Old 04-13-2020, 03:31 AM
Heep-J4000's Avatar
Dana 20 transfer case behind Cummins diesel
I'm collecting parts for converting my 73 j4000 to 12 valve Cummins with nv4500 transmission.
Also going with dana 60 front and dana 70 rear axle.
Have most of the necessary parts
But now is my question ,is it wise to use the Dana 20 transfer case with this build?
The j4000 was my daily work truck for 13 years with 360 converted to LPG ,T15 with 20 transfer case.
It's going to be the daily work truck again after the conversion and overhaul.
The 12 valve Cummins engine is still a low miles stock engine , Probably want to upgrade a couple parts , but nothing crazy because want to keep it dependable!
Like to hear your ideas about this!
Cheers
Mees
Old 04-13-2020, 04:08 AM
It will not last, way to much torque from the Cummins, really should look for a heavier duty transfer case.
Old 04-13-2020, 05:38 AM
Mikel's Avatar
Mikel Mikel is offline
Why would you spend money bolting a D20 to a NV4500? Plenty of transfer cases at junkyards that will bolt to a NV4500 that are stronger.
1969 M715 6x6
1963 J300 Swivel frame
Old 04-13-2020, 06:10 AM
Heep-J4000's Avatar
Well I have a couple of D20 laying around.
And over here in Holland there are not so much of heavy truck parts to find on junkyards.
Old 04-13-2020, 06:15 AM
Heep-J4000's Avatar
So what is a good one to use?
It needs to be with a passenger side front output for the Dana 60 front axle.
Could a Dana 300 be a option?
Have also one of that in the barn.
Old 04-13-2020, 10:55 AM
Mikel's Avatar
The transfer case that originally came with your NV4500 could be a good candidate, if the output is on the right side.
1969 M715 6x6
Old 04-13-2020, 12:27 PM
Heep-J4000's Avatar
There was no transfer case included with the transmission.
Old 04-13-2020, 06:18 PM
bufurd's Avatar
bufurd bufurd is offline
My take is run it if you can get it adapted reasonably enough. You have a spare once you know its limits, I run one behind a very healthy 1969 GTO 400 engine for near 20 years, T-case was never an issue and I cut it no slack, truck pulls, mud bogs, lots of wheelin, etc.
Current fleet
07 JK Wife bought new...
Old 04-14-2020, 04:27 AM
241d out of mid 80's dodge trucks or a chevy 241c mid to late 80's, both where p.s. drop.
Old 04-14-2020, 10:59 AM
Heep-J4000's Avatar
Thanks for the suggestion!
Anyone experience with a np205 ?
They also came in the dodge and Chevrolet trucks
Old 04-14-2020, 05:06 PM
bufurd's Avatar
205 is a great T-case, bullit proof and easy to put behind a NV4500. On that 4500, do something real with the 5th gear issue and use the right oil.
Current fleet
Old 04-15-2020, 10:49 AM
Heep-J4000's Avatar
It's a complete new transmission with all the latest updates from Allstate gear.
So I expect and hoped that is also done!
Old 04-22-2020, 08:51 PM
The adapter required to bolt a Dana 20 to a NV4500 is expensive and still requires you to chop a good portion of the transmission's tailshaft off and use a "spud" shaft or "power sleeve". I'm doing this same swap. Just find an NP205 and be done with it.
-Jonny B.
AMC 401 - Pro-FLo 4 FI
F D44 - 4.10, Eaton E-Locker
R M23 - 4.10, Detroit Locker
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
Old 04-26-2020, 05:19 AM
Heep-J4000's Avatar
Yes I did came to the conclusion that going for a np205 is the better option.
So started looking for one over here (probably going to get one from the US , because in Holland there is only junk or they don't know what they have and asking to much.
Thanks for all your input about this!
Cheers
Transfer Case Questions Thomas792 General FSJ Tech 10 12-20-2007 05:27 PM
NP229 Transfer Case Leak - What Sealant to Use? Kevin718 General FSJ Tech 12 08-15-2006 06:45 PM
Transfer Case cracked driving to work today vistalite General FSJ Tech 5 04-21-2005 09:54 AM
Transfer Case Replacement because of Vibrations. Red's FSJ General FSJ Tech 1 07-27-2002 06:59 AM
