Old 02-01-2013, 08:30 AM
bigblock91 bigblock91 is offline
Looking at the post about the 92 dodge cooler row say it has 3 inch ports.. I'm seeing 2.5 on the tape.. did anyone else notice that? Maybe one of these days I'll get the oil burner bug and head down this road. For now the big block will have to do
Old 02-01-2013, 08:31 AM
jeepmj_tj's Avatar
jeepmj_tj jeepmj_tj is offline
I used a 92 intercooler on my swap. fit pretty good. only had to do minor trimming on the inner fender for the tube clearance. But this cutting allows for easy access to the t-bolt clamps for the boots at the intercooler tubes. I am running the stock V8 radiator and the intercooler sits in front. I did have to trim the grille valance similar to resbum but not as much. I am running a final type grille at the moment with tons of room behind it for additional items like an AC condenser that I hope to add before this next summer.
01 TJ-Trail rig
91 MJ-Play toy and work horse
79 J20 Tow Rig- Cummins 6 cyl, DD since 07
Old 02-01-2013, 09:46 AM
ross80truck's Avatar
ross80truck ross80truck is offline
Yeah, I agree with you on the 2.5" port size. I never even saw the note until you posted it.
Life Priorities:
1. God
2. Wife
3. Children ( Lane )
4. Work
5. Wagoneer
Man it is hard to keep them in the right order!
Old 02-01-2013, 10:24 AM
rwjohnstone's Avatar
rwjohnstone rwjohnstone is offline
My bad, I was posting all of that from my phone, it has been edited, sorry guys!
"Decide what to be and go be it." - The Avett Brothers
1964 J-200 "Alice" Build Thread:
http://www.ifsja.org/forums/vb/showthread.php?t=150066
1979 CJ-7 (s) - Status: Dismantled Hibernation
1981 J-10 - Status: Parts? Daily Driver? Lawn Ornament?
1993 Cherokee Sport - Status: Sold (408,000 miles)
Old 02-19-2013, 04:59 AM
Swampfox89 Swampfox89 is offline
I am in the process of fitting an intercooler into my J truck right now, I have a 1st gen Dodge intercooler I have been trying to work with. I know it can be done, very similar to Rebum's 2nd gen install. I am tempted to find a 2nd gen cooler after seeing his success. My problem right now is that I am trying to use a mechanical fan from a 1996 Dodge on my motor, it puts the fan too close the the radiator. I am having a custom aluminum radiator made, and before it is made I am debating on pushing it forward 3/4" or so to clear the fan. If I do this I am losing room on the other side between the razor grill I am going to use and the intercooler. On top of this I would like to stuff my AC condenser back in there too. I have looked at after market condensers, being I could get smaller ones than the factory one I have, which would probably all work...
Other option is go electric fans, keep the radiator in the stock location, stuff the 1st gen intercooler in there with the ac condenser in front. Easier, but I don't have electric fans, so more $$$.
Thoughts on this? Pictures of a 1st gen intercooler installed?
Here are a couple pictures of a stock V8 radiator with the dodge mechanical fan installed. It is so close it hits the bottom tank. It also interferes with the bottom outlet on the radiator and the tranny cooler fittings, but this doesn't matter being the custom radiator will not have them there.
Thanks.
Old 02-19-2013, 08:34 AM
Resbum's Avatar
Resbum Resbum is offline
Wow, that fan is scary close, isn't it.
I've been sitting here with my morning coffee thinking of "no more cost" options. The biggest obstacle to that I keep running into is your wanting to keep your A/C. I hate to say it, but I keep coming back to an electric fan(s) setup is going to be the cheapeast and least complicated way to meet your needs.
Some other good reasons came to mind about the electric fans:
1- Much easier to change the serpentine belt
2- Run quieter than a mechanical fan
3- Not really and issue for the 6BT, but less HP loss
4- The ability to switch the electric fan off for deep water crossings
I'm pretty sure in trying to keep the mechanical fan the expendables and materials needed for the extra mods would get you a fair way towards the cost of the electric fan(s).
I'm interested in seeing what you come up with.
