Old 01-31-2020, 11:11 PM
Harland Sharp Roller Rockers
For those of you who have them installed... are they noisy?
I did the adjustable pushrod thing, making sure that I have the narrowest stripe right down the middle of the valve stem and added the lifter preload for pushrod length. Am fairly confident I'm set up right.
Am super quiet at startup, then after the oil heats up it gets 'clicky'. Not horrible like there are pushrods bouncing around, but clicky.
I do have aluminum valve covers and have heard that they let sound through more. Have also read that roller rockers can make noise.
Looking for others who have a similar setup. Should I freak out... or relax, don't worry, have a homebrew.
Thanks!
1984 GW
360
Comp 260H
Magnum Roller Rockers
Wiseco -21cc Forged Pistons
Performer Intake
Holley SA 670
MSD 8523
Dakota Digital custom cluster
Serehill headlamp harness
NWMP aux tank
1987 GW deceased
...but the parts live on
Old 02-01-2020, 06:58 AM
Sounds like the preload is off a bit? How is the oil flow to the tip of the rocker? Are you using guides? All in all I would not worry about any of it.
Old 02-02-2020, 09:36 AM
Many engines with bigger cams and roller rockers are a little noisy compared to a stocker. If you are confident in preload being correct I wouldn't worry about it.
Old 02-02-2020, 09:55 PM
Cool - not going to worry!
Definitely have plenty of oil going up top, am using guides, and am 100% sure preload is correct.
Thanks guys!
1984 GW
360
Comp 260H
Performer Intake
Holley SA 670
MSD 8523
NWMP aux tank
1987 GW deceased
Old 03-29-2020, 10:01 AM
82camo401j10's Avatar
82camo401j10 82camo401j10 is offline
With solid cam mine are noisy, music to my ears,lol.
I have scorpion on my hyd cam, quiet as stock.
roller rockers o stamped? yossarian19 General FSJ Tech 3 05-23-2017 02:29 PM
Will stock valve covers clear roller rockers? Strode General FSJ Tech 4 09-25-2012 10:10 AM
For those of you with roller rockers...have a question 78 Arizona Chief General FSJ Tech 26 12-11-2007 10:51 AM
Scorpion roller rockers on 401 baybilly General FSJ Tech 10 03-14-2007 07:26 AM
Who has experience with AMC roller rockers? TexasJ10 General FSJ Tech 7 08-16-2004 07:14 AM
