Old 03-21-2009, 04:57 PM
AnnieL's Avatar
AnnieL AnnieL is offline
How much Freon (r12) if mine if empty?
Hiya everybody,
Can anyone tell me what is the total capacity if I need to completely recharge my AC? (89 GW)
I do have an EPA cert, so not worried about locating some, just wondering how much I should plan on needing-IF it's empty. I'm going to have it checked out by an AC guy to make sure I don't have any leaks, etc. before I do this. And no, I am not interested in retrofitting!
Thanks!
~AnnieL ~
"I think, therefore I'm single.”
Director: Mojave Desert Animal Rescue
http://www.AnimalResQ.org
~'89 GW- "Harsh Mistress " BJ's 4 Inch Lift, 31" Bridgestone REVOS, Quick Disconnect Swaybars, Pro Comp shocks...and...crappy paint!
Old 03-21-2009, 06:03 PM
mattmopar440's Avatar
Thank god some who doesn't Like R-134A to
It will take Just over a Pound of freon to fill the system full or 2-3 small 8oz cans
If you cant find R-12 I recommend the next best thing is HotShot (R-414B) a direct replacement for R-12 no PAG swap. also it's alot cheaper and easier to find due to they can still legal make it in USA
http://www.icorinternational.com/hotshot.html
87' Grand Wagoneer
80' J10 4BT/AX-15/208
74' J10 Go Grabber Green Sold
Inferior Chevy
Old 03-21-2009, 06:27 PM
AnnieL's Avatar
Thanx Matt!
LOL! NO I do not like 134A and I am not gonna go through all the necessary headache to try to convert over. I've seen some master disasters-I got enough to worry about with my rig as it is, and I am not gonna invite any trouble to reside under the hood.
I have my EPA cert and I can easily get it several places-
If I have a leak someplace I intend to get that straightened out first, I'm not in the mood to go through this twice! I haven't used the AC ever-
I turn it on and it blows OK, but its warm.
Annie
~AnnieL ~
Old 03-21-2009, 06:34 PM
well have the pressurize it with nitrogen up to max system pressure and check all the fittings for what the cost have them replace both schrader cores there cheap and most leaks start there have them pull it into a 500mic vacuum and if it holds charge it
87' Grand Wagoneer
Inferior Chevy
Old 03-21-2009, 07:42 PM
Lindel's Avatar
Lindel Lindel is offline
Perfesser of Jeepology
Annie, do you have a 609 cert? That's what you'll need to have to buy R-12.
The regular cert doesn't cover automotive.
Jeep Grounds
RRV Homepage
1987 Grand Wagoneer
AMC 360/TF727/NP229
1999 Wrangler Sport
4.0L/AX-15/NV231
Old 03-21-2009, 08:03 PM
AnnieL's Avatar
Hi Lindel,
Yup, I sure do. Section 609 MVAC Certification.
IF I have problems with hoses or fittings, where's the best place to go get replacements? (I'm really hoping for no problems there, but if a problem DOES arise, I want to be prepared!)
~AnnieL ~
Old 03-21-2009, 09:03 PM
Dude, do you just make up answers?
Capacity on a stock 86-91 R-12 equipped GW is 2.25lbs (2lbs for 6cyl)
Old 03-21-2009, 10:40 PM
Really I must of done the OZ to Lb conversion wrong
Book only list it in OZ
87' Grand Wagoneer
Inferior Chevy
Old 03-21-2009, 11:59 PM
BarryL's Avatar
BarryL BarryL is offline
16 ounce to a pound. You probably used 32. Common mistake since we use ounce for both weight and volume.
'84 Wag, 360, 727, 229, stock 177k
Old 03-22-2009, 05:59 AM
Lindel's Avatar
Good deal Annie. The price of R-12 has come down a lot in the last couple of years.
Now, if you've got, or have access to a vacuum pump and a bottle of nitrogen, plus a decent micron vacuum gauge, you'll be in good shape.
