Old 02-24-2020, 05:05 PM
monkeyevil's Avatar
monkeyevil monkeyevil is offline
Has anyone installed the BJ's rear mount tank?
My Chief came with a non-installed BJ's stainless tank and I'm curious if the previous owner modified the mounts for some reason? No photos of the tank installed on BJ's site, can't find any on a google search either. Namely where this front mount goes? I can weld a new one on, but I wanted to make sure I'm not missing anything
Does anyone have a photo of their installed for reference?
Photo: https://www.dropbox.com/s/fl5n5oixa3...6.48.jpg?raw=1
79 Chief
Old 02-25-2020, 06:43 PM
UnkleMunky's Avatar
Cannot help you directly on that, but BJ's still sells those kits:
https://www.bjsoffroad.com/Fuel-Tank...eel_p_850.html
I'd say contact them and ask questions. I am sure they will help as much as they can. Maybe the owner didn't include *all* the parts or did something to it, as you wondered.
Michael (UnkleMunky)
'08 Dodge Grand Caravan
Some dogs, a few fountain pens...and too many sewing machines...
Old 02-25-2020, 11:21 PM
SJTD SJTD is offline
A thousand bones? Wow!
Sic friatur crustulum
Old 02-26-2020, 10:56 AM
i'm surprised BJ's sell these. can you imagine the liability issues when someone gets rear ended with one of these tanks back there and it busts open? a custom tank in a non stock location on a car that is known to fold up like an envelope?
Old 02-26-2020, 11:53 AM
Especially when the mounts are welded to it.
I learned that lesson on a glass bodied VW buggy. I welded mounts to a stock tank which then ripped off in an accident. Lotsa spilled gas. Luckily there was no ignition.
There's a reason factory tanks are held up by straps.
Old 02-26-2020, 07:16 PM
asphaltrockdweller's Avatar
The Trail Blazer tanks were mounted back there in the 70'-80s.
HAHA I have two of them for my Wagoneers.
Old 02-27-2020, 04:20 AM
How did you survive and not blow up?
Old 02-27-2020, 07:27 AM
I have not worked with this tank before but I have removed a Trail Blazer tank that was shaped the same. The narrow end of the tank was in the back and the angled area along the sides fit one of the receiver hitches that was popular back then. Contact BJsOffroad
Old 02-27-2020, 10:42 PM
Either unbelievably lucky or God didn't want me burned to death.
I think it was option two.
Old 02-28-2020, 08:15 AM
Good one! There are so many vehicles with rear mounted fuel tanks that they should have all blown up. That's a bit of sarcasm right there.
Old 02-28-2020, 09:03 AM
Mustangs? Wasn't the tank also the trunk floor? Or was that the Pinto?
Old 02-28-2020, 10:36 AM
Pinto/Mustang II/Maverick? Yeah they had issues...
In auto body school in the 90's we had a pretty in-depth section on fuel systems/fire safety checks on vehicles that needed collision repairs.
There were a LOT of fire-related injuries and deaths on older vehicles.
Something like 3/4 million fatalities in one of the studies we read.
The risk is real and way higher on older vehicles due to a lack of safety standards. More modern vehicles had to meet better standards and pass several tests before they were deemed "safe".
Driving any old school vehicle is never as safe as newer ones. Any aftermarket fuel system mods should be done very carefully if you intend to drive it on freeways or higher speeds where impact forces/speeds will be much higher.
A tank like the OP is talking about would likely fail in a collision much easier than a modern OEM tank. Newer OEM tanks are designed and mounted to absorb impacts an aftermarket one probably has ZERO testing and would likely fail any real-world testing.
There are federal motor vehicle standards for fuel tanks and I seriously doubt the above tank would pass.
Will it ignite? who knows way too many factors to consider but I sure wouldn't risk it because my kids ride in my vehicles and there are WAY TOO MANY idiots out there on the road.
If I was going to do a tank replacement I'd use an OEM one with a similar mounting setup.
Old 02-29-2020, 09:22 AM
Cherokeeowner's Avatar
Cherokeeowner Cherokeeowner is offline
Mustangs of certain years had the tank as the trunk floor.
"Proud to be prissy."
1988 Grand Wagoneer
1986 Grand Wagoneer
Old 02-29-2020, 09:52 PM
Reminds me of a cartoon from way back when. Caption was something like "Oh honey, you got me a new car!" Car was a Pinto with Firestone 500's.
Some will remember the uproar over those tires.
My front driver side's rear spring mount it bent rang-a-stang General FSJ Discussion 18 08-10-2017 09:32 AM
Left Rear Upper Shock Mount Repair TBT General FSJ Tech 2 04-11-2015 08:48 PM
High Clearance Rear Fuel Tanks for Wagoneers El_Diablo Off-Road FSJ Tech 25 07-03-2010 05:27 PM
J SERIES REAR SHOCK MOUNT JERSEY JOE Off-Road FSJ Tech 8 10-31-2009 12:46 PM
Squishy brakes after rear disks installed. Woody Long General FSJ Tech 5 12-08-2006 11:56 PM
