Go Back   International Full Size Jeep Association > Tire Kickin' > Introduce Yourself.
Old 09-30-2019, 07:51 PM
mtn eer mtn eer is offline
New to forum
Hello! Glad to be joining the forum. I bought a 1988 grand wagoneer last year from a neighbor. He was the first owner, all original. He had kept it up pretty well until the last 3 years it was sitting in his drive. I am an amateur mechanic trying to learn as I go. I have got it up and running, new fuel pump, rebuilt original carb, new radiator and water pump, new starter. My biggest current issues have been a no crank/no start issue when it is getting hot, and the transmission is leaking. Also contemplating whether I should beef up the 360 or if I should try to keep it all original.
[IMG]Sideview jeep by mtn eer, on Flickr[/IMG]
[IMG]Rearview jeep by mtn eer, on Flickr[/IMG]
[IMG]Christmas jeep by mtn eer, on Flickr[/IMG]
Old 10-01-2019, 05:43 PM
UnkleMunky's Avatar
Welcome!
Cool plates!
Whether to beef up the 360 or keep original is really up to you and what you want out of the rig. If a daily driver or average use, then there should not be a lot of need to beef it up, per se. Initial focus is to get it running reliably. After that you can get a better feel for whether or not you think it is adequate for your needs or if you think you need to add some beef to the plate.
Is the no crank/no start after it's been running and hot or just hot weather in your area? There are common vapor issues with these rigs, and if you search for the symptoms on the forum here you'll probably find lots of discussion that may help you narrow down your real problem.
Feel free to ask questions as you go along. People can either directly help or give you links to previous discussion on topics. Also, use the search feature here well and you'll find lots of past points to learn from.
Michael (UnkleMunky)
'08 Dodge Grand Caravan
Some dogs, a few fountain pens...and too many sewing machines...
Old 10-01-2019, 06:30 PM
Starting issue
Thanks for your reply! The no crank/no start has been this summer, but it would only do it when the engine was hot (above 200). Starting for the first time was no problem, but if I would turn it off at a gas station and try to turn it back on 5 min later- nothing. No click, no crank, nothing. When it cooled down it would start. New battery, I even checked a load test and that looked good. I replaced the starter relay and still no crank when the engine was hot. Wrapped the starter with a shield, still no improvement. I then used a remote start button and could get the starter to crank when the ignition would not crank it. If I put the remote starter lead on the wire from the relay down to the starter, it would crank, but if I put the remote starter lead on the ignition wire post of the relay- no crank. So I recently replaced the relay again. So far, so good, but I live in North Dakota and since it is 50 degrees outside, the engine isn't getting above 190 so I don't know if the problem is actually fixed.
Old 10-04-2019, 07:07 AM
miracleed's Avatar
miracleed miracleed is offline
Welcome to the forums! Handsome rig.
'79 Wagoneer Limited
Old 10-04-2019, 10:49 AM
jpjeeper's Avatar
jpjeeper jpjeeper is offline
Crank and no start is usually just the fuel filter return... One side has to hoses onside has one...
If I recall... you need to make sure the return line is higher than the feed line or you will have issue...
Ass suggested... do a search, its on here somewhere.
1967 J3000 Gladiator 327 Vigilante
1972 CJ5 Renegade
2006 Rubicon Unlimited
2017 Rubicon Unlimited Hard Rock
Old 10-04-2019, 10:53 AM
jpjeeper's Avatar
Ask suggested... do a search, its on here somewhere.
no crank when hot...
Could be the starter solonoid or the ignition module... Cant remember if they have a ballist resistor or not because I went HEI a long time ago... but I think they might... this was a source of issues like these for me...
1972 CJ5 Renegade
Old 10-04-2019, 01:37 PM
Did you photoshop that rear plate or is that really your plate?!? SOoo awesome!!!
When you say "a no crank/no start issue when it is getting hot" Does it click when you turn the key? When I first got my rig, when it was hot, it would either BARELY turn over or not at all (but I could hear the solenoid click). It sounded like a dead/dying battery. I would let it sit for 3 hours with the hood open and it would crank right over and start right up. I had to rebuild all my battery cables from the battery to the starter, and my ground wire. I used 0ga welding wire and copper terminals after buying 2 sets of cheap pre-made cables at McParts that didn't help. It cost me about $50 and killed about 2 hours of working but it really helped. When our starters get hot, they draw ALOT more current and it makes it hard to turn over. You might also consider a new starter.
How bad is the trans leak? I am not sure a FSJ exists that does not leak. If your rig is not leaking, you are out of fluid.
Welcome to the forum! Glad you're here!
79 Cherokee Chief
Old 10-05-2019, 08:16 AM
SOLSAKS's Avatar
SOLSAKS SOLSAKS is offline
I love the color of your wagoner
John candy in the great outdoors comes to mind every single time I see one like yours
welcome.
dave in NC
Old 10-07-2019, 07:31 AM
Kottobe Kottobe is offline
Hello! I am new here, nice to meet everybody.
Old 12-12-2019, 01:49 PM
jeepman1's Avatar
jeepman1 jeepman1 is offline
Bums
..The lot of us!
: 98 9er
'83 Honcho j10
'12 Liberty Ltd.. wifes
'19 Chaparral H2o Dlx sport 21
Old 12-13-2019, 07:17 AM
miracleed's Avatar
Heya Kottobe! Welcome to the forums.
Old 12-19-2019, 01:36 PM
Outstanding color on yours, haven't seen one like that in years. Love the license plate. Looking forward to seeing future posts.
Old 12-26-2019, 10:57 PM
selkplitt's Avatar
selkplitt selkplitt is offline
Mine did the same. It was the wire from the relay on fender to solenoid on starter. Good cold but would not make connection hot therefore engine wouldn
http://s1191.photobucket.com/albums/z469/selkplitt/
1989 Grand Waggy stock
2007 Commander Rock Mountain with QuadradriveII 4.7
2018 GMC Canyon Denali 2.8 Duramax
Howell and GM Based TBI FAQs and other forum links FSJ Guy Fuel Injection 2 02-27-2012 06:27 PM
"I'm Thinking" forum idea Fiodh. Argus General FSJ Discussion 33 05-11-2011 05:08 PM
Distributor tech 101, AMC options wickedwagon767 General FSJ Tech 24 12-26-2006 08:23 PM
