Old 08-19-2019, 04:23 PM
tarriverarms's Avatar
tarriverarms tarriverarms is offline
Trans/engine temp ranges
Does anyone have any idea what the temperature ranges are where the transmission bell housing interfaces with the engine block?
I have received a donor trans that has a hole in this area that needs patching. I was thinking of using alumiweld to fill in this area. Alumiweld has a melting temp of 730* F. I believe it would be safe to use but not 100% sure.
Old 08-21-2019, 02:00 PM
730 is ALOT!!! It doesn't get that hot! If it did, you would have MUCH bigger problems. I bet it does not get any hotter than about 200 degrees on a hot summer day...
79 Cherokee Chief
TBI Engine Temp sensor and Factory Temp Sendor locations rang-a-stang Fuel Injection 8 03-21-2018 10:46 PM
Coolant temp fluctuating Old Ironsides General FSJ Tech 43 08-13-2015 10:56 PM
Auto dimming rearview with compass & temp install JeepsAndGuns General FSJ Discussion 24 02-02-2013 12:43 PM
temp sending unit placement (Trans temp and oil temp?) Wagoneerlover General FSJ Tech 3 05-21-2007 02:41 PM
is this a bad place for temp sensor???? rockcandy General FSJ Tech 12 12-02-2004 04:21 PM
