Old 01-12-2008, 05:19 PM
Jodaddy Jodaddy is offline
Do I really need a 77 widetrack with a 454?
I found one for sale and the guy wants $1000 for it. The work is already done and I am going to need a tow rig in the near future for a 1500 mile move. I am pretty sure it has the original drivetrain: th400, QT 44's front and rear. The original owner swapped in the big block so he could tow his airstream a little easier. Will this engine just eat up the drivetrain or am I in the clear. What sort of mileage can I expect? It is a carb'd big block. thanks
Joe
Old 01-12-2008, 05:21 PM
wheelbase is a bit short for towing anything big. that 454 will decrease the life of the q/t chain i'm sure.
Old 01-12-2008, 05:33 PM
Rednex4x4s's Avatar
Rednex4x4s Rednex4x4s is offline
I would go for it if the work is already done then once you get to were you are going have the T-Case overhauled or get it done before you go.I myself would look for a 400 turbo with a 205 or 208 transfer and and ten make the move.the rest of the running gear will make it if you feal comfortable with it.If the T-case doesnt have alot of slop in it and the running gear is fairly tight Id go for it the 454 is worth the thousand on its own.Good luck.Oh and better throw in some new springs or someair assist in the rear to tow with it.
Old 01-12-2008, 06:06 PM
HOOT's Avatar
HOOT HOOT is offline
The Quadra-trac can handle the 454. It won't handle any hole shots but then again any engine hole shots will destroy a Quadra-trac.
It is a very nice case for automatic transmissions.
I'm sure the old racing J trucks(Baja) had a more powerful motor than a stock 454 in them.
<edit> To answer your question above... YES
Tom Gibson
1980 J20 Utility bed truck. Factory cab and chassis truck. Many new mods for it but it will look all stock.
1985 J10 nothing special just a nice clean stock truck.
2017 Challenger. Very jealous of the Jeeps.
Old 01-12-2008, 07:20 PM
Does anyone already run this type of setup?
Old 01-12-2008, 07:22 PM
billyrb's Avatar
billyrb billyrb is offline
BJ's Off-Road
There are a handful of folks running 454's, and they seem to be quite happy with them. As long as it's set up properly and not rigged together, it's a good engine for the heavy FSJ's.
Btw, to answer the question "Do I really need a 77 widetrack with a 454? "
The answer is "WELL, DUH!"
BJ's Off-Road
ryan@bjsoffroad.com
Old 01-12-2008, 07:23 PM
Dmntxn77's Avatar
Dmntxn77 Dmntxn77 is offline
Hey watch this...
Joe
To anwser your other question... YES, of course you NEED it!!
Old 01-12-2008, 07:38 PM
Dirtball's Avatar
Dirtball Dirtball is offline
Not only do you need it... but we NEED you to need it...
Paul
1979 Cherokee N/T
360/TH400/Qtrac/D44s/rear Lock-right
6 inch Hell Creek all spring lift
34x10.50 Super Swamper LTBs
http://i54.photobucket.com/albums/g1...t/100_1394.jpg
http://i54.photobucket.com/albums/g1...t/100_1390.jpg
http://i54.photobucket.com/albums/g1...100_1387-2.jpg
Old 01-13-2008, 06:59 AM
jeeping1974's Avatar
you are kidding right?
03 GMC 2500HD - DD/toy hauler
06 Street Glide - Cruiser
Old 01-13-2008, 09:21 AM
JeremySmith's Avatar
JeremySmith JeremySmith is offline
Thats like asking if I really need my Super Redhawk (44 mag with a 9" barrel). And for mileage, yes you can expect to get some.
1978 Cherokee Chief 360/T-18/D20
Midwest FSJ Gathering Website
Three out of four voices in my head thought it was a good idea.......
Old 01-13-2008, 09:49 AM
Rande's Avatar
Rande Rande is offline
Ph.D in Jeep B.S.
NEED has NOTHING to do with it. If you want it, buy it. Forget about any justification for it. You want it, get it. Simple.
N4ZYV
1966 Mustang
1937 IH D2
Old 01-13-2008, 10:21 AM
Crazy_Jeepman's Avatar
Sloppy Shifter
You don't need/want it....................................Where is it at?
