  #41
Old 03-15-2022, 12:34 AM
Kaiserjeeps's Avatar
I am super impressed with your progress. Your X model is going to be a head turner. I appreciate the woodgrain info. My X model has the 125 year old white bleach look to it also. I am also proud to say I had a look at my wagoneer in the garage today. For the first time in a couple years. I want to get it going again. My priorities have change now that I lost my wife. Time to get all these projects done and going again. And Yes... Covid and the creators of it can go straight to the burning lake of sulfur as the good book claims they will. That day her death will be avenged, and I can rest. I trust those claims completely.
I will be watching the progress. It is a great build. Thanks for posting all the information.
Am I done yet?
Holy Moly, I am done.....
1969 1414X Wag,
71 J4000 Rang-A-Stangs next project!!
Building a m715 over at the m715zone
Beloved wife Elizabeth Ann Temple Murdered by covid on Oct 19th 2021
Old 03-15-2022, 09:03 PM
bkilby's Avatar
bkilby bkilby is offline
Off topic, but so sorry to hear about your wife Kaiserjeeps. I have another buddy that lost his wife to covid too.
Old 03-16-2022, 02:05 PM
bluehwy's Avatar
bluehwy bluehwy is offline
Originally Posted by cu4whln
Great update!
I just read your whole thread... Cool Project!
Keep at it.. I am 6 years into my "part time" project here and there.
A little at a time . . .
Yuppers, bought mine in 2013-2014 and started pullin' her apart 8/2018. I'm 3 1/2 years in... Si Se Puede! (Sorry just had to say it because yours is in Central Valley too).
_____________________________________________
Current: 1979 Wagoneer
Previous: 1988 Grand Wagoneer (found recently behind a bar and passed on buying it back-too far into current build),
1989 Grand-sold to Montana
"And for those brave Right Wing Americans who say it's about... keeping America safe... if you want to fight against a country you need a F-15. You need a something a little more than a gun." ---Brandon
Old 04-01-2022, 12:49 PM
melford1972's Avatar
melford1972 melford1972 is offline
Hey bluehwy, Central Valley represent! I am originally from Visalia, though I have been living in SoCal for quite a while. I still spend a lot of time up there though. My Wag is going to see a LOT of trips in the foothills and Sequoia National Park. Where are you based? Your sig says North Idaho, which is funny because I get up there pretty often too. My father-in-law moved up to the CDA area about 8 years ago. He couldnt handle SoCal anymore, and I cant say that I blame him. I started reading through your thread about your 79. Cool build. I thought about doing a full frame off, but decided to do it this way instead. You are definitely doing it right.
Old 04-01-2022, 03:47 PM
Update with some pics.
If anyone wonders, these pics were taken under a fluorescent light, so it makes the color of the paint look a lot more yellow than it actually is. I did not respray since previous photos were taken, just in case anyone wonders.
So the shop I am using is doing pretty good work. It seems like slow going, but their attention to detail is pretty good. If I had done this all myself, the workmanship wouldn't have been nearly this good.
As mentioned, the engine ended up sitting pretty far forward in the engine bay, which forced us to get creative with fans, etc. It turned out to be a pretty tight fit for all components.
They've used every inch of space in this engine bay. Note the a/c components mounted in the pie pan holes. Will be using the original factory a/c (in place of the center glovebox). For space, we had to use a low mount compressor bracket, which goes low on the passenger side.
Fan shroud and dual fan setup. I think this should work well, even when I'm crawling slowly up steep stuff.
Gauges in and the interior is almost ready for carpet and console. The go pedal is mounted too. You can see the a/c in this pic too. I also had the factory radio rebuilt with a USB port so I can plug my phone into it for music. I opted not to go the Bluetooth route, but now I am wondering if I should have done that.
The booster and master fit. Glad, because I didnt want to run hydroboost.
I have three different cold air intakes. Hopefully one will fit. Will return the others.
These pics also do not show the external transmission cooler, mounted low on the drivers side. This also got an external fan to keep things cool while climbing up the Mineral King road to some of my favorite fishing spots. (That road is famous for causing overheating.)
