  #141
Old 05-26-2011, 09:17 AM
Elliott's Avatar
Elliott Elliott is offline
Cowboy Up
Finally...
Mocked up a firewall plate for the single flange hydroboost mount to fit the '62-'66 Jeeps. Pics coming soon
*** I am collecting pics and info on any factory Jeep Dually trucks from the J-Series at the new Jeep Dually Registry.
***I can set you up with hydroboost for your brakes: http://www.ifsja.org/forums/vb/showthread.php?t=106056
Old 05-30-2011, 08:11 AM
Elliott's Avatar
Cowboy Up
Here is the '62-'66 FSJ single flange hydroboost mount that will fit brake rod lengths between 3-4" using an adjustable brake rod end:
Old 05-30-2011, 09:00 AM
Chevelleguy's Avatar
Chevelleguy Chevelleguy is offline
I really need to pull the trigger on this upgrade. Had a panic stop the other day that required two feet on the pedal, and I was only rolling about 20mph. It still took about 15ft to come to a stop. Not a good feeling.
David "If all else fails, read the instructions."
83 Wag Lt,BJ's 6"lift,360/727/Pinned229,D44/trac-lok,AMC20/lock-right,35/12.50 Baja MTZ,Pro-Jection EFI.
10$ NP229 fix http://www.ifsja.org/forums/vb/showthread.php?t=2520
Old 06-14-2011, 07:13 AM
Elliott's Avatar
Cowboy Up
'75 IH Series 150 hydroboost
Here's a new one about to be test fit for an IH truck. It mounts to the existing booster brackets on the firewall and couples with the OEM brake rod when setup like this:
Old 07-06-2011, 07:49 PM
Elliott's Avatar
Cowboy Up
'68 Roadrunner hydroboost
Here's a new one for y'all.... shipped to Austria for a test fit
Keep the custom work coming to me folks. I'm relocating but I'll be keeping up this work so you can reach me at sterlingworth16 at yahoo dot com
Old 07-23-2012, 11:05 AM
james cowger's Avatar
james cowger james cowger is offline
Noob!
hydroboost
are you back to building the hydro boost units? if so, i have 77 j10 in need of one. let me know if you are. ljcowger@hotmail.com thanks
77' J10 GM 350 Th400 np 205... Soon to be SM465 np 205
Old 07-23-2012, 11:26 AM
Elliott's Avatar
Cowboy Up
Hi James, Yes I am and I have a thread here in the Homegrown Vendor's section of our for sale listings (the link is in my sig). Sent you an email.
I've done a bunch of new mounts for various applications so if anyone is interested just send me an email or ask here. Some of the new stuff is the C2 Vette, '97 Camaro, ~'82 Toyota FJ 60 series, etc. Currently working on a '62-7 Nova mount.
Old 04-27-2013, 08:20 AM
Elliott's Avatar
Cowboy Up
Ok, so it's been awhile since I posted here regarding the hydroboost mounts kits I put together so I'm going to update folks. The original kit had two plates that welded at opposite ends of a center tube and one plate matched the firewall and the other plate matched up with the flat plate on an early Astro van like this '67-'73 FSJ M715 mount kit shown here:
I have a similar mount kit listed on ebay for the CJ/YJ. The three plate kit gives you a replacement plate for whatever plate you have on most any hydroboost you can pick up and it allows you to simply unbolt from the firewall part of the mount to invert the hydroboost.
Now, not all hydroboost will be compatible for the simple reason that not all hydroboost have a brake rod you can either thread 3/8-24 for an adjustable rod end or because the section near the hydroboost is necked down so you can't thread up far enough to keep your brake rod short enough so the tube section of the mount isn't over 3". I'm not cutting any tube for these kits over 3" because 1) you aren't going to like the look of the install and 2) it creates a lot of leverage on the mount to have a iron MC sticking out past the hydroboost that far, then 3) some rigs won't have that much room in front of the booster to have it stick out that far. This is a pic of a typical GM truck HB brake rod that isn't going to work in a lot of short brake rod applications. It will work for the FSJ however. If you want to use that HB/brake rod in something else please ask me about your vehicle. The '80s-'90s GM truck/surburban brake rod pic:
This F350 hydroboost brake rod isn't something you can thread unless you have a super short application or are going to fit a coupler with jam nuts to use a longer rod:
If you aren't buying an early Astro van HB for your rig then consult me first before you buy something that won't be compatible.
