Old 03-18-2009, 10:28 PM
badaboom's Avatar
badaboom badaboom is offline
Info on 401 numbers ?
Checked out a nice virgin 401 core today very little if any lip edge in the cylinders 4.165 std bore(gottcha)? - included, connecting rods pistons. timing cover, oil pan, valve covers and all bolts heads complete. pretty much everything except harmonic balancer- short block was asking 550 . Can anybody provide me info regarding the following numbers
crank 32204 (any gottchas regarding for a manual or auto transmission)?
block 3198951
Thanks
1981 Jeep J10 Laredo, 401-V8, 625 Carter, Lunati 262/268, Edelbrock Performer, MSD Ign., Hydroboost, Hyd. Clutch, Flow Cooler WP, Be Cool Aluminum Radiator, Doug Thorley, NV4500 5-Spd, NP-231D, 3.73 F/R Trac-Locs, Rustys 4" Lift, Vintage Red Metallic, Black Interior and 33X10.50X15 BFG, FiTech400 to come - IN PROCESS Bling Bling Cha-Ching
Old 03-19-2009, 08:42 AM
HARDCORE pacer's Avatar
HARDCORE pacer HARDCORE pacer is offline
the cranks on the 401 are the same from auto to manual. The difference lies in the production year. up to 72 they were not compatible with the 727/904 trannies from 72 on they are all the same. The difference is in the way the end of the crank is machined. The pre 72 cranks are OK with any of the std trannies.
78 pacer on 75 chero frame thats shortened 10\" and shackle reversal, D60 front with spool,14ff with detroit locker 4.56s in both,500 hp/500 ftlb torque 401,built 727,208 to divorced 205 doubler,on 46x21 ag tires
78 cj 360, 3spd, scout 44s with detroits SOAed with 36"tsl and beadlocks
Old 03-19-2009, 08:46 AM
You sure you don't have an extra zero in your bore measurements? A standard 401 bore is 4.165" diam.
Old 03-19-2009, 10:58 AM
badaboom's Avatar
401 in the making ????
Bore gotcha right 4.165 my mistake offered 400.00 see what happs.
Old 03-19-2009, 12:19 PM
AKAMC's Avatar
AKAMC AKAMC is offline
Anyone have a photo of that difference? I have a 401 I'm tearing down and don't know what year it's crank is from.
06 Rubicon Wifes toy
84 CJ8
66 Amphicar Yea it's a boat too!
08 German Sheperd
03 Golden Retriever
06 Golden Retriever
19XX Sexy Red Head loaded with all the options!
ALASKA... "Land of the Individual and Other Endangered Species"
Old 03-19-2009, 12:52 PM
Elliott's Avatar
Elliott Elliott is offline
Cowboy Up
If you have a late model flexplate laying around just see if it matchs up iwth the flange bolt pattern.
Old 03-19-2009, 12:56 PM
AKAMC's Avatar
I don't have one but I'm looking for a 401 flext plate for this engine to run in front of my 727...
84 CJ8
08 German Sheperd
03 Golden Retriever
06 Golden Retriever
