Old 07-16-2000, 08:35 AM
Ralph's Avatar
Ralph Ralph is offline
Third Member
Wink
Has anyone retrofitted a 4-headlight system?
I've got my front end apart (again), the radiator out, grill and other local parts off, in the course of replacing the A/C condensor and filter/drier. So naturally I'm looking at those nice round cut-outs and pondering the function/appearance of putting in a "Rhino Chaser" grill and four round headlights, to look more like the original models:
Oo [!!!] oO
Really, really BRIGHT headlights... H1/H4 halogens... yeah!
I can see that it would be necessary to move the filter drier out of the way of the cut-out on the passenger side, and move the horn units from the cut-out on the driver side. But from that point it looks to be no more than a couple of appropriately sized headlamp buckets, and probably a bit of wiring to set them up as high beams.
[This message has been edited by Ralph (edited July 16, 2000).]
Old 07-16-2000, 11:02 AM
jamchico jamchico is offline
Cool
I'm trying to set up that exact thing! I have replaced my grill with a "rhino" and I found smaller buckets at the local yard. I am having a problem finding and headlight bevels (the chrome outer ring) for either size. I think just about any round ring will work with the larger size, but I'm having touble with coming up with ideas for the smaller size. I have the metal covers for the smaller hole, but I just didn't like the look when I got them home. Do you know anything about headlight wiring loom called ARB H4? I saw a string where the guy praised it, but he never replied about price or where he got it.
Allen
69 wag
Old 07-17-2000, 04:10 PM
Ralph's Avatar
Third Member
Wink
Off-hand, I would look at late '60s to mid-'70s European cars for chrome rings to fit, since many of them had smaller round headlamps. Also, I think JC Whitney has some, but I'll have to look.
As for the wiring, every time I see an older BMW or VW I wonder if I couldn't just use the wiring harness out of them, or create my own using a wiring diagram out of a Haynes/Chilton manual.
Do you have any pictures of your progress? Just a few minutes ago I finished putting my grill back together, so I'm really thinking about this right now.
Old 07-17-2000, 04:31 PM
ClarkGriswald's Avatar
ClarkGriswald ClarkGriswald is offline
Wink
Seems to me you could just run a wire from the hot terminal on the headlight switch(the one that energizes when the headlights are turned on. and use that power to trigger a relay that will handle the full power of the additional lights.. simple circuit.. I have been thinking bout doin this myself. Im thinking about making a second fusebox (or possibly a bank of self reseting circuit breakers) that can be fed with a heavy gauge wire right off of the positive battery lead. I will try to mount it on the inner fenderwell I think, and make it so I have a "HOT" point that I can tap into with whatever I want.. (like a positive buss rail with several holes and setscrews so you can hook in a couple of circuits). or a multi ciruit box with a single feed.. anyone ever do this? or does everyone just hack stuff togethor as they go? like add it when i need it?? of course the biggest consideration is the waterproof factor\roadworthieness.whatever I end up doin on mine.. it will be somehow made to be weatherproof.. . but back to the headlight thing. it should be real easy to add them to the existing headlight circuit.. the big powerwire from the battery (thru a relay) right to the new lights will give them the unrestricted voltage that they want.. and the small voltage needed to energize the relay should be easily provided by the stock headlight switch. (I wanted to have my headlight switch turn on the power to the stock lights the second set like you folks are adding, and the foglight\driving lights, and have three subcircuits with switches to turn each of the three on or off as I need them.. heheh sorry Im a big tinkerer\madscientist when it comes to electrical.. . but I am glad to help out on electrical info wherever I can.. hope this helps give ya some idea's
88 Grand Wagoneer
D44's front\rear
AMC 360
TF 727
NP 229 (Funky)
Bone Stock (for now)
NO RUNNING BOARDS!
Old 07-17-2000, 04:39 PM
Wink
Sorry forgot one thing.. if you use lights for your secondary add in's. that are HI and LOW beam.. youll need to have a double circuit. two identical one's one Hi one LOW they could both be on the same fuse\breaker just need to split after the protection and go into two relay's then two hot wires to the to filaments in the bulbs.. and the third wire as the ground.. snag some plugs for the lights from a junkyard or wherever.. My biggest question was where do you get the mounting hardware\adjusment's to mount those round lights? are they just like one's from some other jeep vehicle and you can utilize them in this application???
88 Grand Wagoneer
D44's front\rear
AMC 360
TF 727
NP 229 (Funky)
NO RUNNING BOARDS!
