Old 12-23-2018, 10:44 AM
Stupid question: E2000 pump, which side is the inlet?
Just got my pump and it is not labeled inlet or outlet, no arrow either. Looking at pictures on google I don't get a good idea either.
Is the inlet the side with threaded end and the outlet the side with the electrical connectors?
Old 12-23-2018, 01:23 PM
In EFI pumps generally it is the outlet side that has the wiring connections.
Old 12-23-2018, 02:27 PM
Tripwire's Avatar
Tripwire Tripwire is offline
on both of my pumps there was a small brass screen on the inlet side....course you could put a piece of tubing on one end and jury rig it to a battery to tell which is in/out?
Abort? Retry? Ignore? >
Old 12-23-2018, 03:38 PM
copy all. Thanks gentlemen.
Carter Fuel Pump Install my experience KdkGrizz General FSJ Tech 5 07-29-2016 05:21 AM
Fuel pump question... j20brett General FSJ Tech 9 03-06-2007 02:10 PM
help with inline fuel pump. Sgt Rock General FSJ Tech 5 03-30-2005 12:33 PM
Stupid water pump question? Green Giant General FSJ Tech 2 03-06-2003 05:27 AM
Air pump aka "smog pump"....to remove or not to remove- THAT is the question. Iron Horse General FSJ Tech 8 06-27-2001 06:15 AM
