Old 06-16-2019, 07:31 PM
Bkgw Bkgw is offline
Fuel skid plate question
Putting back my fuel tank and coffin skid plate on my 82 wagoneer and need help. When I removed the tank it had a heavy duty home made cradle. I picked up a coffin for it and did some work and am ready to install. However since I didnt remove it, Im having a little trouble installing it. Can someone draw a crude diagram or point me in the direction of one and where all the bolts should go? I have the 2 book shop manual but havent seen it. Ive scoured this forum and have read a few different things but just get confused. I did learn the frame should have welded nuts, so that helps a bit. But on the driveshaft side are there any bolts...there has to be? Is there a long bolt somewhere on the frame side or is that for a different jeep. Thought I read about a long bolt? Thanks in advance!
Old 06-17-2019, 10:54 AM
I guess what I really need to know is of there is a bolt that goes throught either of the tank straps or on the inboard side that attaches to the body or any other point for support.
Old 06-17-2019, 12:37 PM
acct21's Avatar
acct21 acct21 is offline
On my '90 -- and I think they may be the same on the '82 -- there is only one inboard bolt. It hangs down from the body brace, and goes through one of the two holes at the flange where the rear tank strap attaches inboard.
You lift up the tank/skid, and the threaded bolt goes through the skid/strap hole, and you cinch it up with a nut and washer. the inboard rear of the tank/skid "hangs" from this bolt.
Old 06-17-2019, 03:33 PM
Thanks...thats the info I needed. Very hard to find clear pictures of this setup under a vehicle.
seized fuel tank skid plate bolts murphtime General FSJ Tech 3 10-11-2011 01:42 PM
Yes another fuel tank question - 82 J20 -possible to swap XJ tank-how? FSJK General FSJ Tech 12 05-03-2011 09:39 PM
69 Waggy Stalls When Warm kodyharrell General FSJ Tech 11 09-30-2009 11:07 AM
Fuel flow question srobertsfsj General FSJ Tech 3 07-01-2008 03:11 PM
Fuel filler hose / Skid plate Q. Narnian General FSJ Tech 3 09-25-2002 09:35 AM
