Old 08-01-2016, 07:25 PM
Rocket2314 Rocket2314 is offline
Noob!
Gas Tank Leaking I think...
So still trying to get my J10 to run. First the fuel pump when out, so changed that. Then wasn't getting gas to carb. I knew the fuel gauge never read accurately so I thought maybe I remembered there being more gas in the tank than there is. So, tonight I went and got 15 gallons and started to fill it up. I got maybe 9 gallons in and I start hearing dripping. I look under the truck and out is coming fuel through a rust hole in the skid plate under the tank. So I stuck a bucket underneath fearing the worst and watched until it stopped. There's only maybe 1 gallon in the bucket. So, there's still whatever fuel was in the tank plus roughly 8 but I have fuel that leaked out from an unknown location. Anybody have any clue what I do next besides tow it to the mechanic and have them drop the tank and replace it.
***Update, tried to start the truck again. It starts with gas poured in the carb but dies when it runs out. Still no fuel to the clear filter. I can't imagine by now the new fuel pump isn't primed. Also, when I started the truck up the gas gauge now reads full and when I send a tube down into the gas tank I hit fuel right away so I'm definitely full. Why would gas leak out over I'm assuming the top of the tank and through the rust hole on the skid plate? And what in the world is blocking it from getting through the lines? I've looked at all the lines and they look fine. I actually think upon further inspection that they may have been changed prior to my aquisition of the vehicle. Mind you, this truck ran fine up until a few months ago when I couldn't get it to start. Tracked the issue (or so I thought) to a bad fuel pump. The diaphragm was actually ruptured so I was sure this was my problem. Anybody who has some knowledge of this kind of problem...please help!
1982 J10 Rust Bucket
Old 08-02-2016, 08:00 AM
I'm no mechanic but I'll shoot.
Test fuel pump by taking the hose after the pump and put into clear pop bottle. Crank motor once or twice and see if fuel squirts onto bottle. If it does then clog is after fuel pump. If it's weak or nothing then it's fuel pump or before it.
Pull the hose between fuel pump and tank and blow through it to see if it's clogged. Also a good idea to put a paper towel to sift the gas that comes out of the lines to see if there's a lot of debris. Check the fuel filter again. Take it off and blow backwards through it onto a paper towel again to see if there's a lot of debris. Cloud be uber rust in tank that's clogging things up.
Fuel sending unit may be clogged or the sock on the end of it. Again pull it out and blow backwards to see if any crap comes out onto clean paper towel.
Tank may have a hole but unlikely, more like a hose leak somewhere.
Good luck, have fun.
Old 08-02-2016, 01:47 PM
2ToneBluJ10's Avatar
2ToneBluJ10 2ToneBluJ10 is offline
http://www.ifsja.org/forums/vb/showthread.php?t=179981
These tanks develop cracks on top and leak.
Dave
The few. The proud. The browless.
Somewhere between prissy and pristene
Old 08-02-2016, 04:12 PM
Gulrok's Avatar
Gulrok Gulrok is offline
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Actually seems to work to repair it. I did it to my tank. I had a leak still after I used a polyethylene rod. I couldn't physically see it; and it held water.. but it wouldn't hold gas. My guesss is that there was a micro-hole somewhere. It was only drips.
So I applied the epoxy from above - and it seems to hold onto polyethylene just fine. No leaks from gas yet. ( Has only been about a week since I've applied the repair. )
1983 Jeep J10, 8ft bed, Townside - 258cu - Weber 32/36 - Nuttered
So the mechanic said, "it looks like you blew a seal" and I said, "you leave my sexual preferences out of this".
Old 08-02-2016, 07:01 PM
Noob!
Tank issues
Does anyone know if the fuel sending unit can be accessed on the J10's without dropping the tank?
Old 08-03-2016, 07:57 AM
It can be. It is on the front side of the tank.
Dave
Old 08-03-2016, 08:45 AM
Ya know, it depends on what you mean by "access." You can see it and touch it, but I believe the sender will not come out unless you drop the tank.
It's no big deal to drop the tank if it's empty. Some work, but it's not hard. You may need to move the driveshaft aside. Siphon out all the gas so it's not heavy.
Old 08-03-2016, 09:02 PM
jpcoutts's Avatar
jpcoutts jpcoutts is offline
I had to drop the tank to replace the sending unit on my '86. The hardest part was getting the filler hose and other lines loose. Just don't mess up your filler hose, they are hard to come by. Yours is different from mine due to a change in the fill location in '85 or '86. Here's a link with some photos:
http://www.ifsja.org/forums/vb/showt...hlight=sending
Jim C
'67 J3000 Dually
'86 J20
'79 CJ5(in pieces)
Winter Boredome Waggy Project Log (Pic Heavy) Dr. Marneaus General FSJ Tech 102 09-24-2012 11:44 AM
A little help with BJ's fuel tank pablo_max General FSJ Tech 36 12-15-2009 11:51 AM
Gas Tank and Filter Sock Woes The PIG Smith General FSJ Tech 13 06-16-2008 10:09 AM
bringing back the FI fuel tank ideas... AlsChopShop General FSJ Tech 12 09-19-2007 12:12 AM
That leakin gas tank noah's big truck General FSJ Tech 11 04-02-2002 01:38 PM
