Old 05-21-2004, 07:32 AM
robselina robselina is offline
Originally posted by KYJ10:
Ran two belts and it not only improved speed, but also made it finger turnable! Dennis
Thanks for the info man! Gonna have to mess with that!
Rob
Old 05-21-2004, 07:48 AM
The Donzi The Donzi is offline
Great writeup Rob !!
I am running hydro assist as well and I just did the mods to existing power steering pump and I definitely notice a difference. It feels like it has sped up alot compared to before, but sometimes still a little slow in tight turns. I drilled out the center pin and notched it like shown on this site: http://westtexasoffroad.homestead.co...rsteering.html I also am running a power steering cooler from an explorer. Works great and lets me run some extra fluid too...
1979 Cherokee Chief <br />360,400,1339,44,14ff,SOA,<br />Hydro assist,44044\'s, 63\" chevy rears, Dual electric fans, 35\"SX\'s on hummer rims Rhino lined interior, f/r reciever hitches, Warn 9000i<br />Edelbrock intake, truck avenger<br />Engle cam, chopped, caged
Old 05-21-2004, 07:54 AM
KYJ10 KYJ10 is offline
You can ask around here and someone will have a dual groove pulley. I found mine locally. My 88 had daul pulleys, both the same circumference. One ran the air pump. Dennis
Starting to miss the addiction!
Old 05-21-2004, 01:13 PM
Elliott's Avatar
Elliott Elliott is offline
Cowboy Up
Originally posted by robselina:
</font><blockquote>quote:</font><hr />Originally posted by Elliott:
There's a slick little cooler for such a system that will give you a remote resevoir. I'm fixin to do this and add a hydroboost as well.
got a part number and source for that? Sounds interesting....</font>[/quote]This is it: http://www.4x4wire.com/toyota/tech/steering_cooler/
Ought to be just the ticket for hydraulic winches too!
~$50. at: http://www.secureperformanceorder.com/onlinestore/getproduct.cfm?CategoryID=6&ClassID=256&SubclassID =1258&ProductID=5190
[ May 21, 2004, 07:30 PM: Message edited by: Elliott ]
Old 05-23-2004, 02:46 AM
A quick update:
didn't manage to get the pump mod done yet, I'll need to replace my high pressure line out of the pump since its shot and I'll have to cut it to remove it.....I looked into what dennis was saying about dual belts and it turns out it'll be an easy mod for me
As you can see, I need to pick up the belt but I've got the dual pulley already. Must have been used on the rigs with AC, since I don't use my compressor right now(it's fried)
I also rigged up a skid out of some scrap 1/4" steel. It's sort of an odd angle I took the pics at, but it's level with the bottom of the housing and then comes up 45 degrees infront of the ram.
Rob
Old 05-23-2004, 02:47 AM
Elliott, that's pretty trick, thanks for the links!
Rob
Old 05-23-2004, 07:18 AM
Yea, I think all the balancers and pulley for the coolent pump are 3 groove. So just find a dual for the steering, and your done. I also did it with my alternator, casue it is a 105 amp and had trouble when the fans kicked in. Also worked great. Dennis
Old 05-23-2004, 07:45 AM
Elliott's Avatar
Cowboy Up
Yep, first time I saw that cooler I was thinking it would really help if I was to use a Milemarker hydraulic winch (they only weigh about 65Lbs, probably w/o cable).
Still be interested to know if the high pressure pump is compatible with hydroboost brakes... if anyone knows?
Old 05-23-2004, 08:09 AM
mcinfantry mcinfantry is offline
id like to know too!!! i have HB, and a ram... i need to hook the ram up this week.......
1942 Dodge WC53 (replaced my m715)
under the knife!
4bt, 4l80e, nv241
d60/14b 4.88gears w/ arb's
michelin 1100x16xl's
Old 05-23-2004, 08:58 AM
Glenn_tx Glenn_tx is offline
Elliot, you figure a little tranny cooler would work also if it was hooked up to the low pressure return hose?
Glenn<br /><br />-I\'d rather be a fencepost in Texas than the king of Tennessee!
Old 05-23-2004, 09:01 AM
isuzu cars and trucks have what appears to be a 12-16oz remote resevoir...
how necessary is a cooler over just more capacity
under the knife!
4bt, 4l80e, nv241
Old 05-23-2004, 09:04 AM
I have never had any problems w/ lack of fluid or everheating, but I've only wheeled w/ my hydro assist a few times.
Old 05-23-2004, 09:37 AM
Elliott's Avatar
Cowboy Up
This is probably the same thing, 1/2 the price, but will have less capacity: http://www.noid.org/pscooler/
I've got a manual trans and an auto radiator, thought about cooling my ps fluid in the radiator, but don't know how well those worked.
[ May 23, 2004, 03:39 PM: Message edited by: Elliott ]
Old 05-23-2004, 02:40 PM
the only thing you have to watch out for with trans coolers is that some aren't set up for this kind of flow. If it looks like a radiator, it's no good, if its a big 'S' with fins attached, it's perfect for this.
BTW - got to try this out on a real wheelin' trip today, LOVED it. This ram was one of the best investments I've made on the heep...
Rob
Old 05-26-2004, 12:11 PM
just a quick update. I did the dual belt mod, with two new matched belts. Also did the hi-pressure mod to the pump. Feel absolutely, positively....no difference
Not saying these mods don't work, just that they didn't do anything for me. Just an FYI...
Rob
Old 05-26-2004, 01:17 PM
Elliott's Avatar
Cowboy Up
Well, the dual belt is only going to keep the pump from chirping when the single belt slips.
AGR makes a high pressure pump, but don't know what it accomplishes that the modification doesn't.
