View Poll Results: Trivia, So which shock do we feel are best?
Belstein 5100 Series : 31 27.68%
Belstein Heavy-Duty Self-Adjusting : 9 8.04%
Procomp ES 3000 : 5 4.46%
Procomp ES 9000 : 4 3.57%
Procomp MX6 : 2 1.79%
Rancho RS5000 : 25 22.32%
Rancho 9000X : 33 29.46%
Sky Jacker : 3 2.68%
Superlift : 0 0%
Warn black diamond : 0 0%
Voters: 112. You may not vote on this poll
Old 01-17-2009, 02:39 PM
badaboom's Avatar
badaboom badaboom is offline
Shocked on Shocks
For the overall general driver Should kinda do it all.
Procomp ES 3000
Procomp ES 9000
Procomp MX6
Rancho RS 5000
Rancho 9000
Sky jacker
Superlift
Warn black diamond
1981 Jeep J10 Laredo, 401-V8, 625 Carter, Lunati 262/268, Edelbrock Performer, MSD Ign., Hydroboost, Hyd. Clutch, Flow Cooler WP, Be Cool Aluminum Radiator, Doug Thorley, NV4500 5-Spd, NP-231D, 3.73 F/R Trac-Locs, Rustys 4" Lift, Vintage Red Metallic, Black Interior and 33X10.50X15 BFG, FiTech400 to come - IN PROCESS Bling Bling Cha-Ching
Old 01-17-2009, 03:27 PM
jaw knee's Avatar
jaw knee jaw knee is offline
I run Rancho 5000s. Don't know if there the best, cause that's all I've used. When I first got em, the ride seemed a bit stiffer than the stockers that were on before.
X- Forest Service, 1983 Cherokee 4 Door, 258, T-176, NP208, Dana 44, AMC 20, Stock.
"Jeep is America's only real sports car!" - Enzo Ferrari
Old 01-17-2009, 09:22 PM
Serious Johnson's Avatar
Voted for the Rancho 9000s, since those are the only ones on the list with wich I have much experience. I've liked them for their sensible compromise -- pretty good for towing, twist, pretty good for daily driving, twist,...
But, after 5 years & 25,000 miles, one of 'em is leaking and I can't seem to get any response on whether it'll be replaced under warranty. They don't make the same shock anymore for retail sale, so replacing them all would be **** pricey.
15-year-old Konis on my other car -- still good.
S.J.
"Carpe Mañana".
'83 Wagoneer
Old 01-18-2009, 09:00 AM
TPICherokee's Avatar
FYI, Pro Comp and Rancho shocks are made by the same company with the same warranty. So a Pro Comp ES9000 is basically the same as a Rancho5000 except Pro-Comps are valved a little softer.
I voted for the Bilstein 5100's.
Old 01-18-2009, 10:28 AM
Fiodh. Argus's Avatar
Fiodh. Argus Fiodh. Argus is offline
I have always wanted to install a set of Rancho 9000's with the remote in-dash adjustment system. Having more James Bond knobs is cool and I love the idea of firming it up for a winding asphalt road, then softening it for the dirt. I voted for the Ranchos even though they are the same as procomps.
Drew
77 Cherokee WT
Old 01-25-2009, 10:47 PM
John Huebner's Avatar
John Huebner John Huebner is offline
Have the RS5000's on my Waggy, the RS9000's on my YJ. With the Trailmaster (Read STIFF) springs on the YJ, I need one additional "softer" setting than the 9000's offer. The RS5000's are stiffer than I like on the waggy...I'll do the Bilstiens someday on it...
John Huebner
1989 GrandWag ~ Dino
1989 YJ Wrangler ~ The Mistress
Current Jeep Status:
Running!
Old 01-25-2009, 11:38 PM
Ron H's Avatar
Ron H Ron H is offline
I was running rs 9000's for awhile, worked awesome. I now run air shocks, since the onboard air, just because i can air up or down on the go. But the 9000 is a great shock.
Dude hang on watch this sh$t.
  1. 1979 waggy, chopped, and caged. 351W, C4 with shift kit. NP205/203 doubler 9" and HP44, 488's, 38" tsl's for now, will be doing Rockwells soon.
Old 01-26-2009, 08:41 AM
JeepinPete's Avatar
JeepinPete JeepinPete is offline
If you are stock height, Bilstein makes a specific shock for the Waggy. They handle and ride great. I am using 5100's on my SOA Cherokee, and am pretty happy with them. They are a little softer than the Waggy specific versions, but work very well.
