Old 09-04-2004, 08:28 AM
matt0481 matt0481 is offline
Post digital clock wiring
Does anyone know which wires are for what on the digital clock. The Chilton and Haynes are confusing.
[ September 04, 2004, 02:28 PM: Message edited by: matt0481 ]
Old 09-04-2004, 09:02 AM
The below is a post I saved years ago and can't verify it's accuracy so use at your own risk but anyway here is what I have:
"There are five wires coming out of the clock.
Black - Ground
Red - Constant +12V
Blue - Ignition Switch +12V, will turn on the display
Yellow - Parking lights (running lights), this connection will signal
the clock to dim the output to the appropriate level. Connect this to
one of the white wires coming out of the light switch (there are
three...just poke a pin in the wires and check the signal with a
voltmeter).
Orange - Dash lights (dimmer voltage level), this connection will
indicate the appropriate dimmed level."
Old 09-04-2004, 09:31 AM
M1Garandfan's Avatar
M1Garandfan M1Garandfan is offline
Red - Constant +12V
Yellow - Parking lights (running lights), this connection will signal the clock to dim the output to the appropriate level. Connect this to one of the white wires coming out of the light switch (there are three...just poke a pin in the wires and check the signal with a voltmeter).
Orange - Dash lights (dimmer voltage level), this connection will indicate the appropriate dimmed level.
Here we go digital clock wiring up grade. This is how a "REAL" Jeep dealer did mine back in the early 80's.
Black—Ground
Blue—Hot with ignition on only
Red—Hot all the time
Yellow & Orange—Is what I call variable, able to dim and brighten like your dash lights. (Splice the yellow and orange wires together)
I found a place on the fuse box for the Red, Blue, & Yellow/Orange wires. Just take your Probe and check open plugs for when they are hot. One of the two wires for the old clock is always hot and the other is a ground. "
"That rifle hanging on the wall of the working-class flat or laborer's cottage is the symbol of democracy. It is our job to see that it stays there." - George Orwell
76 Cherokee Chief (Sold)
78 J10 Longbed (Stock daily driver)
78 Cherokee Chief (Sold)
87 "Garand" Wagoneer (Sunday go to meeting)
95 "Garand" Cherokee
