Old 01-27-2008, 01:10 PM
krek's Avatar
krek krek is offline
Perpetually Perplexed
Buick 455 vs Olds 455 vs Pontiac 455
I know several members have swapped a Buick 455/TH400 in their FSJ. I went to look at a B455 today and it turned out to be an Oldsmobile 455. I know these motors aren't interchangable, but is there a significant FSJ advantage or disadvantage to the Buick vs the Olds vs the Poncho?
Old 01-27-2008, 02:01 PM
billyrb's Avatar
billyrb billyrb is offline
BJ's Off-Road
Originally Posted by krek
I know several members have swapped a Buick 455/TH400 in their FSJ. I went to look at a B455 today and it turned out to be an Oldsmobile 455. I know these motors are interchangable, but is there a significant FSJ advantage or disadvantage to the Buick vs the Olds vs the Poncho?
They aren't interchangeable and don't use the same parts. The Pontiac 455 has the most aftermarket parts available as well as the least expensive. The olds has less support than the pontiac, but still a few good places out there although more expensive. The olds is a great motor and can be built for a TON of power.
BJ's Off-Road
ryan@bjsoffroad.com
Old 01-27-2008, 02:19 PM
krek's Avatar
Dang it... I specificially meant to type "aren't interchangable"...
Old 01-27-2008, 02:22 PM
billyrb's Avatar
BJ's Off-Road
hehehe, suuuuure ya did fingerfarts, they make you type what you mean not to
BJ's Off-Road
ryan@bjsoffroad.com
Old 01-27-2008, 02:32 PM
HorribleHarry's Avatar
HorribleHarry HorribleHarry is offline
Location: Encino, San Fernando valley, Los Angeles, California, USA., Earth, Orion arm, Milky Way galaxy
You can get a TON of oomph out of the Olds motor. There is still a decent amount of aftermarket for it since so many were used as boat powerplants.
Perhaps an adapter plate???
These are all good places to start for performance enhancements.
http://www.mondellotwister.com/
http://oldsperformanceproducts.com/
http://www.rocketracingperformance.com/
http://www.pawinc.com/
Harry
86 GW, 360-V8, NP229, Tow Package(3.73's), D44/AMC23, aux. 25 gal. fuel tank, 2.5" lift, 31"BFG AT's, dual Flowmaster exhaust w twin cats, factory brush guard, PIGNOSE transplant!, rust, shiny chrome valve covers! ...and no more woodgrain!
89 Range Rover classic hunter (with factory standard leaky head gaskets!!!)
87 Vanagon SYNCRO 4X4
Old 01-27-2008, 02:50 PM
Eugene 1's Avatar
Eugene 1 Eugene 1 is offline
go Buick !
1970 Charger Daytona
2005 Ram 1500 Hemi
1979 Cherokee Dodge CTD with running Gear Build thread
MoPaR
Old 01-27-2008, 02:53 PM
Mikel's Avatar
Mikel Mikel is offline
1969 M715 6x6
1963 J300 Swivel frame
Old 01-27-2008, 02:56 PM
Eugene 1's Avatar
Originally Posted by Mikel
nice toro. 68 ?
2005 Ram 1500 Hemi
MoPaR
Old 01-27-2008, 02:57 PM
66!!!
oh I'd be willing to swap my front teeth for an early Toronado!
Heck it even has my name on it!!!
Harry
Old 01-27-2008, 03:24 PM
willam's Avatar
willam willam is offline
I'm thinking that the deal maker or breaker for swaping into an FSJ woulld be the distributor location. Buick/Caddy is on the timing cover, just like a 360. Not sure, but I believe the rest have them located on the rear of the intake manifold like a chevy. Not a whole lot of room back there, especially when stuffing a big block under the hood.
Why bother with cutting the firewall anymore than necessary? Also makes maintenance easier if it's all up front and easy to get to.
My 2 cents, for what it's worth.
Old 01-27-2008, 03:37 PM
Mikel's Avatar
Good eye... It's a '66.
A bit of Olds artwork
1969 M715 6x6
Old 01-27-2008, 05:25 PM
krek's Avatar
Sweet Toronado, Mikel!
