Old 03-09-2020, 08:01 AM
SOLSAKS's Avatar
SOLSAKS SOLSAKS is offline
use or disconnect AMP meter
1976 j10
auto 360
new NOS gauge cluster
original set up as far as OEM Fuse block, etc
I read somewhere not to use the AMP meter
if using a modern alternator
not real sure if my alternator is considered modern
I am not very mechanically inclined, so to make sure I will have to ask.
but what is the general opinion, as to un hook the AMP meter
( is it a real threat of fire , etc ? )
we already wiped a cam and had to rebuild the motor again
so I don't want to ad fire to the list.
any help appreciated.
dae in NC
Old 03-09-2020, 10:48 AM
There is a sticky thread above on ammeter bypass. It's been done to death.
"Modern" implies much higher amp rating than the original alternator. The ammeter likely cannot handle that.
The best solution is to replace the ammeter with a voltmeter.
Old 03-09-2020, 11:15 AM
Main issue with AMP meter is crappy old wiring/connections AND the age of gauge itself.
I have seen many many melted wires on these, and gauge plastic bits cracked/failing.
If NOS probably ok *IF* wiring is good.
Old 03-09-2020, 01:34 PM
SOLSAKS's Avatar
10-4 thanx for the help.
dave in NC
Old 03-13-2020, 09:31 AM
nograin's Avatar
nograin nograin is offline
Ya. Agree with Babywag. It's probably fine but definately check it out first.
Since you have the gage out you can look at it and see.
It's just a big metal plate with a stud pressed in each end.
Problem occur if the studs get loose from the plate, or the insulation fails.
Generally this is due to overheating but I'm sure there are other conditions that could also cause deteriations over time.
The later ammeters are 60 amp to 60 amp. Not sure what your year has. Might be 60 might be 40.
Any time you see close to 60 amps through the meter, there is a problem.
If you see even 30 amps going through the meter beyond for the first 15 - 30 seconds of recharging, need to ask why.
'85 Grand Wagoneer
360 727auto, NP229
body by beer (PO)
carries wood inside
no "wood" outside
My other car is a fish
Old 03-13-2020, 09:40 AM
nograin's Avatar
My suggestions is if its in good shape, keep it, its useful.
And between bad info posted and so-so wiring work and materials many people get themselves in trouble when making a bypass.
'85 Grand Wagoneer
360 727auto, NP229
body by beer (PO)
carries wood inside
no "wood" outside
Ammeter and protection Joe Guilbeau General FSJ Tech 33 05-01-2017 01:53 PM
Volt meter woes HWY4 General FSJ Tech 11 04-30-2017 12:53 PM
roasted amp meter and alterantor after jump Macgyverjr General FSJ Tech 15 04-04-2017 06:17 PM
Volt Meter ?? CHEEP J10 General FSJ Tech 5 03-20-2008 10:44 AM
