Old 02-11-2010, 03:13 PM
imiceman44 imiceman44 is offline
How do you recognize a 401 visually?
I am going to check out a Cherk chief WT and the VIN says 401.
I need to verify that before I buy.
Does it have the dsplacement cast on the side like some other engines I know?
or is there other obvious signs like location of dizzy or oil fill or something?
Thanks in advance, and by the way I did try searching in every way I know and didn't find a thread about this.
IceMan
Old 02-11-2010, 03:15 PM
tkiller13 tkiller13 is offline
It will say 401 on the block. Near the bottom on the side.
Old 02-11-2010, 03:16 PM
Elliott's Avatar
Elliott Elliott is offline
Cowboy Up
Look under the engine mounting brackets where they bolt to the block. It will give the casting number there in numbers about 2" tall. If it has no numbers it was a service block and could be any bore.
Old 02-11-2010, 03:38 PM
janie's Avatar
janie janie is offline
Dexron Impaired
Chris and Elliott make it sound to easy. Here's the real version:
Put on the nastiest coverall's you can find. Grab a putty knife. Climb underneath and start scraping away all the goo, crud, grime and rust.
I promise you will eventually find those 3 golden numbers.
Old 02-11-2010, 03:44 PM
grand_wag_85's Avatar
Murphy's Law Poster Child
Look at where the motor mount bolts to the block
EDIT:
A big 4BBL and an air cleaner that says 401 on the yellow sticker should also say "Hey I'm a 401" but then again those parts can be swapped, only real easy way to tell is to climb up underneath.
'65 J2000
Old 02-11-2010, 03:47 PM
mdill's Avatar
mdill mdill is offline
Gone. Not Forgotten.
I think the no-number ones were the race blocks, that could be built anywhere from 5.0 -> 401+ depending on class rules, not many of those left, and those that are mostly have been run/punched out to where they are for the most part a who cares block, as you and I ain't goin to see one, much less care.
Mike D.
Old 02-11-2010, 03:50 PM
Mike D.
Weren't those ones also painted red instead of the AMC teal?
'65 J2000
Old 02-11-2010, 04:34 PM
thanks all for the replies.
It is as I guessed then.
Well wish me luck, it's a runner but supposedly is missing some smog stuff so can't pass a visual.
Well I know how to take care of that
IceMan
Old 02-11-2010, 04:44 PM
'72 California engines were red. Service short blocks (and complete engines?) were black, as I recall... I don't remember seeing a service bare block in the day.
Old 02-11-2010, 04:50 PM
Mike D.
The no number ones were factory replacement motors.
Old 02-11-2010, 04:54 PM
If you are upside down it looks like this:
Sean, looks like yours had a leak...
Old 02-11-2010, 04:58 PM
Tatsadasayago's Avatar
Tatsadasayago Tatsadasayago is offline
Brother had a no number block that came from the factory as a warrantee engine.
Jim
KY7DX/6
76 401 Wagoneer *The Gag-O-Neer*
77 360 W/T Cherokee Chief *Blair Jeep Project III* http://www.ifsja.org/forums/vb/showthread.php?t=113707
Sacramento, CA USA
Old 02-11-2010, 05:15 PM
Just a little bit
'65 J2000
Old 02-11-2010, 05:23 PM
turtlejoe's Avatar
turtlejoe turtlejoe is offline
I don't know about all that casting number and motor mount stuff. If it isn't located in SW Colorado and Flint and/or Krista aren't watching over your every move, it ain't a real 401.
Kerry - Raised by Jeep
"Got Altitude?"
"Trigger"
'78 Cherokee Chief WT 33X12.50 BFG A/T's, 15X8 Rockcrawlers, 4" BDS lift, TFI, NOS QT, TH400
"Sherman"
1993 4.0L Grand Cherokee, 44HD rear, 4:10's
"Roxie"
2004 Rubicon
"Moose"
2000 Ford Expedition XLT with 4.6L
Old 02-11-2010, 06:57 PM
janie's Avatar
Dexron Impaired
Doing cartwheels in your rig again Flint?
Old 02-11-2010, 08:55 PM
Elliott's Avatar
Cowboy Up
Putty knife is good, ifn it don't look like this...
Old 02-11-2010, 09:23 PM
That's a cool pic Elliot. I'm guessing the casting #'s were graffed onto the block after they were cast?
'65 J2000
Old 02-12-2010, 07:21 AM
Elliott's Avatar
Cowboy Up
the #s are part of the casting
Old 02-12-2010, 07:34 AM
That is a purty color on yours Elliott.
shades of 401s...
Old 02-12-2010, 08:03 AM
710 Burner's Avatar
Now we know why Janie squints on one side. Try safety glasses.
Mark B. Jones
