Old 02-21-2020, 11:06 PM
JTD's Avatar
JTD JTD is offline
Experiencing binding in the front after installing lift kit
Last weekend, I installed a 3" lift kit in my 79 Wagoneer. Replacement springs and shocks in the front. I'm now experiencing some "binding" if you will, in the front end when I turn. I didn't think a 3" lift would put any undo stress on anything. It ALMOST feels like it would if the 4x4 was locked in, but not nearly that extreme. Really the only things under extra stress I think would be the stock sway bar links. Technically they are being pulled down an extra 3" now. Anyone have any thoughts for insights?
Old 02-22-2020, 06:50 PM
bufurd's Avatar
bufurd bufurd is offline
Well.. Kinda tuff to say. Having lifted a few Jeeps, 3" sure shouldn't cause any problems. The sway bar end links shouldn't care about the new position as long as nothing is rubbing. I think I'd put it on jack stands (under the axle) and steer it lock to lock to see if anything looks not right and nothing is rubbing.
Current fleet
07 JK Wife bought new...
Old 02-22-2020, 07:43 PM
JTD's Avatar
JTD JTD is offline
Since I posted this morning, I removed my front drive shaft and it turns out the double cardan joint at the T-case seems to be catching as I pivot it around. The more extreme the pivot, the worse it gets caught up. Adding the 3" lift changed the angle enough, it reared it's ugly head. I put the Jeep in E-drive and took it for a spin without the front drive shaft. No binding on turns.
Installing 6" lift! jwalton23 Off-Road FSJ Tech 63 12-24-2011 12:19 PM
4" lift Chevy springs up front wickedwagon767 Off-Road FSJ Tech 7 08-20-2009 05:51 PM
Need Advice....Installing 3" Lift LonghornJ10 General FSJ Tech 1 03-13-2007 05:29 PM
Installing front lift springs question Allen78J20 Off-Road FSJ Tech 3 07-28-2003 04:14 AM
Front Shackle lift? Treadted2 General FSJ Tech 16 02-08-2001 09:32 AM
