Old 05-08-2020, 12:25 PM
Riozilla Riozilla is offline
Question: how to wire Yellow & Green wires to new Coil (for HEI distributor upgrade)
I am in the midst of installing a CRT Performance HEI distributor and coil to replace my stock AMC ignition and distributor in my ‘88 Wagoneer.
My question to the group is how to best wire the original (2-prong) yellow/green hot starter ignition wires to the new coil?
I am learning and am new to automobile electrical, but have a wiring diagram and instructions. But am still wary of splicing open the original yellow and green wires and attaching them to coil until I know clearly how to best do that.
Thank you in advance for patience and help.
Old 05-08-2020, 05:24 PM
Cliff's Avatar
Cliff Cliff is offline
I had to look up CRT - had not heard of them. That looks like a bargain price, compared to Davis or MSD.
I have no info on the wiring, just wanted to comment on the dizzy. Let us know how it works.
Cliff Danley
1977 Cherokee S
Old 05-09-2020, 10:21 AM
Not sure what your question really is. Are you unsure of what color is positive or negative, or which type of connector to terminate the wires with? I'd ask the coil manufacturer I suppose.
Old 05-10-2020, 11:42 PM
FleetFox's Avatar
FleetFox FleetFox is offline
There are few write ups out there. Most people I have seen tie into the 2 prong plug from the motorcraft box. I think the wires are blue 12 gauge and an 8-10 red with a white tracer. Use the red w/ tracer as your power supply and run a like sized wire to the HEI. The second terminal on the HEI is a tach feed back to the cab.
Either way you need 12 volts switched to the HEI, 12 volts switch with NO interrupt in the start position for the key.
I wish i had a pic of the pigtail I'm talking about, but alas I don't.
Fleet Fox
Old 05-11-2020, 08:24 AM
You will not be wiring in a coil. HEI is a one wire wonder. The coil is built into the distributor cap.
who sells HEI conv is TFI better? drives mopars General FSJ Tech 29 03-12-2004 04:12 AM
Rather long post on Alternator Theory...some background Joe Guilbeau General FSJ Tech 12 06-08-2003 06:53 AM
ok. really POED now! ok, not no more. i am happy. CowKiller General FSJ Tech 105 02-10-2003 01:15 PM
ignition problems!...arrgh.....coil ..ballaster wire! mccullough_89_GW General FSJ Tech 3 07-05-2002 03:21 PM
Electric Question: 68Gladiator Starter Wires MaxJeep General FSJ Tech 1 02-24-2002 02:10 PM