Old 07-20-2000, 06:34 AM
Snakeyes_Tx Snakeyes_Tx is offline
Wink
Hey, the headlight buckets as I've been told for the outside round lights.. the buckets, cups, the rings, and the lights are ALL the same as a CJ. So I'd look into that first. As for the inner lights, I believe the round lights off an older Jaguar would work. Hell... have you guys ever looked at a Jag up close for a while? The Four round lights.. two inside ones are smaller.. the grille in the middle looks like a smaller rhino style... its such a coincidence! As for wiring the inner lights... DO IT THE EASY WAY! Just rig the outside lights for HIGH and LOW and rig the inner lights on your own wiring system with a switch in the dash.. that way you can do what I plan on doing.. having the highs on... my driving lights (blue-white) AND have my KC daylighters in the little holes! Imagine THAT!
Old 07-20-2000, 10:22 AM
Ralph's Avatar
Third Member
Wink
Excellent idea, Snakeyes. Does that mean you kept your Jeep after all? Good for you!
Old 07-20-2000, 04:22 PM
JERRY88GW JERRY88GW is offline
Wink
I would love to see a pic of this! <
Old 07-21-2000, 04:12 AM
Ralph's Avatar
Third Member
Wink
Since reading Snakeyes' post yesterday, I've been pondering the possiblity of getting an older Jag sedan (love the V12) and putting woodgrain trim on it. Maybe call it the "Jagoneer."
Old 07-21-2000, 05:07 AM
Wink
Hmm.. I live in a mobile home.. mabye I will do the simulated woodgrain trim on my whole house hahhahahah.
88 Grand Wagoneer
D44's front\rear
AMC 360
TF 727
NP 229 (Funky)
NO RUNNING BOARDS!
Old 07-21-2000, 04:16 PM
Ralph's Avatar
Third Member
Wink
Clark, call it "Double Wideneer."
Okay, tonight I was looking at a '88 VW Rabbit with a perfect headlight set-up, except that there's still the problem of finding chrome rings. I even think the smaller lamps will be shallow enough that I won't have to remove the filter/drier from the small hole on the passenger side (the two horns behind the driver-side hold can be remounted anywhere).
Jerry88GW, take a look at the J300 DutchD is seling in the Classified Forum:
http://thunder.prohosting.com/~dutchd/j300photo.htm
That's the look original FSJ's had, and I'm interested in doing the same thing to my '88 Grand Wag.
[This message has been edited by Ralph (edited July 21, 2000).]
Old 07-21-2000, 04:56 PM
Wink
Wow!
That's a great look for our jeeps! It's very eye catching!
Let us know how you get it figured out, I'm interested.
Jerry
Old 07-21-2000, 06:19 PM
porkchop's Avatar
porkchop porkchop is offline
Master of B.S.
Smile
I was looking at buying a '65 wag awhile back. It had the grill like the truck in the pic. I did notice that the other two inboard spots that everyone thinks are head lights are in fact just plates to cover up the holes. I do not know if it was just for that wag or if was standard. I just think that doing this will be on your own as far as wiring and mods. Let us all know how it goes.
'67/'79 Wagoneer mix
Body of a 33 year old
Heart and legs of a 21 year old.
360,TH400,QT,D44's F&R
32X11.50's
"I regret that I have but only one paycheck to give to my Jeep."
Old 07-22-2000, 01:09 AM
andy d andy d is offline
Shade Tree Shaman
Question
i'd been thinkin along the same lines as this thread. just wonderin'; is there a repro of the Gladiator grill available? the rest of those parts,headlight fixtures and such could be sniped from a cj or a commando.up here in ne, where the only things saltier than the ocean,are the roads,glads are a distant memory,
'88 gwag
Old 07-22-2000, 02:50 PM
Ralph's Avatar
Third Member
Wink
Even while we've been participating in this thread, I bid on a "Rhino Chaser" grill on eBay:
http://cgi.ebay.com/ebaymotors/aw-cg...item=383109776
The seller has already contacted me, and he's got to check on the shipping cost. I can't wait to get it, then go about checking around for prices on getting it re-chromed.
I think this was a steal (depending on the condition of the grill). The last one I saw sold for over $100.
[This message has been edited by Ralph (edited July 23, 2000).]
Old 07-23-2000, 05:58 PM
Thumbs up
Congrats on the grill Ralph! I got mine off of Ebay also. It cost me $50 + s/h, but it still had the orig parts tag on it. A little elbow grease and it shines so pretty! If anybodys interested I have those inside plates for the smaller holes.
Allen
69 wag
Old 07-25-2000, 11:01 AM
Ralph's Avatar
Third Member
Wink
From reading posts on this forum over the past year, I've learned that on Europe-bound vehicles the two smaller, inside openings may have contained headlamps. Does anyone know more about this?
Old 07-26-2000, 02:03 PM
BobBarry
Posts: n/a
Cool
<BLOCKQUOTE>quote:</font><HR>Originally posted by ClarkGriswald:
[snip]
<HR></BLOCKQUOTE>
I did this very conversion on my '78 Cherokee; I feed an aftermarket add-on fusebox (a $6 Motormite one) from the charging stud on my alternator, and from there run a 10-ga wire to a pair of relays I have hidden under the overflow tank. These relays are switched by the original wires running from the dimmer switch, and the current is sent to the headlights through the rest of the original wiring.
