Old 07-13-2018, 08:14 AM
JoggerFogger JoggerFogger is offline
Mice in my headliner
I'm so mad.
I'm finally putting the windshield in my Wagoneer and realized that the little mouse poops I found are not 20 years old. I could hear the little demon running around up there. When I tried to scare him out by tapping on the headliner I could hear all his poops bouncing around and I realized where that rat smell has been coming from.
What really makes me angry is the headliner is perfect. 47 year old rig, and it looks brand new. Now I'm going to remove it, probably screw it up, and it will never look so good again. Furthermore, I don't even know if I can get the mouse piss smell out of it.
This is a 1972 Wagoneer, and it has a bow mounted headliner. Any advice on how to attack this is appreciated. Any advice on how to keep this little devil worshiper from coming back is also appreciated.
-Kevin
1972 Wagoneer > Isuzu 4BD1t > 4L80E > D300 > D44
www.civilrock.com/72-Wagoneer
Old 07-13-2018, 08:22 AM
SOLSAKS's Avatar
SOLSAKS SOLSAKS is offline
dang, i sympathize with you.
wish i could offer precise help,
i know the bow/suspended headliners have metal bows in them.
i had to have a friend install mine in a 69 charger
if you know an old timer
or someone experienced with the bow type headliner
they can prob. remove and re install without damage
if material and thread are not brittle.
as for keeping the mice out, hard to stop them.
they can get in almost anywhere.
good luck.
dave in NC
Old 07-13-2018, 09:44 AM
SJTD SJTD is offline
You've got a real problem. There's no holes in it so you know he came up through one of the pillars so while you're taking out the headliner he's going to hide out somewhere. Need to trap it. Don't want it to die in there somewhere.
I opened the hood of my Dodge to find three big mice in the hood liner that was now laying on the engine. Removed it and flushed everything. Seemed to be gone but then a few weeks later there was "wetness" under the air cleaner. Out came the hose again. This time they were down between the wheel well and the firewall.
A while later I saw her running across the driveway carrying one in her mouth with another hanging on. Finally we cornered them between a garden shed and block wall. Herded them into a bucket and took them down to the wash. Maybe they won't come back.
Gotta get another coyote dinner, er, I mean cat.
Sic friatur crustulum
Old 07-13-2018, 09:53 AM
peanut butter on an old school mousetrap gets them every time.
little bastards love peanut butter
Old 07-13-2018, 10:33 AM
Before tearing out the headliner I'd try setting traps for awhile till you don't get anymore in the traps. Maybe liberally spray Febreeze on the headliner for the smell? On stored or infrequent use rigs even motorcycles I've had issues with mice eating the wiring insulation. I lay moth balls on/around the motor. Don't know if it really works or it was just a coinkydink but haven't had any wire chewing issues for years. Prolly not a good idea for the interior if you have kids that like to put things in their mouths.
Good luck.
Old 07-13-2018, 12:43 PM
BBBWWWAAHAHAHHAHAHAHAHA!!!!
LOLOLOL!!!!!!!
79 Cherokee Chief
Old 07-13-2018, 12:46 PM
I'm gonna throw this out there, too. After you take everyone else's advice and set traps and get rid of the little bastard find a nice steep incline and get the front of your jeep as high as possible and tap and your headliner so all his turds find their way aft. You might be able to get them to bounce down the sides into your wheel wells where you can vacuum them out.
I've never done this but have thought of it.
79 Cherokee Chief
Old 07-13-2018, 12:52 PM
letank's Avatar
letank letank is offline
sadly, been there... the little buggers have probably built a nice nest in your headliner, hence the pee smell and the poop trails... I had to dump a decent headliner years ago.
As for mouse control, mint oil on cotton balls is a very good start
I do not know how to remove the early style headliner, but a quick search for the early style
http://www.ifsja.org/forums/vb/showthread.php?t=14228
from Tad
At thier age they are not coming down in one piece, sorry.
It will rip/tear and generally fall apart everywhere.
Trash it, buy/get the headliner holder trim from a newer model and they will go right in with some light duty hole drilling.
I have a combo 76/83/85 headliner in the 70 wag.
Hardest part is the center holder for the visors.
One interesting note on the older roofs (and I have seen a lot of roofs installing these racks) is they were not painted prior to the factory insulation. They glued some fiber looking crap up there and painted over it, bare metal under it (go figure).
Took me 2 days of sanding with a respirator and shop vac to get the rust off the inside and repaint it. Took me about a hour to reinsulate the roof once it was dry.
Al, if you do switch headliner types, grab everything, side strips, front and rear strips, the 4 corner pieces, visors, center holder piece and visor cups, the headliner and most importantly the trim strip that spans the 2 pieces of cardboard headliner. I still need to pull mine back down and recover it to match the interior someday.
END of Tad posts
Michel
Old 07-13-2018, 01:50 PM
Thanks for all the suggestions.
I just started in. Once I started sticking my nose up along the edges, there's no way I'm getting that smell out without some serious surgery.
This is where I was when I realized that there was a live mouse in the headliner. I could hear him running around.
Pulled the rear glass guide out first to undo the glued rear end of the headliner.
That got me to here. A little nesting material on the right. it's insulation the little rodent scraped from the roof.
