View Poll Results: Which Header to you prefer
Headman Header 42 23.73%
Doug Thorley 93 52.54%
Edelbrock 28 15.82%
Another 14 7.91%
Voters: 177. You may not vote on this poll
Old 01-16-2008, 03:23 PM
trail mule's Avatar
trail mule trail mule is offline
Which Header?
What Header are you using? Do you like it if not what would you recomend for an amc360 with an np435 behind it? What horsepower and torque did it give you? Any Gas Mileage improvements?
Old 01-16-2008, 03:26 PM
BRUTUS's Avatar
BRUTUS BRUTUS is offline
headman because it was cheap! No noticable gains in gas mileage, HP or torque.
Old 01-16-2008, 03:32 PM
misfittom138's Avatar
misfittom138 misfittom138 is offline
I'm thinking the doug thorley. That and a flowmaster 40 series muffler. No cat on my jeep, so that should be nice!
81 Wagoneer 360/727/208, lockrite rear/welded front,4.10s, 7"SOA/shackle flip,3" body,OBA,37" Iroks,chopped,caged,highsteer,hydro assist....
Old 01-16-2008, 03:46 PM
incommando
Posts: n/a
Years ago, I had to replace the headers on my drag car ( '71 Ply Road Runner / 440) in a hurry due to a loading-it-on-the-trailer incident. I had some fairly decent hooker 2" primary headers/4" collector headers, but the only thing I could get in time was 1.75" /3.5" Dynomax Black Jack el-cheapos. They are probably exactly like Hedmans. Well, they made zero, zilch, nada difference in my 60' foot time, ET, or trap speed. And this is on a 550 hp engine. So, on most engines I don't think the "better" headers will really make a difference at all.
My concern, through experience, with 4x headers is rust through. That may not be a concern where you are, but I would recommend some sort of coated header for longevity. When I had headers on my 2A with a swapped in 225, I replaced them about every other year. Luckily they were easy. But the rust problem also occured on a 78 w150 and a CJ5.
Just my 2 cents.
Old 01-16-2008, 03:52 PM
JERSEY JOE's Avatar
EDELBROCK SHORTIES
I LIKE THE EDELBROCK SHORTIES AND I HAD MINE JET HOT COATED FOR LONG LASTING USE. I ALSO LIKE THE EDELBROCK TES SYSTEM ON A STOCK TRUCK THAT WILL USE LARGE SINGLE EXHAUST RATHER THAN A DUAL SET UP. MY CURRENT J-20 IS USING THE TES
1987 J-20 401 90% COMPLETED.
1970 AMX CURRENT PROJECT
Old 01-16-2008, 05:55 PM
TPICherokee's Avatar
Doug Thorleys are far superior headers but it looks likely that they are discontinuing the FSJ Header....
Old 01-17-2008, 02:24 AM
jeeping1974's Avatar
i have hedman headers and i don't care for them. they were and are cheap. the flanges started to warp once they would heat up and cool down and i have had to retighten then bolt multipe times. i finally changed over to studs and am hoping that that will help with the problem.
03 GMC 2500HD - DD/toy hauler
06 Street Glide - Cruiser
Old 01-17-2008, 11:08 AM
cajun_lad's Avatar
cajun_lad cajun_lad is offline
I am running Thorley headers on mine. (They came with it when I bought it.) I love the sound, and have never had a "lack" of power. Don't really have anything to base it off since they were always there. They do get pretty hot (ask Casey). The only issue I had, was the dum-dum who put them in did not tighten the header bolts good and I eventually was down to about 5 or so (total for both headers). Once I changed the blown header gaskets and replaced the missing bolts, my exhaust leak went away and never looked back since.
Joey
Jeep-Less
Old 01-17-2008, 12:09 PM
shackwrrr's Avatar
http://www.dougthorleyheaders.com/pr.../productID/952
they still makem
Jeepless
In to Turbo crap now
Old 01-17-2008, 12:20 PM
Originally Posted by shackwrrr
Call them, they don't, we are actually trying to work a deal where they remake them for us...
Old 01-17-2008, 01:55 PM
78indian 78indian is offline
thorley headers - $550 - $800
headman - $150
thorley headers might be nice but for $600 more, they could be gold plated i wouldn't pay that much more for what maybe 5 extra ponies and 1 mpg if any at all.
i wish i had money like yall(yous guys-for the yanks) i would invest it in somthing that makes a diference.
hmm.... i can get a detroit locker and a set of hedmans for what you pay for crome!