I have also added an additional charging wire from that alternator stud to the (+) feed on the starter relay, so the dash only sees a small fraction of the amps it normally would see. Now I can add as bright a set of lights as I want without worrying about melting my headlamp switch!
Bob Barry<UL TYPE=SQUARE>* '78 Cherokee 4-door
* '88 Grand Wagoneer[/list]http://studentweb.providence.edu/~rbarry/wheels/
Old 07-28-2000, 11:41 AM
Brenton Brenton is offline
Wink
AAAAAUUUUUGGGGGGHHHHHHH!!!!!!
SO YOU'RE THE BAST&$%S THAT KEEP DENYING ME MY REPLACEMENT GLADIATOR GRILLE!!!!!! YES YOU STOLE THAT GRILLE BECAUSE I'M TAPPED OUT. NEXT DECENT ONE ON EBAY GOES FOR A MILLION BUCKS IF IT HAS TO BUT IT'S MINE.... DO YA HEAR..... MMMIIIINNNNNEEEEEEE!!!!!!!
The front Grille mount is the exact same as the Wagoneers with only a few exceptions. The One on the Wagoneer still has the tabs that the Rhino Grille mounts to, but it has some mounts welded on the front where the longer grille bolts up to. I almost used the one off my Wago parts truck, but decided that with the rusted hole in the bottom of it, it wasn't worth salvaging, plus having to grind those grille mounts off, and then bondo it back to smothness and beauty. Another important thing to note on the Wagoneers is that the hood release is different with a "Rhino" Grille as opposed to the stock grille. On the Wagoneer that release is right up under the hood. Picture sticking your hand over the top of the Grille between the hood. That's where your release is at with the long grille. With the 12 Slat Gladiator Grille (yes, it was stock on the Gladiators from 62 to 69 - not sure of EXACT years) you actually reach between the slats farther down from the hood to release it. You would need to extend the arm down to be reachable with a Gladiator Grille since that grille is taller, and you have to remove that little brace on your hood to accomodate the different height.
In addition, that extra length has to be accomodated by cutting a hole into your Radiator mount. If you look at it closely, yull see kind of a dimple in the metal between the hood catches. That dimple is a hole on the Gladiator's and allows passage of the hood release arm. If you closed your hood after mounting a Rhino grille on the front, I don't think there'd be any way to ever get it open again. You wouldn't be able to reach it.
The guys who have already done the conversions could probably verify this. I'm going off'n memory and the quick glance I took when noting the differences. However, it is a little more work than the initial glance would indicate (So stop buying my replacement parts for your stinkin' silly pathetic little conversions!!!)
Also, those little dealies you see in the center (where you intend to mount the additional headlights) are indeed aluminum inserts (mebbe pot metal). They mount up using 4 screws.
I followed the link, and that is indeed a beautiful Gladiator. And for you Neanderthals who think that "Rhino" Grilles are cool without knowing any better - that is a Thriftside. A gorgeous example of an American Classic. The last of a dying breed, and a most noble beast. I can only hope miine looks as good when she's done being restored.
BTW: Guys, I'm just yankin' yer chains. Didn't want to offend anyone when I'm just teasin' around. Those grilles are very unique, and Kick A@@. I wanna get a replacement (Something hooked on my emblem in a past life and bent the two slats that it mounts too. Unfortunately it split the metal while it was at it. Wanna get a good replacement, and then consider repairing the other one for a spare.) It's the fastest way to identify a Gladiator. After they changed the Grille, it just became a J-Series Pickup - No offense to my lesser cousins
Later,
Brenton
Old 07-28-2000, 12:01 PM
Wink
Additional Note:
Yes Ralph - you got an excellent deal on that grille. That's the cheapest I've seen one go for on eBay in that condition. Most of them have been dented, and from the looks of it most need replating anyways.
Jamchico, you got the best one I've ever seen sold on eBay. Swiped it out from under me in the last hour of the auction. That'll teach me to assume that an auction on eBay is a done deal.... And hey, what'd I buy from you recently? It's driving me nuts!
As far as reproductions on those Grilles.... Haven't seen it. If you find it YOU MUST POST IT!!! IN BOLD LETTERS!!! Reproductions on the Gladiator specific parts are virtually nil. My only saving grace is that a lot of the parts are identical on the Wag's and the J-Series trucks for years - so somebody makes the more generalized parts pretty readily....
Yes, the round dealies in the center were stock. Far as I know there wasn't even an option for headlights there. They're just dress up. I guess to make the front end a little busier, or something - but it still looks sharp.
Brenton
