View Poll Results: Does your electric rear window work 100% all the time
Yes 507 58.28%
No 363 41.72%
Voters: 870. You may not vote on this poll
Old 01-01-2008, 01:01 PM
tkiller13 tkiller13 is offline
My 78 works perfect 100% of the time. I do think it is kinda of a pain to have the keys every time you want to roll it down. Anybody run a hot switch to the back so keys are not needed?
Old 01-01-2008, 01:30 PM
Wagonforever's Avatar
Wagonforever Wagonforever is offline
Not sure about the older ones, but the 86-91's have a switch right on the dash. So you don't need a key.
There are those that have and those that will.
1986 Grand Wagoneer, BONE STOCK just the way I like em!
The Aviation Forum
Fred 08
Old 01-01-2008, 01:41 PM
mine has the dash switch. I still have to have a key to turn accessories on.
Old 01-01-2008, 02:26 PM
mattmopar440's Avatar
the window works fine the window wiper dosen't the motors cooked
Oh yeah, I still have to do that too. Guess it would be kinda nice to just run that dash switch to be on all the time. Though I always either have the Jeep locked or have it running so I have to use the keys to get into it anyway.
The Aviation Forum
Fred 08
Old 01-01-2008, 02:50 PM
Jeepsmith's Avatar
Jeepsmith Jeepsmith is offline
Mine works great, but I'm worried about the wires that go from the gate to the body. Does anybody know where to find a new sleeve for those wires?
1983 Cherokee Pioneer
1988 Grand Wagoneer
Old 01-01-2008, 05:02 PM
Don't know where you can find a new sleeve, but I just wrapped them really well with electrical tape in that area on my 90. They weren't chafed through, but I had the same concern.
The Aviation Forum
Fred 08
Old 01-01-2008, 07:02 PM
JeremySmith's Avatar
JeremySmith JeremySmith is offline
Mine has a momentary contact toggle in the back right about the interior panel on the drivers side. When it works, I usually roll it down 6-8" from the dash, then use the back switch to raise and lower it the rest of the way, that way I can help it along if needed. It was there when I bought the truck, so I don't know how it was hacked, but it does work.
1978 Cherokee Chief 360/T-18/D20
Midwest FSJ Gathering Website
Three out of four voices in my head thought it was a good idea.......
Old 01-01-2008, 07:12 PM
letank's Avatar
letank letank is online now
74 is flawless..... knock on tailgate.... the OE channel busted last spring... but it was still working for Moab... a bit cockeyed.....fixed now.... a few years ago.... the (+) wire was totally oxidized (green powder)replaced the bullet plug... and of course 20 years ago the safety switch was discarded....
on the other hand the 85 opens from inside switch, but outside switch only for closing the window.....
Old 01-01-2008, 08:00 PM
misfittom138's Avatar
misfittom138 misfittom138 is offline
Mine works. For now.
81 Wagoneer 360/727/208, lockrite rear/welded front,4.10s, 7"SOA/shackle flip,3" body,OBA,37" Iroks,chopped,caged,highsteer,hydro assist....
Old 01-01-2008, 09:03 PM
Bobbo's Avatar
Bobbo Bobbo is offline
It always worked on my 84, but I just sold it. Maybe I was a little low on the price seems I had a rare bird there
78 Cherokee WT with a 4" BJ's system 401/TH400/half of a QT and 35/13.50-15 Toyo MTs
Old 01-01-2008, 10:19 PM
phatmax95's Avatar
phatmax95 phatmax95 is offline
Originally Posted by andy d
uhmn, could you please 'splain how that crank thingy works?
I welded that rod directly to the gear. And the wire is the lock.
Old 01-01-2008, 11:11 PM
Strider
Posts: n/a
At the risk of cursing myself, mine works from the dash and the rear lock.
Old 01-01-2008, 11:17 PM
DieselSJ's Avatar
DieselSJ DieselSJ is offline
Get underneath and unplug all the wires and slip a piece of heavy shrink tubing over it. Working from underneath was much easier than disconnecting everything inside the tailgate.
Oh, my window works perfectly...as long as I plug it into an external power source.
-87 Grand, 6.5L diesel, MHI TE06H turbo, Water/air intercooler, Art Carr 700R4, CS-130, hydroboost. 21/24mpg, dead 229 [Custom 242 on the way]
-99 XJ Limited.
-Jeepspeed 1717 -Built 4.0, FAST EFI, Rubicon Express, Bilstein, Rigid Industries, 4 Wheel Parts, G2 Axle, Currie Enterprises
-Member, FSJ Prissy Restoration Association
Old 01-01-2008, 11:39 PM
Wagabond's Avatar
Wagabond Wagabond is offline
Works fine, from both the key switch and the in cab. All the window motors work, but the tapey things that raise them have broken in 2 of the doors.
Americans: We're fat because we have food.
Old 01-01-2008, 11:49 PM
Blake Blake is offline
Everything works great on my '83 with SOA and 37's.
Old 01-02-2008, 12:41 AM
leftturn109 leftturn109 is offline
Didn't BJ's sell a manual convertion at one time?
Old 01-02-2008, 01:10 AM
Mark Wilde's Avatar
Mark Wilde Mark Wilde is offline
Okay, I voted yes, but maybe I should clarify. My 90 works great. My 85 needs a helping hand DOWN but up works like a rocket. Go figure!
Of course, much like Strider, now I just cursed myself...
90 Grand Wagoneer, 401/727/229, TFI upgrade, MC4350 4V, Edelbrock Performer cam, All-Aluminum Radiator, Razor Conversion, 4" Rusty's all-spring, 31x10.50 BFG TA/KO's...much planned, little time/money, thus she's a PipeDream!
Status: Up and running, but needs attention....
Old 01-02-2008, 02:32 AM
SBJeep's Avatar
SBJeep SBJeep is offline
Perfect until below 32 degrees, then no. It doesn't get cold enough here to troubleshoot it.
Tom - '90 GW(Gone)
Old 01-02-2008, 07:40 AM
Golddust's Avatar
Golddust Golddust is offline
My 77 has always worked fine. In about 79 I added a rear inside switch to operate the window when I slept in the back camping. In 1985 I replaced the wipes and touched up the defrost grid. I never had the rear switch cover modified for the safety recall. If the key is left in the switch, the cover can activate the switch closing the window on someone or something.
REGARDS, GDDST
