Old 06-27-2020, 01:09 PM
stonehengeheels's Avatar
stonehengeheels stonehengeheels is offline
Tailgate Key Switch Removal for new Woodgrain
How do I remove the key switch so I can lay down the woodgrain and then cut it. I tried knocking out the security pin in the middle of the 2 screws but couldn't do it. Any suggestions?
Thanks.
Steve
'87 GW (Totaled)
'90 GW (Under renovation)
'00 GC Laredo (Totaled)
'02 GC Laredo (Sold)
'67 Dodge Coronet Convertible 440/727/3.55
Old 06-27-2020, 07:38 PM
Driftwood's Avatar
There's a tool for that. Harbor Freight, Autozone, etc.....carries the tool. I have 2 or 3 of them here in the garage.
1979 Wagoneer
Old 06-27-2020, 07:42 PM
Driftwood's Avatar
Amazon has them too. Here's the link.
torx screwdrivers set, security tamper proof
1979 Wagoneer
Old 06-27-2020, 09:22 PM
That "pin" is not a pin, it is part of the fastener. There is a bit called a "Tamper Proof Torx" bit that you will need to remove the fasteners.
-Jonny B.
AMC 401 - Pro-FLo 4 FI
F D44 - 4.10, Eaton E-Locker
R M23 - 4.10, Detroit Locker
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
Old 06-28-2020, 02:09 PM
Thanks! Will order a set today.
Steve
'87 GW (Totaled)
Old 07-07-2020, 09:54 PM
jeepman42 jeepman42 is offline
Hopefully your key switch is now off and woodgrain ready? /installed?
There is a good U Tube video under Installing GW woodgrain. Shows dry technique & worked well on my '85 two weeks ago.
You could actually install without key removal by trimming around key bezel but not so "professional".
Video used TGW vinyl but I like Metro's 3M product better.
Good luck with your install.
Old 07-12-2020, 05:00 PM
Torx bit worked great thanks. Woodgrain next and I will view that video first. Thank you.
Steve
'87 GW (Totaled)
Old 07-13-2020, 08:53 AM
aktrapper aktrapper is offline
Do you have a link to the 3M product? Is it pre-cut to fit a GW or cut-it-yourself deal? I couldn't find anything like it. TIA
Certified Novice Mechanic...
89 Grand Wagoneer (AMC 360/TF727/NP229)
A work in progress!
Old 07-15-2020, 07:55 AM
Go to wwwMetrorestyling.com
use upper right bar - search store-Put in -vinyl wood . should come up w selections
comes in sheets, but they have a 15" width as long as you need. I figured 35' for a complete GW. 15" is a correct width for the side panels.
they have a red teak, but not red oak. Also have marine teak.
Order samples first as Team GW,metro,& others all look different.
Likes Metro because looked more like wood with a satin finish whereas TGW has a shiny printed look.
Cost for precut sets almost double!
Lastly, get 3M dinoc. My off brand has faded badly in 5 yr.
Removing tailgate window and switch? PaulD General FSJ Tech 13 07-21-2017 03:21 PM
Replaced Rear Window switch in tailgate... puckettj General FSJ Tech 5 09-20-2011 10:57 AM
Repairing the tailgate switch - You can do it too! Jeepster226 General FSJ Tech 8 08-28-2010 11:29 PM
Tailgate dash switch blakviper General FSJ Tech 12 07-01-2010 10:47 AM
Please help. Tailgate is baffling me. JINGA General FSJ Tech 8 07-03-2001 01:26 AM