I have a '69 Country Squire waiting to donate a 429/C6 and 9 inch rear to my wife's high school car (1970 Mustang Sportsroof)... put that project is years off.
What about the Ford 429/C6 for an engine in a FSJ? I'm assuming it would bolt up to an NP205?
Old 01-27-2008, 05:43 PM
krek's Avatar
I just don't like the idea of putting a Ford in a Jeep...
Old 01-27-2008, 07:29 PM
LouM LouM is offline
The Buick, Olds, and Pontiac engines you're considering all had the same bellhousing bolt pattern so any one of the three will bolt up to the same transmission. The mounts and accessory brackets are another matter, though. From there on, it's just as Ryan describes. The Pontiac has the most support. I like the Olds engines myself but the Buick 455 was the only stock engine of that era to produce over 500 lb. ft. or torque.
Lou
Old 01-27-2008, 08:03 PM
mafos4471's Avatar
mafos4471 mafos4471 is offline
OK, from personnal experience Buick is EXPENSIVE to rebuild... around 3000 for everything. Definately more aftermarket for Olds, Pont, and from what I remember cheaper to rebuild, like 2000-2500. All the 455's had distributers on the front of the engine, so thats not a problem. Have fun...
Old 01-27-2008, 08:10 PM
krek's Avatar
For sure? The engine I looked at today had the dizzy on the rear. It had aftermarket valve covers and air cleaner... I'm not sure what else it could have been.
It was in a '72 Delta 88...
Old 01-27-2008, 09:10 PM
Dirtball's Avatar
Dirtball Dirtball is offline
Hope this helps (looks like you WERE looking at on Olds engine):
The Olds engine family is identified by:
1. An oil fill tube at the front of the engine, just over the timing chain enclosure. It is offset to the right (passenger side) of the engine, and on most cars, it stands straight up 'n' down. A few engines use a fill tube with a slight bend in it, but the base of the tube will be vertical.
2. Distributor in the rear, but offset slightly to the left (driver's) side. It rotates counter-clockwise as seen from above. Distributor does not enter the intake manifold.
3. Valve covers are held on with 10 bolts (early engines) or 5 bolts (later engines.) The pattern is the same, but every other hole is unused (and perhaps undrilled) on the 5-bolt covers. 10 bolt covers use five bolts on the bottom row, and five bolts on the top row. 5 bolt covers use three bolts on the bottom row, and two bolts on top row.
4. The timing chain cover is a flat, stamped sheetmetal cover with provision for the front main seal and water pump outlet openings. Fuel pump is mounted to the right (passenger side) of the timing chain housing.
5. There are identifying numbers and letters cast into the top of the timing chain housing at the front of the engine, just in front of the intake manifold. If the large figure at the end is a number, you're looking at a small block. If the large figure at the end is a letter, you're looking at a big block. All 455s use the letter F to identify them.
Info taken from: http://reviews.ebay.com/GM-Big-Block...00000002053785
Paul
1979 Cherokee N/T
360/TH400/Qtrac/D44s/rear Lock-right
6 inch Hell Creek all spring lift
34x10.50 Super Swamper LTBs
http://i54.photobucket.com/albums/g1...t/100_1394.jpg
http://i54.photobucket.com/albums/g1...t/100_1390.jpg
http://i54.photobucket.com/albums/g1...100_1387-2.jpg
Old 01-27-2008, 10:22 PM
Crazy_Jeepman's Avatar
Sloppy Shifter
It would be an OLDS 455. The only 455 with the Dizzy up front would be the Buick.
Old 01-28-2008, 02:14 AM
You'd rather see a chevy in there???
ewwwwwwwww yucky (sorry, I grew up in the blue oval)
hehe
Harry
Old 01-28-2008, 10:03 AM
GWChris GWChris is offline
When you think about how many OHV pushrod V8 designs the US auto industry made, and how similar they all are from a big picture point of view, it's really silly to have allegence to a particular brand or type. That's without getting into the whole concept of people tying their personal identity to that of a corporation....
Anyway, some particular designs were better worked out than others, and some fit better in a particular application than others - go with whatever gives the best result for the effort and money - or perhaps just use what interests you. The only "correct" engine from a restoration point of view is an AMC.
$4.55 / ga.?
