flickr
20220410_134437 by Scott Weckerly, on Flickr
20220410_134453 by Scott Weckerly, on Flickr
20220410_134502 by Scott Weckerly, on Flickr
Old 05-10-2022, 05:02 PM
devildog80's Avatar
A few more
20220410_134258 by Scott Weckerly, on Flickr
20220410_134322 by Scott Weckerly, on Flickr
20220410_134314 by Scott Weckerly, on Flickr
20220410_134305 by Scott Weckerly, on Flickr
Old 05-10-2022, 05:15 PM
devildog80's Avatar
Engine Bay
20220410_134149 by Scott Weckerly, on Flickr
20220410_134138 by Scott Weckerly, on Flickr
20220423_084451 by Scott Weckerly, on Flickr
20220423_084338 by Scott Weckerly, on Flickr
20220423_084216 by Scott Weckerly, on Flickr
20220416_125619 by Scott Weckerly, on Flickr
20220416_125750 by Scott Weckerly, on Flickr
20220416_125844 by Scott Weckerly, on Flickr
Old 05-10-2022, 05:33 PM
devildog80's Avatar
Ok....down to fixin.
Re-attached battery NEG cable from top of A/C compressor case to Passenger side engine mount bracket, to try and avoid electrical gremlins from the git! (no pic)
Dropped fuel tank to clean and service, making sure everything ready to feed engine when ready to fire up.
In line existing fuel pump - soaking to see if it will work again
20220423_163608 by Scott Weckerly, on Flickr
Dropping skid plate/tank - had to remove rear driveshaft off rear yoke for clearance
20220423_163634 by Scott Weckerly, on Flickr
Tank in skid plate just after drop
20220423_180155 by Scott Weckerly, on Flickr
Will pull sending unit out and test
20220423_180246 by Scott Weckerly, on Flickr
Old 05-10-2022, 05:36 PM
devildog80's Avatar
Nice newer exhaust from manifolds to tail pipe
20220416_125900 by Scott Weckerly, on Flickr
Old 05-10-2022, 08:26 PM
Full Size Jeeper's Avatar
Very nice. What does the emblem say on the right rear quarter, can't make it out?
1978 Wagoneer
Mods:
Old 05-11-2022, 11:40 AM
devildog80's Avatar
It is the "Grand" emblem. Same on both sides.
Some think it was put there on the factory line....others think it was put there by one of the PO's when overspray of the paint was done some years back.
I searched for emblem placement mix ups, but found nothing to indicate it happened during factory assembly.
The 4 wheel drive emblem is supposed to be on the back corners, and "Grand" over Wagoneer on side of front fenders.
Some day I will get them back where they should be.
Old 05-11-2022, 01:51 PM
Your truck is AWESOME!!!! I especially dig the really old school looking MSD 6A!
What is that mounted on top of your A/C compressor? Fuel Filter? What are your plans after you get it running?
00 Baby Cherokee
Old 05-11-2022, 02:29 PM
devildog80's Avatar
Yes that was the PO's bypass fuel filter.....mounted backwards, and return capped off.
Have since removed it, as it was fed from drivers side frame hard line from fuel pump, with rubber fuel line all the way from frame up to the filter. Hose was cooked bad!
I intend to replace the rubber line that was on the engine, with a hard line routed away from heat sources, and only connected to hard line on frame with short rubber line between, then rubber connect to new filter up top.
Not sure I will use bypass yet, but will identify it and hard line parallel with feed line it back down to frame. If I want to activate it just a simple rubber hose connection needed.
My CJ5 I use the bypass filter with mechanical pump, full open bypass, with no vapor lock issues running 1-2 mph on trails in 4 low crawl and 114*+ heat out here.
Intent for Wagoneer ultimate use.....road and light trails. No off road hill or rock climbs, but able if needed. Have the CJ5 for that.
Replace using our '07 2wd Dakota V6 pulling our current camper 16' Scamp (my dads). Dakota does just ok
Wagoneer boasts a 401 ci, auto + 4x4
Wagoneer can pull more camper should we upgrade some day
Wagoneer is more comfort for my wife for longer light trails. CJ5 is too rough for her physically, and I want to take her out on trails in comfort.
I like the room to haul stuff in the truck covered and protected
I can keep up in interstate traffic on any grade road. That pull up to the Rim through Payson is a bugger with the Dakota.
Want it reliable to go when and where I want, and get home
Old 05-16-2022, 01:30 PM
devildog80's Avatar
Ok, a little progress, a few more pics, and a little disappointment :/
Washed out the fuel tank, and my-my-my the crud that washed out. Used de-greaser with hot water, and color of the washout was like mustard mixed with a little barbecue sauce.......nasty, but much better now.
Sorry no pics of that process.
