Old 06-07-2019, 03:14 PM
Tripwire's Avatar
Tripwire Tripwire is offline
anyone here into 3d printing?
I feel the need to rid myself of some troublesome extra cash i happen to have lying around.......
I think i would like to dabble in 3D printing for making widgits and small replacement plastic parts. I think i want to spend about 500 bucks for a starter printer, i would like one that is dependable and can use any brand filament. some sort of included autocad software would be bonus. I looked on amazon and cant wrap my head around the reviews.
what are "must haves" when looking at printers - and is there a good forum out there for newbies?
Any suggestions?
Steve
Abort? Retry? Ignore? >
Old 06-08-2019, 08:43 PM
I haven't bought a printer, but did figure out how to turn an MRI of my shoulder when I needed surgery into a 3D printable file. Sent it to these guys: https://www.shapeways.com/
Was like $80 and now I have a high resolution model of my actual bones on my desk. It's kind of neat - could see where the actual break was. Also, the centers of the bones are hollow where the marrow is. Pretty weird!
1984 GW
360
Comp 260H
Magnum Roller Rockers
Wiseco -21cc Forged Pistons
Performer Intake
Holley SA 670
MSD 8523
Dakota Digital custom cluster
Serehill headlamp harness
NWMP aux tank
1987 GW deceased
...but the parts live on
Old 06-12-2019, 03:47 PM
Jenga77's Avatar
Jenga77 Jenga77 is offline
I'm not an expert on 3d printing, but I've thought about getting into it too.
From my understanding most printers have their own software (typically proprietary) which takes the 3D model (usually in a generic format like .stl, .x_t, or .step) and uses it to set up the machine parameters and generate the code to run the machine. To make your own 3D models you'll need CAD software and the know how to use it, otherwise you're stuck downloading models or having someone else create them for you. There are some free online CAD systems (like Onshape.com) but I'm not sure if they let you download to .stl or another format for use in the printing software. Professional CAD software is way too expensive for hobbyists.
There's also a lot of considerations in exporting / importing your model (like with the resolution of the solid mesh, stress points in the design) and with its positioning on the print bed (like the grain of the print, where the scaffolding needs to be, etc.) which can get really technical. In a lot of cases you have to tailor the design to be 3D printed (sometimes over / undersizing certain features, no threads, etc.). When you're starting out I don't think that's a major concern though.
As far as the actual physical printer I'd think about the largest part you want to make and get a printer with that size of print area. The larger the area the more it's going to cost.
I'd also look for one with a full frame (U-shaped top bar) rather than the single stick type since there's a big difference in the stability of the printer head, and therefore the quality of the printed part.
The bed type is another consideration which should be chosen to match the material and part size you're printing.
I also would only ever get a printer with some kind of recovery built in for if there's a power interruption. On a larger and more complicated part the print time can be on the order of days, so I wouldn't want to have to scrap a part because of a power blip.
Not an endorsement, but this is the one I'm pretty close to buying: https://www.creality3donline.com/off...ter_p0117.html
Once you're set up you can join an online group where people can send you models and pay you to print them for them, which is pretty sweet. Not sure if it would be profitable for you though!
77 J10 - 360, T18, Dana 20, J20 Axles - Work in Progress!
Old 06-12-2019, 04:05 PM
SOLSAKS's Avatar
SOLSAKS SOLSAKS is offline
I don't know anything about 3d
but I do know EPSON always gives a Big Bang for the buck
( if they make 3d printers )
good luck.
if any more troublesome cash Is found
send some to me, to put into this 76 j10 I am working on.
dave in NC
Old 06-12-2019, 09:39 PM
men in black's Avatar
Check out this FB group
https://www.facebook.com/groups/Crea...?ref=bookmarks
This is the printer I bought, have been too busy with the CNC to play with it.
Here's a link to a site that you can download a lot of cool stuff that is already to print
https://www.thingiverse.com/
Once you get your printer you will have to tweak it in. Also learn some software like Cura.
https://ultimaker.com/en/products/ul...-cura-software
Do you have a makers space in your city or near by? We have Factory Two in Flint,Mi. Which has four 3D printer and CNC and Laser cuttter.
If you join the space you can use the equipment.
Look under reservations to see all the equipment they have.
Here's the link https://factorytwo.org/en
Old 06-13-2019, 07:05 AM
2ToneBluJ10's Avatar
2ToneBluJ10 2ToneBluJ10 is offline
I have 4. The learning curve for these never ends. Each different material has it's own learning curve. Automotive materials would be PETG or ABS not PLA it can't take the interior temps and wilts. These aren't at the set and forget it level yet like 2D printers are. The parts that these make are not as strong as injection molded parts because of being made in layers.
I my honest opinion the best beginner 3d printer is the Monoprice Select Mini V2, less than $200 sometimes cheaper, 120mm cubic build volume, can do PETG and ABS with some machine mods.
Use the free open source solid modeling software like OpenScad or Tinkercad to model parts with and the slicer software that comes with printer to generate the g-code for the printer. Engineering background helps.
It's a hobby for me.
Dave
The few. The proud. The browless.
Somewhere between prissy and pristene
End Caps for J10 Stepside Rear Bumper ESikes533 General FSJ Discussion 19 03-14-2015 11:38 AM
Anyone explore 3d printing of parts? zbethem General FSJ Discussion 5 09-26-2013 08:46 AM
Preserve/Restore: The making of a Hitch-Sticker Crist Clapper General FSJ Discussion 51 10-14-2011 02:51 PM
Printing Keys from JEEP Dealership with VIN, getting key code temps425 General FSJ Discussion 11 07-16-2011 03:58 AM