Pete
Isuzu 6BD1, NV4500, NP241
Old 02-05-2009, 06:50 PM
sappy76's Avatar
sappy76 sappy76 is offline
Just got a set of these for the selectability. Ran Ranch 5000 and Skyjackers, both seemed to hard on the freeway but good offroad. It probably depends a lot on your springs, tires, and weight. The Skyjackers with the Skyjacker 4" softride and 33" tires bounced a lot on the road.
Old 05-03-2009, 12:55 AM
beloth's Avatar
beloth beloth is offline
well...
i am the cheap bastard i guess...i have checker auto's no name house brand...was told it is a monroe gas charged shock...got them all for $10.99 each new about 6 years ago when i got the jeep ...since we redid the springs in the back the back ones now have used RS5000 shocks...but never had a issue or complaint with them....
1966 wag "JENNY" w/1973 drivetrain
330K miles w/360 V8 2bbl (HEI installed ), flowmaster muffler
TH400 /Dana 20 transfer case D30 /D44 w/ 3.73's LT235/75/R15 AT tires. lift shackles in frt. 2 in lft; w/ TAD's Dozer bumpers! Cost $700 -now total cost=?
Old 05-03-2009, 01:07 AM
AnnieL's Avatar
AnnieL AnnieL is offline
I voted for Rancho 5000's because that's the only experience I've got & currently on my rig. Those were a replacement for the factory shocks-which were shot beyond belief!
I'm SO curious to see what type of difference I'll notice once my new lift is on.. (BJ's 4 inch)
~AnnieL ~
"I think, therefore I'm single.”
Director: Mojave Desert Animal Rescue
http://www.AnimalResQ.org
~'89 GW- "Harsh Mistress " BJ's 4 Inch Lift, 31" Bridgestone REVOS, Quick Disconnect Swaybars, Pro Comp shocks...and...crappy paint!
Old 05-03-2009, 04:51 AM
JERSEY JOE's Avatar
shocks
I have run the Rancho 5000's and did like the ride. Currently my J-20 has Monroe Gas Magnums and I am pleased with the ride. On the other Jeeps I and using the Edelbrock Extended Travels since they had a fire sale on them and they were priced right.
1987 J-20 401 90% COMPLETED.
1970 AMX CURRENT PROJECT
Old 05-03-2009, 02:38 PM
janie's Avatar
janie janie is offline
Dexron Impaired
As usual, I'm the oddball. Running DoetschTech's on the Honcho.
Old 05-07-2009, 08:12 AM
Chris P.'s Avatar
Chris P. Chris P. is offline
I'm still running the originals.
79 J10 Honcho 360/T-18/D20
Summit 8600 cam, GM TBI
78 Wagoneer 360/TH400/QT
Old 05-07-2009, 08:13 AM
jeeping1974's Avatar
Where is the option for no shocks?
03 GMC 2500HD - DD/toy hauler
06 Street Glide - Cruiser
Old 05-07-2009, 09:19 AM
stumpjumper3's Avatar
stumpjumper3 stumpjumper3 is offline
When i did my 4 in from BJ's i opted for the Rs9000's. I really like the adjustabiliy of them and they give it a very good for a lifted vehicle. i've got probally 10k on them since the lift and no leaking so far
1978 Cherokee, 4 in and 33s
Old 05-07-2009, 10:16 AM
mattmopar440's Avatar
I have a Bjs4" I like the ride of the ES3000 for a DD
87' Grand Wagoneer
80' J10 4BT/AX-15/208
74' J10 Go Grabber Green Sold
Inferior Chevy
Old 06-07-2009, 06:23 PM
bill4570 bill4570 is offline
I ran RS5000's on my stock height 77 Chero and loved them, but I really like the Bilstein 5100 series and plan on putting a set on my wife's Grand Cherokee to replace the RS5000's on it.
Old 11-02-2009, 11:49 AM
CHICOWAGGY's Avatar
CHICOWAGGY CHICOWAGGY is offline
What no Doetsch-tech or KYB on the list?
1990 Grand Wagoneer
Stock 360/727/229
Restoration in progress.
Old 11-02-2009, 12:17 PM
j20brett's Avatar
j20brett j20brett is offline
360 AMC
The 5100 series bilstiens are AWESOME! The price isnt, but you truly get what you pay for with them.
Build Thread
Fight Crime...Shoot Back.
ΜΟΛΩΝ ΛΑΒΕ