Resbum
Originally Posted by Resbum
"What year is my truck?... Which part?" Build thread- http://www.fsjnetwork.com/forum/view...p=18290#p18290
Old 02-22-2013, 06:03 PM
loosewrenchcowboy's Avatar
loosewrenchcowboy loosewrenchcowboy is offline
I dont see in this thread which year engine your using, but the 89-93 dodge truck engine uses a different fan/pulley/mount than the 94-up. if u have a 94-up motor, switching to the 89-93 dodge cummins setup will gain u just shy of 2 inches more room between the fan and radiator.
Old 02-22-2013, 06:28 PM
how about this intercooler? sorry its upside down.
Old 02-22-2013, 06:32 PM
photo #1: the intercooler fits inside the core support uprights, between the fascia and "core" support
photo #2:minor grinding/opening of the factory hole in core support to clear 2 inch tubing(intercooler is 3 inch inlet/outlet)
photo #3:view from passenger side-the red cap u can just barely see is the dust cap on the intercooler during installation.
Old 02-24-2013, 08:51 AM
What's the intercooler from? Source? Part Number?
Old 02-24-2013, 09:18 AM
trickc's Avatar
trickc trickc is offline
Have you considered a dodge caravan electric fan in there? with minor trimming it fits. I run them on 2 of mine although Ive got stock amc motors though but they do a good job, only cost me about $30 at pull a part.
73 j-4000 "buttercup"-SOA 36's 4 door cab
78 wagoneer choptop-SOA 36's, 6 point cage, blah blah blah
Old 02-24-2013, 01:53 PM
swapfox
i got 3 of them from a local diesel performance repair/fab shop i know. he has done serveral weird cummins swaps(el camino is one). he is unwilling to share his source/supplier(BUSY small shop, 3 guys, and no time to spend doing mail order stuff i assume), but the price is fair, and they are good quality. i bailed out on one of the diesel jeep swaps i was gonna do, so i have a spare intercooler if ur interested in it. i paid 250$, so probably 275$ shipped to ur door. there is a jeep restoration shop that sells an intercooler very similar to what i have, but they want 400$.
the other jeep: cummins m725 camper i"m doin for the family:
com/albums/ae55/ewa02/Camera19.jpg[/IMG]
Old 02-24-2013, 01:54 PM
pic
Old 02-24-2013, 01:55 PM
pic
Old 02-24-2013, 06:38 PM
Mikel's Avatar
Mikel Mikel is offline
Oooh... I like
1969 M715 6x6
1963 J300 Swivel frame
Old 02-24-2013, 08:55 PM
oops
I didnt realize the pics were gonna be that big. And i kinda hi-jacked the thread. My apologies, sorry.
Thanks mikel
Old 02-28-2013, 04:27 PM
Tigger4X's Avatar
Tigger4X Tigger4X is offline
I remember seeing a really sweet install of an intercooler on here somewhere.
Search for "Project Humpty" ... I believe its a few pages into the thread.
Originally Posted by will e
Old 02-28-2013, 05:31 PM
jMedia's Avatar
jMedia jMedia is offline
Here ya go....
http://www.ifsja.org/forums/vb/showp...1&postcount=38
Joshua
Constantly changing, never done
Old 02-28-2013, 06:19 PM
Tigger4X's Avatar
Thumbs up
Originally Posted by jMedia
Yeah buddy Thanks JMEDIA! That's what I was referring to.
If I ever get to do a Cummins 6BTA this'll be how I run mine.
Old 02-28-2013, 07:18 PM
poolmike poolmike is offline
Here's the Mishimoto that had installed in mine. I went with a slightly thicker wall plumbing since it is running in the wheel area, taking some abuse.
'68 M715, Cummins P-pump 5.9, NV4500, NP205, 14 bolt/Dana 60, 20x10 American Racing Mojave's w/12.50R20 Michelin XL's, relentless rust....
Intercooler in an FSJ sporting a 4BTA zmjeeps Diesel Swaps 48 08-23-2017 09:06 PM
wagoneer options kahula General FSJ Discussion 14 07-03-2011 01:44 AM
factory color options for 64 Jeep Gladiator / Wagoneer???? Jeepster4ever General FSJ Discussion 4 02-21-2011 05:56 PM
Please school me on tcase options? shimniok Off-Road FSJ Tech 5 05-30-2007 09:25 AM
4lo options? AlsChopShop Off-Road FSJ Tech 7 05-26-2006 05:51 PM
