Old 03-14-2009, 09:22 PM
AKAMC's Avatar
AKAMC AKAMC is offline
V8 Cylinder head rocker style
I've been trying to find a couple photos showing the diference between the two rocker styles on V8 heads. 71 and older are a single rocker bolt style while 72 and later are a bridged style. I've found photos of the bridged type but would like to see what the factory single looked like. I hear the single is easyer to set up roller rockers on. I'm mainly intrested in how the head castings themselves differ as I have several 360 engines to choose from.
06 Rubicon Wifes toy
84 CJ8
66 Amphicar Yea it's a boat too!
08 German Sheperd
03 Golden Retriever
06 Golden Retriever
19XX Sexy Red Head loaded with all the options!
ALASKA... "Land of the Individual and Other Endangered Species"
Old 03-15-2009, 07:08 PM
HARDCORE pacer's Avatar
HARDCORE pacer HARDCORE pacer is offline
easiest way to tell is the casting # all 319 starting #s are the early heads with adjustable valve train.
78 pacer on 75 chero frame thats shortened 10\" and shackle reversal, D60 front with spool,14ff with detroit locker 4.56s in both,500 hp/500 ftlb torque 401,built 727,208 to divorced 205 doubler,on 46x21 ag tires
78 cj 360, 3spd, scout 44s with detroits SOAed with 36"tsl and beadlocks
Old 03-16-2009, 07:12 AM
Chevelleguy's Avatar
You can have the bridge style head machined for screw in studs, then you can run stud mounted adjustable rockers.
