Old 04-14-2012, 09:30 PM
imiceman44 imiceman44 is offline
bench testing a 360???
So I pulled my 360 out of the Waggy and sold the waggy.
Now I am putting my 360 on an engine stand and I want to test it, I do have all the electronics, but the wiring harness is gone with the Jeep. So my question to save me time figuring out how to power it, anyone know the minimum I need to get this engine running on a stand?
Thanks in advance.
IceMan
IceMan
Old 04-14-2012, 11:45 PM
Rich88's Avatar
Rich88 Rich88 is offline
Thanks in advance.
IceMan
Well, the starter bolts to the tranny housing, not the engine, so you'd have a hard time starting it without that. You'd have to build a custom stand to accomodate everything.
Old 04-15-2012, 04:14 AM
I know, I have the tranny here too.
Just trying to see if someone already figured out which lines to power for a quick test run, but if I don't get my answers when I am ready I will go thru the wiring diagram and figure it out.
IceMan
Old 04-15-2012, 06:41 AM
Power to the ign box and coil should make it run.
46 cj2a
51 Willys p/u
'51 Willys Parkway Conversion
'74 CJ5
'75 J-20 Wrecker
'75 J-20 Cummins service bed
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
Old 04-15-2012, 11:23 AM
Thanks, can I be more of a pain and ask which color line coming in to the ign is pos and which is neg or is it just grounded on the box?
IceMan
Old 04-15-2012, 11:47 AM
google duraspark wiring diagram
one plug is + for crank and ignition from ignition switch
other plug runs to coil & distributor pickup
ground would be engine block
Old 04-15-2012, 12:00 PM
Carnuck Carnuck is online now
Last time I saw someone start a motor on an engine stand, it was one of theose made in China ones and it folded, destroying itself and since the motor was running, MAJOR damage ensued, including breaking of the body parts of owner and nearby vehicle. Make sure you have the front braced too!
Old 04-15-2012, 12:08 PM
Oh you don't know me.
I go overkill.
I started with a base 2000lbs HD engine stand non foldable, and then building on it for the trans mount, and it will be strapped down so it doesn't go anywhere.
IceMan
Thanks
IceMan
Old 04-15-2012, 12:18 PM
SC/397's Avatar
SC/397 SC/397 is offline
I use a bell housing from the old cast iron Borg Warner automatic and a Pro Torq stsrter.
http://s625.photobucket.com/albums/t...ent=002-18.mp4
Old 04-15-2012, 01:35 PM
lycanthrope's Avatar
lycanthrope lycanthrope is offline
on 'desert car kings', they pulled a motor from the junkyard, hooked it to a battery, poured some gas in the carb and fired it up(on the ground).
backfire+spilled fuel=fire, but after they put the fire out, they tried again, and got it running.
tommy
'83 j10 pioneer 258/t5/208...gone
'81 j10 sportside 258/t176/208
'76 j10 shortbed 360/th400/QT
'81 j10 sportside 258/tf999/208
'74 j10 shortbed ...gone
Old 04-15-2012, 02:02 PM
I've run many an engine on the ground...just don't rev 'em up and it's all good.
If I can't see/hear it run I won't buy it, or it better be dirt cheap.
Old 04-15-2012, 05:23 PM
That is why I want to run it, I am selling it and don't liek to sell engines condition unknown to them or they will not pay what it's worth.
IceMan
Old 04-15-2012, 05:25 PM
I have seen this done a couple of times. LOL, it is a hoot to watch.
46 cj2a
51 Willys p/u
'74 CJ5
'75 J-20 Wrecker
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
360 rebuild rem2506 General FSJ Tech 6 10-04-2008 05:20 PM
will a 2barrel carb off 360 fit 304? Robber80 General FSJ Tech 7 05-03-2006 06:39 AM
a few questions swapping out 360 in 401 roadgrime General FSJ Tech 3 04-03-2004 05:49 AM
360 better than 258?? Scruffy Engine 6 07-24-2000 08:04 AM