Here is a pic of a three plate '74+ Jeep (mounts to your aluminum firewall block) and Jeep TJ kit showing the HB plate installed so you can see how things will match up: (if using a stepped down rod the tube will a little longer)
This is a pic showing the firewall part of the mount welded up and painted:
This is the '67-'73 FSJ and M715 hydroboost mount kit used when the brake rod attaches to the passenger side of the brake pedal:
This is the '67-'73 FSJ and M715 mount kit used when the brake rod attaches to the passenger side of the brake pedal (requires one 3/8 hole be drilled in the firewall to tie in the pedal assembly):
Even if you have an early Astro hydroboost you may want to swap out the mounting plate and go with this three plate kit I have as the HB plate is smaller in size and makes for a cleaner looking installation. Here is a comparison:
'74+ FSJ owners.... don't worry, it doesn't have to be so complex for your installs and minimal welding is required. If you have an early Astro unit it just requires some brake rod hole sizing/bushing and a 1" spacer built from flat stock, and welded, to fit between your aluminum firewall block and the OEM square hydroboost mounting plate.
Questions?
I can put together hydroboost mount kits for just about all of the different hydroboost setups for the various rigs I have listed on ebay at: Sterlingworth16
If you have something else in mind then please run it by me and you can reach me at sterlingworth16 at yahoo dot com
DON'T PM ME HERE...
Check out installs and tech at: www.custompowerbrake.com
Old 04-27-2013, 05:04 PM
Elliott's Avatar
Cowboy Up
I edited the above link showing the three plate kit will work on a '74+ FSJ if you are using a GM HB with the stepped down rod. You will need to cut thread the rod for a adjustable end like the one shown.
Old 05-08-2013, 09:20 AM
swampedge's Avatar
swampedge swampedge is offline
Elliot, I need another HB set up but, for my 70 j2000 I put the 454 in. Can you pm me the number to reach you at as I no longer have it in my new phone. Or let me know how much and where to send the cash.
Thanks: Jim
1970 Gladiator with a 350, a/c and a PTO winch.
You really are judged by the dogs you have!
Old 05-08-2013, 10:00 AM
Elliott's Avatar
Cowboy Up
Emailed you. I can be emailed at sterlingworth16 at yahoo
Thanks
Also, if anyone has a Toyota 4 Runner... say 2003+ with the electric master cylinder... I have a prototype hydroboost set up being tried out so these should be available. It requires going to a GM MC and adapting the existing brake lines to the ports on the GM MC but I can refer you to a source for adaptors. I will post pics of this when the guy verifies everything fits up well.
Old 05-08-2013, 10:01 AM
Elliott's Avatar
Cowboy Up
Working on a Land Rover Defender 90 hydroboost application.... stay tuned.
Old 05-18-2013, 05:21 AM
Elliott's Avatar
Cowboy Up
2003+ Toyota 4 Runner Hydroboost
This hydroboost replaces the $1,700 electric master cylinder. Shown installed on a slammed '03 4 Runner.
Old 05-18-2013, 05:37 AM
Elliott's Avatar
Cowboy Up
European Toyota J7 Series Hydroboost
Here is one for our European friends, a '84+ Toyota J7 Series unit:
Old 05-18-2013, 05:43 AM
Elliott's Avatar
Cowboy Up
Going to finish an install on a '64 Dodge Polara 500 today. Guy has a big block so it will requires rotating the hydroboost and adapting the MC to the rotation. This will fit the '62-'65 B and C Body.
Old 07-16-2013, 05:57 PM
Elliott's Avatar
Cowboy Up
Ok, That guy's Polara rocks... pics of the completed install are coming.
I have a new mount figured out should fit in the '64.5-'66 Mustang and working on the '67-'70.
Somebody want to test fit this? Or I can find a local hot rodder...
Old 07-16-2013, 06:53 PM
I've got a '68 Mustang can help you if needed?
It's a blank slate right now, firewall is bare.
Booster is in the trunk I think?
Old 07-16-2013, 06:57 PM
Elliott's Avatar
Cowboy Up
Ah great, the last measurement I need is from the two bolt holes opposite the 2" center hole through the firewall down to the bolt hole below directly under the 2" hole. It's either 2.1" or 2.3" from what I can tell and likely 2.3". The rest of it I have all mapped out. Post it here if you like or email me at sterlingworth16 at yahoo dot com
Thank you sir!