Work is busy and we are in the process of moving, but I almost have the fender badges ready to take into Solidworks so I can send them out to CNC. Something I love about these old rigs from a design standpoint is how much attention to detail there is. Each fender badge actually has a tiny bit of arc/taper to make it integrate with the fender more smoothly. (You can really see it in this pic against my computer screen.) Modern cars and trucks NEVER do this and the design nerd in me loves it.
Old 04-01-2022, 08:00 PM
bluehwy's Avatar
Originally Posted by melford1972
Hey bluehwy, Central Valley represent! I am originally from Visalia, though I have been living in SoCal for quite a while. I still spend a lot of time up there though. My Wag is going to see a LOT of trips in the foothills and Sequoia National Park. Where are you based? Your sig says North Idaho, which is funny because I get up there pretty often too. My father-in-law moved up to the CDA area about 8 years ago. He couldnt handle SoCal anymore, and I cant say that I blame him. I started reading through your thread about your 79. instead. You are definitely doing it right.
Howdy. Actually I think you are doing it right. You
Old 04-01-2022, 08:02 PM
bluehwy's Avatar
Dang apostrophes
Old 04-14-2022, 11:41 PM
Dang apostrophes
Tell me about it. I posted something on the other FSJ site tonight and when I hit submit, I thought "Oh no! I forgot to check for apostrophes!" But then I remembered that I was not on ifsja.
Old 05-10-2022, 11:41 AM
bluehwy's Avatar
I was in the mountains near CDA when trying to respond. Cell service, apostrophes and a time crunch I never finished responding. I'm about 25 minutes from downtown CDA. Back in Bakersfield now for about a month. Then gone for good.
I was tryin' to say you are doing it right because you will be enjoying yours sooner and saving a hell of a lot of money!
My uncle lives in Visalia. You should stop by one of these times passing through Bako. I dropped my Wag off yesterday where a guy is helping with the wiring. I'm guessing I'll have it back in a couple of weeks.
Old 05-12-2022, 02:44 PM
great build !
on the woodgrain,.....3M DINOC is going to be the best material, no question.
from the other suppliers you are prob getting a digitally printed material
that when compared to actual 3M dinoc is 2nd or 3rd rate at best.
Old 05-16-2022, 06:19 PM
I am not sure about the "saving a hell of a lot of money" part. But it SHOULD be on the road very soon. We fired the engine two weeks ago and are just putting the interior back together now. Home stretch.
Yeah, my brother left CA for ID for good too. So I get it.
I might not be through Bakersfield before you leave. We are in the middle of moving ourselves. But maybe I can meet up with you next time I am up your way. My father-in-law lives in Rathdrum, and that is probably pretty close to where you are.
When I get my Wagoneer done finally, I have a dream of driving it up there and fishing at a bunch of spots on the way up. That might just be a pipe dream though.
Old 05-16-2022, 06:31 PM
Originally Posted by SOLSAKS
great build !
First of all, I LOVE your J-10 "Tonka truck" build. It is just...gorgeous the way it turned out. Most people would have been happy with where you started. But you took it to the next level with the interior, paint, wheels, seats. Nicely done.
I actually had a hard time finding the DINOC I decided to go with. I could find it in the interior/normal material, but since it is going on the outside of my truck it needed to be the exterior (EX) version.
Everyone was saying it was out of stock and one distributor told me it was discontinued. But then a woman named Cindi at Interwest talked to me on the phone and helped me locate some...in Japan!
She and her husband are into restoring old Audis, so when she heard it was for a car project, she went above and beyond. Always nice to find good folks that are willing to help others out. Unfortunately, it seems like that is getting more and more rare these days. But then I guess it makes it even better when you experience someone like that.
Old 05-16-2022, 08:15 PM
bluehwy's Avatar
Rathdrum is pretty close. Excited for you to have yours running soon. Fun stuff!
