Old 03-28-2020, 01:00 PM
cu4whln's Avatar
cu4whln cu4whln is offline
33x12.5" Spare. Yes ? or No ??
Can I fit a33x12.5" in the spare undercarriage area? If not, how big can I go? Can I get a 33" but skinny tire under there? ( A true spare ).
If it does fit, will it hang down a LOT ? Pictures would be great!
Anybody ever rig up a truck tire winch into their SJ ?
Thank You !
1977 "401" 'Da Chief
1979 Chero: "Madness" [Sold]
2001 XJ : Driver 2016 JK 2 door
Round 2- LT Swap: 'Da Chief:
"Madness" build here:
Old 03-29-2020, 09:32 PM
pyro's Avatar
pyro pyro is offline
Ironic, I just picked up a 33x10.5 tire on rim today to test fit. I should have time tomorrow to see
'81 J10 Laredo 258/T176
'82 Cherokee 258/TF904
FSJNetwork Florida FSJ's Click Here!!!
Old 03-29-2020, 09:49 PM
cu4whln's Avatar
Great! Thank you . . . Picture if you can.
Old 03-31-2020, 08:54 AM
I had a 32x11.5x15 spare tucked up under a GW for a while. I modified the tire strap with a bracket on the end so it could be secured. A 33" tire may be too tall but some 33s are actually around 32". Good luck.
Old 03-31-2020, 11:55 AM
cu4whln's Avatar
Thanks!
I guess I will have to see.
Also thinking of putting a tire winch from a truck in too .. IF it will take the load on the floor - with an added reinforcement. It well may not.
Cant look up there yet on mine as there is a rear tank mounted.. for now. that is coming out with the new engine project.
Old 03-31-2020, 12:00 PM
I had a worn 33x12.5" stuffed back under there for a time on my 88.
It was TIGHT, hung LOW. No way a new one would have fit w/o airing it down significantly.
99% they were Goodyear MTR's.
As Flint said different brands are different sizes so you'll have to see.
Old 03-31-2020, 12:49 PM
I had to make a change to my spare tire carrier to get a 285/75-16 in there. AND it hangs down a bit. See here:
http://www.ifsja.org/forums/vb/showthread.php?t=187315
Dang it! Pictures stoppped working. Grrrr.... PM me if you want to see the pics.
79 Cherokee Chief
Old 03-31-2020, 01:08 PM
Don't know about carrier difference between Wag/Chero/truck but a new med lug tread 33x9.5x15 would not fit in the carrier of my 72-J4500. Never tried raising the carrier into final position cause the wheel wouldn't lay flat but even if it did I suspect your 12.5' wide tire may be some grief.
Stock Spare Tire Storage svining General FSJ Tech 3 02-27-2012 05:02 PM
the spare parts box and emergency/first aid kit in your rig what do you keep in them? Wagoneerlover General FSJ Discussion 18 11-12-2008 07:48 AM
16.5" Tires for spare underneath Gladiator red mistress General FSJ Discussion 2 06-21-2008 07:40 PM
Preparations/Supplies & Spare Parts jeeprunner81 Moab 23 04-09-2008 06:21 AM
33x12.50 spare into the stock spare tire area, with pics phatmax95 General FSJ Discussion 29 05-21-2007 09:18 AM
