Old 06-24-2016, 06:21 PM
Gulrok's Avatar
Gulrok Gulrok is offline
Gas Tank Massive Leak?
Hey guys,
So first time completely filling the gas tank - usually I would just put 10-20$ in it but today I was feeling good. - The old hoses were bad so I didn't trust it being full... before.
Anyway - it fills all the way, and ends up leaking out the tank. I had just installed new fill and vent hoses today.
So gas started pouring out of the tank - and it took awhile until it stopped.
I'm wondering if anyone had a similar experience of their gas tank leaking bad.
I checked if the fuel sending unit was leaking, and it wasn't.. and I checked if the new vent /fill hose was leaking but they were not leaking either.
1983 Jeep J10, 8ft bed, Townside - 258cu - Weber 32/36 - Nuttered
So the mechanic said, "it looks like you blew a seal" and I said, "you leave my sexual preferences out of this".
Old 06-25-2016, 02:37 PM
2ToneBluJ10's Avatar
2ToneBluJ10 2ToneBluJ10 is offline
Your tank is cracked on top. It's a common problem with the polyethylene (HDPE) tanks on last generation J trucks. I had the same issue.
I have heard of them being repaired by plastic welding polyethylene rod over the crack. It's tough to do but can be done. Fuel fumes must be evacuated before attempting the repair and the tank straps must not be over tightened on the re-install.
Until then don't fill the tank past 3/4.
Dave
The few. The proud. The browless.
Somewhere between prissy and pristene
Fuel tank, fuel pump, fuel pickup for tbi TexasJ10 Fuel Injection 14 03-19-2013 05:53 PM
73 Wag fuel tank leak...vent? (pic included) shiner2001 General FSJ Tech 7 08-09-2012 11:04 AM
Rear Gas Tank Options JeepinPete General FSJ Tech 93 05-21-2012 10:23 PM
gas tank leak mudslider General FSJ Tech 9 07-05-2005 12:04 PM
Gas tank (primary) leak/no-leak Jeephopper General FSJ Tech 2 04-26-2004 11:01 AM