Old 05-26-2022, 02:14 PM
Melford,
sorry I did not mention the company that I got mine from on eBay
'METRO RESTYLING"
but it sounds like you found some with help from good car people.
thanx for the J-10 compliment, it never gets driven, I am terrible for going all in on a project, then getting bored with it, and cautious about when and where I drive it, that is the problem with taking a project too far.
I will try to make myself use it more often.
I am ready for you to enjoy all of your work on your project.
Old 09-19-2022, 05:19 PM
A few recent pics of progress.
Fresh glass is cut and ready to go in. Windshield is supposed to show up tomorrow.
I am still not happy with the air cleaner setup, but it will do for now. As previously mentioned, the adapter to the D20 tcase pushed the engine pretty far forward in the engine bay. That left very little room for the air cleaner assembly. NOW I realize how I could have addressed the issue, but too late to go back and fix that now.
Recreated the armrest on the center console. Thanks to Kaiserman for tracing a template of his armrest for me to copy. The materials are not exactly right, but it is close enough for me. As for the seatbelts, these are borrowed from the aviation world since this is going to be my daily driver and I will be using it to haul kids around. Those seatbelts have full airbags in them. If anyone is interested, here is a link: https://www.amsafe.com/airbag-system...atbelt-airbag/
Really happy with how the woodgrain turned out on the center console. I will be using the same DINOC on the outside, so everything matches.
I opted to delete the chrome strip around the center console. Felt like it was visually distracting and I like this better.
Here is where the ride height settled. It is a little higher than I was hoping, but I can switch the leaf springs out later if I really want to. Still undecided on which tires I am going to run. Those are Falken Wildpeaks on it now, which I might run for a while since I have them already. Ultimately, I won't go any bigger than what is on there now, which is 30x9.5. Going to powder coat the original wheels white and run the original Radial style hubcaps. At least I think that is what they are called.
Also deciding on the process for the fender badges. I have too much on my plate to try to figure that out right this second. I can have them machined out of aluminum or I could 3d print them and cast them myself out of pot metal. Thanks to tgreese for the suggestion on that.
Very close. Thanks to everyone on this board that has offered advice during this build.
Old 09-20-2022, 07:32 AM
bkilby's Avatar
That's a pretty cool seat belt/air bag system. Looks pretty expensive too. Does it work with 12V systems too?
Old 09-20-2022, 04:19 PM
Seat belt electrical is self-contained with batteries. No wiring to truck power. I think this is because they want to make sure they always work, no matter what happens to electrical systems. The FAA requires reman every 7 years for this system in an airplane, but for automotive use I figure I can go a little longer.
And yes, the system is not cheap, but with the way people drive here in SoCal, $3,200 is a small price to pay for a little extra safety. A few years ago, I got into an accident on 5 north near Disneyland and it scared the heck out of me. Should probably switch the seats out to something with a headrest, but that will be left for another day.
Old 09-21-2022, 07:17 AM
bkilby's Avatar
Ah batteries. Amsafe's website isn't the most informative one I've seen. Lol.
I understand the how people drive comment. I'm in Burbank, where are you?
Old 09-22-2022, 10:33 PM
Just relocated to Ventura. But over the years I have lived in Glendale, Pasadena, San Clemente, Encinitas, and San Diego.
Glendale, right next door to you, is probably one of the most terrifying places I have ever driven. I used to have to commute through there every single morning on the way to work. Going by the Galleria on the 134 always felt like I could die at any given second. Crazy how the tire tracks and skid marks on that freeway just go all over the place. With zero attention to lane lines or anything.
Old 09-23-2022, 07:49 AM
bkilby's Avatar
Yeah, that sounds like Glendale all right. That section from Glendale Blvd off ramp to the 5 freeway is always a cluster to drive through.
Custom seat mounting (pics needed) Sir 85 General FSJ Tech 0 03-01-2007 11:00 PM
Custom Seat Covers via SeatCovers.net Manhattan General FSJ Tech 9 02-03-2004 02:37 AM
1970 360 vs. 1978 360 bigblack'74 General FSJ Tech 9 01-18-2003 11:08 AM
Custom Stock Exhaust? UnkleMunky Drivetrain 9 03-26-2002 11:05 AM
