Old 03-01-2020, 02:26 PM
SnowShoe's Avatar
SnowShoe SnowShoe is offline
Question door alignment
Boy-o-boy I need some advise on how to get my doors aligned....so far all margins look OK but. can't get door flush with front and body panels.
OH this is on my 2 door Cherokee
Old 03-01-2020, 03:19 PM
SJTD SJTD is offline
In/out at the front is adjusted by moving both hinges on the jamb.
In/out at the rear is by moving the strike on the jamb.
The door seal may fight you on this. Is it new?
Sic friatur crustulum
Old 03-01-2020, 06:43 PM
SnowShoe's Avatar
Question
Thanks SJTD for the response....My problem is trying to get some kind of leverage to move the hinge out. I have tried loosening the hinge bolts into the body with the door attached and using a crow bar to attempt to move the hinge at the body mount and...no go.
Maybe I will just have to remove the door and try again
I can't believe this should be so hard , but what a fight it's been
Old 03-03-2020, 07:46 AM
bkilby's Avatar
bkilby bkilby is offline
Sounds like somethings wrong if you need a crow bar.
Old 03-03-2020, 10:26 AM
Did you loosen the 2 deep bolts on the pillar as well?
There are 3 bolts on each hinge...
That would be the only reason I can think of that you cannot move the hinges.
Old 03-03-2020, 10:42 AM
SnowShoe's Avatar
Question
Yes, I loosened ALL the bolts and then tried moving the hinge at the deep pocket with crow bar.
This why I am trying to figure out what I have done wrong. Seems like I need to start over with out the door hung to see if that might work.
Old 03-03-2020, 03:21 PM
loosen more??
they should move fairly easily once loose??
maybe try just one hinge @ time? really loosen all 3 and try just that hinge.
Old 03-03-2020, 04:02 PM
SOLSAKS's Avatar
SOLSAKS SOLSAKS is offline
the body shop
that did my j10
had a hard time with driver door
driver door
handle side
at bottom corner is out too much
they finally gave up
but I have friends that may try to adjust at a later date.
dave in NC
Old 03-03-2020, 08:16 PM
Many many that I have seen door alignment is great yet lower corner sticks out.
I would venture guess it's from worn tooling?
Old 03-03-2020, 11:53 PM
Can you move them the other way? Maybe the adjustment is maxed out in the direction you want to go.
Maybe the mounting surface on the door is bent? Might have to shim where the hinges mount to the door.
Old 03-04-2020, 03:49 PM
SnowShoe's Avatar
Thumbs up
Yes SJTD,
I think shimming the door hinge at the door is another option to explore.
I am going to start over one more time and if no success I think shimming is the next best solution.
Thanks for the thoughts...
Old 03-04-2020, 03:58 PM
SnowShoe's Avatar
Exclamation
OOPS I just thought of some thing the door needs to come out to match the fender......ssooooo I am going to have to make the hinge pocket bolt to body adjustment as necessary. Back to the beginning here I go
Old 03-04-2020, 06:09 PM
I had to take my doors completely off, clean the mating surface of both the hinges and the body to get any movement. Mine were pretty rusted together.
79 Cherokee Chief
Old 03-04-2020, 10:20 PM
Another thing you can do is grind the holes in the pillar on the side you want the door to go. IF it's the bolts hitting and not the nut plates banging against their cages inside the pillar..
Old 03-05-2020, 08:39 AM
SnowShoe's Avatar
Thumbs up
Thanks ....good idea
Old 03-06-2020, 04:05 PM
Ive been fighting my doors for years because Ive never gotten them right. IMO, Never-Ever touch the hinge inside the jams They cant be loosened or tightened with the doors closed. Not like other vehicles. GRRR
Old 03-06-2020, 11:28 PM
What I dided, before removing the doors/hinges from the jambs, was drill a 1/8" hole through the jamb and hinge. I'll use some pins to get it roughly back where it was after painting.
If I pull the hinges off the doors I'll do the same thing.
Old 03-07-2020, 09:59 AM
SnowShoe's Avatar
Lightbulb
You are right!!!!!!
Old 03-07-2020, 10:01 AM
SnowShoe's Avatar
Lightbulb
I should have done that
Old 03-13-2020, 07:00 PM
SOLSAKS's Avatar
the body shop that painted my 88 wagoner
drilled holes like you mentioned to get them back in same position.
dave in NC
