Old 11-25-2019, 05:25 AM
hudwagon hudwagon is offline
Durango rear wiper mod
how many of you have done this with success? I found the correct Durango rear wiper motor now just trying to muster the courage to do it. This is on a 1989 GW
David
Old 11-25-2019, 07:46 PM
rws31's Avatar
rws31 rws31 is offline
We did it in our 89 and it was pretty simple. Making the arm was harder than mounting the motor. I just bent and cut down the durango arm to match the wag arm. Here is a pic of it mounted in the tailgate. You will need to make a bracket to stop the motor from twisting. It works perfect.
IMG_20190413_174500340 by ,
89 GW, 454, 700R4, 241C, 411's with posi's, 9" rearend, 2500 stall, lifted, and lots more to do.
1988 Ramcharger
1999 International 4700 Crew Cab 4X4, custom step side bed
2003 Durango 4x4
1982 CJ7 4 banger
2008 MB E320 Bluetec
Old 11-26-2019, 05:04 AM
Thanks for the picture that helps a bunch, my nervousness comes from drilling the tail gate hole larger but appears to be simple with a step bit.
Old 11-30-2019, 09:58 AM
I can't say how many have done it, but yes easy easy.
I would agree the arm is tougher than the motor.
Old 11-30-2019, 05:03 PM
well got it all done and it works great, it was easy .... well except for the 3 times i cut and re spliced thinking it was wired wrong, i had power to the motor but wouldn't work checked fuses, relay dash switch etc. Then by accident i bumped into this little micro switch in the tail gate and it worked , so it appears with the tail gate down and the rear glass not all the way up the arm for the glass wont trigger the switch ,
lesson learned.
Old 12-01-2019, 07:01 AM
acct21's Avatar
acct21 acct21 is offline
Glad it worked out for you.
I did mine five years ago (Babywag and I wrote the tutorials in the electrical section). I used it yesterday! It's one of the areas where you can really fix a mistake made by the factory.
I still haven't messed with the wiper arm -- the factory Durango arm has always been "close enough."
Old 12-02-2019, 07:45 AM
pickledtoast pickledtoast is offline
Man I have to get on this. Not too many pick n pulls by me though.
Old 12-03-2019, 03:23 PM
found mine on Ebay
1990 gw rear wiper gophman General FSJ Discussion 2 03-15-2015 03:41 PM
installing rear wiper arm on 91 GW Tbeach General FSJ Discussion 3 02-20-2015 12:16 PM
GW rear wiper 'sticker' G_$ General FSJ Discussion 3 02-04-2009 04:57 PM
Need to get rear wiper motor out...how easy? jeepthing General FSJ Tech 3 09-12-2003 08:52 AM
90 GW Rear Wiper Motor Repair 90Woody General FSJ Tech 2 09-28-2001 11:53 AM
