Old 01-26-2016, 10:33 AM
see2xu's Avatar
see2xu see2xu is offline
2300-2800 stall converter
The bill keeps mounting - ended up having the original long block rebuilt after the engine I bought calved .
It's going to be 375-400 hp once it's finished, and the builder is suggesting I upgrade the converter accordingly. Any recommendations? I know I have to get one for the AMC version of the Torqueflite - looking for brand/specification suggestions.
Still wrestling with whether to pour more money into this thing, and have Novak build me a 4L60E with their adapter kit. I will NEVER learn.
Old 01-26-2016, 11:00 AM
you can get the factory hi stall unit rebuilt from transtar for about 100 bucks.
the hi stall is about 200-300 rpm higher than the lo stall that jeep used behind the v8. it's works good for what you are doing.
Old 03-30-2016, 03:29 PM
johnbayou66's Avatar
johnbayou66 johnbayou66 is offline
Noob!
Where are you purchasing your engine?
Are you purchasing an H/P AMC360 from CME Engines? I did (415hp at 420lb torque) and they required an 1800 to 2800 stall speed converter...
My transmission guy "Voodoo Daddy Transmissions" had my stock one rebuilt to meet this requirement, to keep from having any fitment issues. Also he added a shift kit.
Johnbayou66
Old 04-17-2016, 01:27 PM
wagy401's Avatar
wagy401 wagy401 is offline
keep in mind that if you go for high stall you maybe get shift problems
if you don't have a lock up !!
for street use it means that the trans shift up to the second gear and in that rpm the converter is still spinning . in that case you need to modified the transmission shift points !!
What stall torque converter djmac Off-Road FSJ Tech 9 01-24-2009 07:45 PM
What stall for a torque converter? Ziptie General FSJ Tech 5 02-20-2008 02:51 PM
Catalytic converter removal? Schlagger General FSJ Tech 12 02-19-2008 09:25 PM
torque converter recommendation crispyboy General FSJ Tech 6 07-11-2006 12:12 PM
'85 G.Wagoneer 727 torque converter, lock-up, high stall, or low stall? Luke Harris General FSJ Tech 3 01-25-2002 07:51 PM