78 Cherokee WT
Old 01-17-2008, 02:17 PM
Charlie_B's Avatar
Charlie_B Charlie_B is offline
I dont think it is +/- a couple ponies that make people spend a few extra bucks on headers. My Hedmans leak pretty bad. They need tightening a lot more than they should. I finally got some of the crushable metal gaskets, and its not as bad, but it still leaks. I'd rather have a set of stock manifolds than my Hedmans. Im looking into getting some Thorleys now. And hopefully I can before they stop selling them.
'79 Cherokee "Goldie" - under the knife Part I; Part II
Currently: body is on, now finishing undercarriage
'92 Cherokee "Rusty" - 3" lift, 31s
'05 Evo MR "Eve"
Old 01-17-2008, 02:20 PM
cajun_lad's Avatar
headman - $150
You are probably that same guy who always has his hood popped on the trail wondering wtf this time?!?! By the way, there is an H in cHrome.
Just kidding man, I don't even know you, I don't think. Unless you are Jared, then I do know you. Anyhow, I understand completely. I wouldn't have paid the money for them, but they came with the rig.
Joey
Jeep-Less
Old 01-17-2008, 02:50 PM
They don't have any more in stock and aren't making anymore unless BJ's Off-Road buys a bunch which looks like it might happen.
Also, they should be for sale for $450 and that includes the Y-pipe, this is why Thorleys cost more. You get what you pay for.
Old 01-17-2008, 02:52 PM
Ha, you will also be pissed off everytime you have to tighten your headers because they leak and you sound like you are farting down the road with all of your exhaust leaks. We don't even sell the Hedmans because they are junk, total junk.
Old 01-17-2008, 03:24 PM
Originally Posted by TPICherokee
Ha, you will also be pissed off everytime you have to tighten your headers because they leak....
yeah had that leak problem when first installed took care of that with remflex gaskets. never even had to retorque after that.
http://www.bjsoffroad.com/cartgenie/...pid=583&cid=16
thanks for selling these
BJ's get em back for $450 ill scrape for that since im hearing such good things (but what i saw on summit when bought mine they wanted almost $700 for them) and i was at the end of my build with limited funds left.
edit: ps.. the headman gasketless ball and socket collecter flange never leaked. awsome design in my book.
pss.. if i wont a broke sob i would prolly be running thorleys...
78 Cherokee WT
Old 01-17-2008, 06:08 PM
i see hookers making a set now but they have rectangle ports??? never knew a amc motor to have rectangle exhaust ports.
hers a summit link for product:
http://store.summitracing.com/partdetail.asp?autofilter=1&part=HOK%2D9402HKR&N=7 00+4294908280+4294908279+4294925060+4294840106+429 4923429+400390+115&autoview=sku
heres a holley link to the hooker product description page 5th down for FSJ 71-79 304-401 port shape = REC
http://www.holley.com/BrowseCatalogs...=Hooker&Page=7
78 Cherokee WT
Old 01-17-2008, 07:45 PM
TINMAN93's Avatar
TINMAN93 TINMAN93 is offline
Breathing out
I've run Headman for years, I'm more than happy. Have used Hookers and Doug Thorley and all were good. I use, and have for years on my race cars and my 4x4's, Header tape and Stage 8 header bolts. I also had leaks with the first gaskets on my 360, but changed to copper and have been leak-free for years. My biggest factor in headers is the weight savings. I find that most choose the wrong headers: too large a primary tube and/or too long which kills back pressure, ie: torque. The shorties are better for torque at low rpm, as are OEM manifolds. But I feel the weight savings are still worth it over OEM's, and if you re-tune for the new flow and finish with the right size exhaust pipe and cat/muffler combo you will see power gains, and that nice rumble.
Tinman
- '91 SJ: BoB'd 13", Lift Hatch, Sliders, Tackbar & more DIM toys.
- And, He who dies with the most toys, still Dies!
Old 01-18-2008, 10:47 AM
trail mule's Avatar
What is recomended for low end torque? After the header what size exhaust would you use?
Old 01-18-2008, 11:01 AM
Ronson Ronson is offline
They look like a rectangle to me with a little dogleg on the corner. I've read that the heads from the sixties have different ports but I'm not sure what they look like.
"Technological progress is like an axe in the hands of a pathological criminal"-Albert Einstein