If you've ever wanted to know what the clips look like in a 72, here they are. The ends are screwed in, the rest have these little twist lock clips.
Old 07-13-2018, 02:01 PM
Taking pics so I can re-assemble. You guys like pictures right?
Here's the little twist clips. They hold really well. I was hesitant to really turn them for fear of breaking them, but it takes some good grip.
Other than the mice piss and turds, it's in really good shape.
Ok, now I've got to a nest. Shop vac handy to eliminate before I make a mess.
More clips, more vacuuming, and the piss smell is getting strong.
I was so disgusted I didn't take any more pictures.
I figured water isn't going to hurt. My thought is soaking, then out in the sun to dry. Maybe repeat.
This is where the urine smell is the strongest. Right above the front passenger. Right where my wife is going to ride. She'd never notice that smell...
I'm going to let it bake in the sun. While it's drying, I'm going to get some vinegar and fabreeze. A quick google search says 1/2 Vinegar, 1/2 Water, soak for 10 min.
Maybe I'll hit it with a nylon brush in the worst areas.
Old 07-13-2018, 02:04 PM
when I get the vinegar, I'm going to get 12 mouse traps. 3 around each wheel with peanut butter lure.
-Kevin
Old 07-13-2018, 02:07 PM
I so hope you can save that headliner!
79 Cherokee Chief
Old 07-13-2018, 02:22 PM
That insulation kinda looks like asbestos from here.
Old 07-13-2018, 06:00 PM
Great.
mice turds all over me.
asbestos in my lungs.
I'm sure to die.
I set 12 traps with peanut butter. One behind each tire, one behind each door, and the rest along the wall next to the Jeep.
I bought "Nature's Miracle" because it had a satisfaction guarantee. I also bought vinegar, with no guarantee. I pulled the liner out of the sun and super soaked the stains, and wet the whole thing with the bottle.
After 10 min I couldn't smell any pee. Although my nose might be too tolerant right now. I'll see if I get any dead mice on Monday, and if the liner smells better after a weekend in fresh air.
-Kevin
Old 07-13-2018, 10:55 PM
Read up on hantavirus if you really want to worry. Idunno if it's up there.
Old 07-13-2018, 11:50 PM
Kaiserjeeps's Avatar
Just reading through all this thinking about hantavirus. There is no cure. A lot of people die from it. I keep hearing about it down south and up here in Washington state. I live in the woods and have terrible issues with deer mice. They are the main carriers. Brown fur with tan underbelly's and big ears like a deer. Bleach spray is the best way to kill the virus by spraying the poop and where they have been without disturbing it. Soak it then wipe it up with paper towels wet. Vacuum's and brooms get it air borne and that is how you breathe it in. If you get flu like symptoms in a week or so, get your butt to a hospital and inform them about your mice contact. Glad SJTD said something. If it was a gray mouse, chances are you will be fine and it was just a dirty job.
I know the headliner is out, washed and drying. Just pay attention to your health in the coming weeks. And for stubborn odors I have an ozone generator that is extremely effective with smells, cigarettes, mice, mold etc. For anybody else with a smell problem in their Jeeps. Try to find a rental ozone generator. They work like a charm.
Please post the install as I am about to sew a new one up and need to install it before the front glass goes in. I am interested in any tips or tricks.
Am I done yet?
Holy Moly, I am done.....
1969 1414X Wag,
71 project J truck FOR SALE
1970 Wagoneer Not Sadie
1983 FJ60 wagon
CJ-5's
Old 07-14-2018, 12:40 AM
Yup, googled it and got a little paranoid. Not much to do now but watch for symptoms. I'll hopefully know what kind of mouse soon with one dead in a trap.
When I pulled the headliner, I could smell it from 15 ft away. So could guys at my shop. It was pungent. After 2 rinsings, and 2 treatments of nature's miracle, I put my nose right in the worst spot stain and all I could smell was canvas and cleaner.
As long as I don't tear the hell out of it putting it back in, I'm feeling pretty confident in the treatment. That is if I don't die from mouse turds.
Old 07-14-2018, 01:22 AM
Originally Posted by JoggerFogger
... That is if I don't die from mouse turds.
HAHAHAHAHAHA!! Killer mouse turds!!! LOL!!!
79 Cherokee Chief
Old 07-15-2018, 06:12 PM
letank's Avatar
check your quarter panel as well
here we go
Michel
Old 07-16-2018, 09:41 AM
Mice like peanut butter.
So I show up this morning and B-line to the Jeep.
I look inside and see all the peanut butter eaten off the traps.
I'm not going to bore you with 8 more pictures of set traps with peanut butter eaten off the trap. Its funny because pain is the heart of humor.
-Kevin
Headliner Board ngasman General FSJ Tech 8 06-30-2016 03:17 PM
Replacing Headliner questions? 87 FSJ Frank G General FSJ Discussion 2 09-14-2011 08:20 PM
Honcho headliner color ? Honchov8 General FSJ Discussion 2 07-26-2010 04:43 PM
Headliner Replacement (Lotsa Pics) chuckchili General FSJ Tech 13 03-19-2009 06:58 PM
Wagoneer Headliner Pattern/Template Symer Salient General FSJ Tech 6 03-15-2005 07:15 AM
