Old 03-20-2013, 08:24 PM
camduke22's Avatar
camduke22 camduke22 is offline
Noob!
Need help. 304 to t18 hook ups
Hey, I have a 1974 J10 with a not original 304. I am switching from a t-15 mated up to a d20. I will be installing in a t-18 back to that d20. I am looking at replacing the flywheel, clutch and clutch plate fork and fork bearing and throw out bearing. If you were doing a dream build what parts would you use? its the 131' wheel base just to throw that out there. I just wonder what parts would you use? Thank you for all the advice
Old 03-20-2013, 10:01 PM
If you are building the motor, have it zero balanced so the flywheel off a six will work.
Old 03-21-2013, 03:58 AM
zero balancing is spending a lot of money needlessly.
the flywheel you have is fine,have it surfaced,and ring gear put on if needed.
centerforce makes a nice clutch. Zoom makes a decent cheaper clutch.
Old 03-21-2013, 08:32 AM
goldhammer's Avatar
I run a centerforce II in mine with the 360/18 combo. Stiff pedal, but I've never looked back on the choice.
Art
ASE Master Collision Tech
Old 03-21-2013, 09:48 AM
Cecil14's Avatar
Cecil14 Cecil14 is offline
Luk gold clutches are good as well, and much cheaper than centerforce.
Got for an 11" clutch as long as your flywheel has both sets of holes (you'll know if there are two patterns of clutch holes).
aa
Old 03-21-2013, 04:38 PM
camduke22's Avatar
Noob!
Thanks for the advice guys. Since i am going to have everything off already i am thinking about going to a hydraulic clutch linkage. Would any body suggest against that? Also where do i go to get a flywheel surfaced?
Old 03-21-2013, 05:02 PM
most automotive machine shops will do it.
i see no issues with stock linkage in most cases.
Old 03-21-2013, 06:25 PM
Cecil14's Avatar
Brake boosters tend to be in the way of clutch master cylinders on our rigs. I'm running hydroboost and have enough room for my master, but I don't know how you'd squeeze it in there with a stock vacuum booster.
aa
Old 03-21-2013, 06:28 PM
camduke22's Avatar
Noob!
I did some measuring and it looks like if i just welded a small piece of metal pointing towards the left it looks like i could fit it in right there. I see hydro-boost kits. Is it just worth upgrading to that?
Old 03-21-2013, 07:02 PM
Elliott's Avatar
Elliott Elliott is offline
Cowboy Up
Hydroboost will add about 1,000 psi to your line pressure at the caliper You can't match that with any vacuum booster.
Old 03-21-2013, 07:12 PM
J20 project's Avatar
I have to agree that replacing the flywheel is pointless. Not sure where the 6 cyl stuff came in here. Using the 304 flywheel w/ a diff trans, right?
Even if changing engines from 8 to 6,,just get the right flywheel.
Resurface, reuse.
Don't necessarily see where a hyd clutch gains anything.
J20 project
BP Drivetrain...........
775-537-7918
Old 03-21-2013, 09:11 PM
camduke22's Avatar
Noob!
Alright Elliot, what would a kit cost me? I am a man on a budget with lots of projects. I read your posting on the brakes but its hard to break down what i need.
Old 03-21-2013, 09:16 PM
Woodchomper's Avatar
Woodchomper Woodchomper is offline
If your engine is a 1970 or 71 you will need a different pilot bushing. The 70 and 71 engines also have a different flywheel if you end up replacing that. Bottom line is, since your engine is not original you may want to verify what parts you need before you make any orders. If memory serves me correctly 72 was the year that the crankshaft flange changed.
1991 GW 401 /727TF/NP229 /4" Skyjacker /EBL TBI /CS-144
1981 J10 401 /727TF/NP208 /6" Superlift /CS-144
Old 03-21-2013, 09:26 PM
camduke22's Avatar
Noob!
The only numbers i can find on the engine is 304, where could i look to figure out the year?
Old 03-21-2013, 09:30 PM
Build code is stamped on a metal tag attached to the pass side valve cover.
First digit is year: 4 =71, 5=72 etc.
Old 03-21-2013, 09:38 PM
camduke22's Avatar
Noob!
Inside or outside? i dont see a tag evident? near the back or front?
Old 03-21-2013, 09:55 PM
Cecil14's Avatar
Assuming the tag still exists and is correct for the motor. The crank should have a casting number on it as well. Inside the pan, likely.
aa
Old 03-21-2013, 10:14 PM
Scroll down the page to the pictures of the two different crankshaft flanges. The differences are obvious.
http://theamcforum.com/forum/v8-flyw...388_page2.html
military tire hook up Hutcho General FSJ Discussion 19 06-16-2011 11:58 PM
Simple rear tow hook mounting? DanHS Off-Road FSJ Tech 4 03-28-2011 05:58 PM
where to hook up electric choke + wire Jeepguy77 General FSJ Discussion 16 08-03-2009 07:34 PM
Tow Hook Options jpsterluvr Off-Road FSJ Tech 5 05-28-2007 10:10 AM
HEI module hook up (JYG, help) AMSting General FSJ Tech 11 10-10-2006 12:28 PM
