Old 01-20-2020, 05:08 AM
Brynjminjones's Avatar
1991 GW - Door Jamb Switch Wiring
Hi Guys,
I'm finally looking back into an issue I've had for ages.
All my interior lights randomly turn on and stay on in my '91. The only thing I can do to turn them off is remove the fuse.
The rear left door jamb switch has no wire connected to it so I'm guessing the wire is floating around in the B-pillar somewhere, occasionally making contact to ground.
I've tried fishing with a coat hanger to find the wire but never had any luck.
Any idea how to find the wire?
Also, does the wire come from the top of the pillar or the bottom? I've studied the FSM and the Oljeep diagrams but never quite managed to figure that out.
Thanks!
Bryn
1991 Grand Wagoneer - Hunter Green
1998 Cherokee (XJ) 4.0
1997 Grand Cherokee (ZJ) 4.0
1974 Ford F100 390
Old 01-20-2020, 08:21 AM
Driftwood's Avatar
Bryn
My wires for the rear door switches come down from the top. The wires originate off of the overhead cabin lights. You may have to partially remove a overhead panel to get to the wiring.
Old 01-21-2020, 03:10 AM
That's great news, thank you!
Finding the wire hanging from above should be much easier than trying to feed it up the pillar from the bottom.
When I get the headliner out I'll see if I can sort it.
Thank you!
1974 Ford F100 390
'70 Wag ignition switch wiring issue houndog1 General FSJ Tech 10 07-23-2017 07:48 AM
Reverse light switch wiring BigBlueYJ General FSJ Tech 2 04-01-2015 09:50 AM
new wiring job (Interior of rig with pics!!) Wagoneerlover General FSJ Tech 21 05-14-2008 06:35 PM
No wiring to my Quadratrac Switch Fornesto General FSJ Tech 10 03-18-2004 04:06 AM