Jeep Grounds
RRV Homepage
1987 Grand Wagoneer
AMC 360/TF727/NP229
1999 Wrangler Sport
4.0L/AX-15/NV231
Old 03-22-2009, 09:30 AM
HARDCORE pacer's Avatar
HARDCORE pacer HARDCORE pacer is offline
Why not use the redtek stuff.
78 pacer on 75 chero frame thats shortened 10\" and shackle reversal, D60 front with spool,14ff with detroit locker 4.56s in both,500 hp/500 ftlb torque 401,built 727,208 to divorced 205 doubler,on 46x21 ag tires
78 cj 360, 3spd, scout 44s with detroits SOAed with 36"tsl and beadlocks
Old 03-22-2009, 09:32 AM
just find a local Hvac guy that can do if for you as a side Job
That way it will only cost you a case of beer
87' Grand Wagoneer
Inferior Chevy
Old 03-22-2009, 01:29 PM
Lindel's Avatar
cuz if he ain't got the 609 cert, he can get into a world of financial hurt!
Jeep Grounds
RRV Homepage
1987 Grand Wagoneer
AMC 360/TF727/NP229
1999 Wrangler Sport
4.0L/AX-15/NV231
Old 03-22-2009, 11:23 PM
AnnieL's Avatar
Lindel, I only know one HVAC guy and he only does residential...so I guess I'll fork over to have it tested. Those aren't items I have sittin' around.
But the way I look at it, that's OK, it'll still cost me a lot less than going through all of that retrofitting stuff...I'm seeing some decent prices-some people who think they have the only can in the world-othesr not so bad...
What's redtek?
~AnnieL ~
Old 03-22-2009, 11:28 PM
he doesn't have an Mic gauge and a vacuum pump ??????
87' Grand Wagoneer
Inferior Chevy
Old 03-22-2009, 11:37 PM
AnnieL's Avatar
He probably does, but he's a real snot, and I'd rather pay than have him touch ANYTHING I own!
~AnnieL ~
Old 03-22-2009, 11:41 PM
AWW OK try to becareful when guys here R12 the get $$$$ eyes
87' Grand Wagoneer
Inferior Chevy
Old 03-22-2009, 11:54 PM
AnnieL's Avatar
Oh believe me, it's the same thing here-I'm in the middle of the Mojave Desert. If anyone thinks they can gouge me on AC work, its out here where I live. (I know, I tried last year for the heck of it, and the lowest "recharge" estimate I got was $339.00 plus tax.) That included nothing but the R-12.
Twice I got the "where's your husband" question, and then when I said I don't need one of those, you could literally see thier eyes light up. (ooh, I can charge the socks offa her!)
These people must think I just fell off of the local turnip truck! ("Oh ma'am that stufff is SO rare, we MIGHT be able to get you enough, but it's going to be X dollars for labor, and then X dollars for the refrigerant.")
All these guys think they're going to charge me $150+ per pound to filler' up? Not in this lifetime...
That's why I just plan to get her tested first, and THEN drag out my own cans.
(Shame on me...NOT!)
~AnnieL ~
Old 03-23-2009, 04:58 AM
Lindel's Avatar
Annie, when you get some spare change, a decent vacuum pump is about $300, a micron gauge will run from $50 to $200 and I'm not sure what the going rate is on nitrogen is.
Bottom line, you can get the parts you need to do most of your own work for well under $1000. Might be a lot now, but there will be a time when R-12 gets outrageously expensive again.
Jeep Grounds
RRV Homepage
1987 Grand Wagoneer
AMC 360/TF727/NP229
1999 Wrangler Sport
4.0L/AX-15/NV231
Old 03-23-2009, 09:55 AM
It's like a $50 for the tank rental and $15 for the gas that's for the big tanks tho.
87' Grand Wagoneer
Inferior Chevy