Took fuel sending unit apart, cleaned with some carb cleaner and soft brush, and actually have OHM readings now.
(NOTE - To open this up, TAKE LOTS OF PICS FIRST, then see the 3 metal tabs and little wire by the arm, on second pic. Little wire unhooks at the top, then can be removed. Gently bend the 3 tabs back with pliers, only till cover with part # is free from base. Do the cleaning and check for operation before re-assembly. If good, re-assemble and check again to be sure of operation.)
When I first took it out of the tank, action on moving the arm was smooth, with no readings. Now you can feel the little arm inside bump over each little wire on the resistor plate. Will calibrate before putting tank all back together and re-install. Want to know where "E" is
Cleaned up the float, sock, float arm, and tank vents with same de-greaser.
20220515_160502 by Scott Weckerly, on Flickr
20220515_144435 by Scott Weckerly, on Flickr
20220515_144523 by Scott Weckerly, on Flickr
20220515_144503 by Scott Weckerly, on Flickr
20220515_144447 by Scott Weckerly, on Flickr
20220515_153706 by Scott Weckerly, on Flickr
20220515_160447 by Scott Weckerly, on Flickr
Old 05-16-2022, 01:31 PM
devildog80's Avatar
Ok, now for disappointment
Existing carb - pulled the top off and filled bowl. Looked good inside
Spray bottle of gas....a little down the throat of the carb
Cranked engine over and found some weak links on solenoid connections. Cleaned and re-assembled and starter was faster
No start
Checked wiring and connections through coil, distributor, and back to MSD-6A.
No hot side coming through on coil
No power from ignition "ON" to MSD-6A (per troubleshooting guide on MSD data sheets)
Got late so will start back checking "IGN" side to feed MSD-6A, and see if good connection, or perhaps MSD is shot.
More to follow
Old 05-16-2022, 01:48 PM
devildog80's Avatar
More pics of interior
20220515_160957 by Scott Weckerly, on Flickr
20220515_161005 by Scott Weckerly, on Flickr
20220515_161046 by Scott Weckerly, on Flickr
20220515_161103 by Scott Weckerly, on Flickr
20220515_161110 by Scott Weckerly, on Flickr
20220515_161117 by Scott Weckerly, on Flickr
Old 05-16-2022, 01:52 PM
devildog80's Avatar
Body damage......besides paint
20220515_161316 by Scott Weckerly, on Flickr
20220515_161331 by Scott Weckerly, on Flickr
20220515_161342 by Scott Weckerly, on Flickr
20220515_161304 by Scott Weckerly, on Flickr
20220515_161255 by Scott Weckerly, on Flickr
20220515_161248 by Scott Weckerly, on Flickr
Old 05-17-2022, 09:33 PM
SOLSAKS's Avatar
SOLSAKS SOLSAKS is offline
nice rig, I like the gold wagoneers
Old 05-18-2022, 09:22 AM
devildog80's Avatar
Thanks
Got lucky with the "champagne" color is what it comes up as!
Lots of fun ahead for sure
Old 05-22-2022, 04:28 PM
devildog80's Avatar
Update
Been tickling the wiring now for 2 weekends, and still no start.....UGH!
Fuel tank still off, pending parts so just using the existing 2150 carb, filled the bowl, and no leaks.
We can hear fuel injecting into carb throats when throttle worked, so might be worth rebuilding, as it is an altitude compensator carb. Would be nice to have it going from home and up the mountains camping.
Did full trouble shooting steps on MSD system, and unable to get spark at coil. Backtracked and found 12V, then set to verify wiring to MSD.
Irregular readings and having to jiggle the key while testing, as voltage was jumping between 9 and 12V.....UGH.
Finally switched out MSD for OEM ECM/coil, and plugged back into OEM harness.
No change.....still voltage dropping, so next step is to pull under dash A/C out, and pull start switch connectors off. Clean up contact points and see what happens with voltage.
20220522_080245 by Scott Weckerly, on Flickr
20220522_080257 by Scott Weckerly, on Flickr
Old 05-23-2022, 07:23 AM
cu4whln's Avatar
cu4whln cu4whln is online now
Hmm - Just a thought....
Is the original "Resistance" wire still in place?
Stock ign runs on 9 volts on purpose.
Only get 12v during crank starts
1977 "401" 'Da Chief
1979 Chero: "Madness" [Sold]
2001 XJ : Driver - 2016 JK 2 door
Round 2- LT Swap: 'Da Chief:
"Madness" build here:
Good Video on Drum Brakes Herezja General FSJ Tech 10 02-11-2017 02:18 AM
Dormant A/C revival Q's jpcoutts General FSJ Tech 5 04-02-2012 08:28 PM
AMC 20hd axle bearings (revival) Sarge's 7 General FSJ Tech 6 11-01-2004 06:26 AM
