Old 09-26-2019, 10:29 PM
86j10's Avatar
86j10 86j10 is offline
J10 Heater core instsll
Need some help with a heater core removal and install on my 86 j10. Factory a/c truck. Heater core was good prior. Think I broke the fitting on the core when I was replacing the old heater hoses with new ones because now it leaks. I was able to get the 2 nuts off the box at the firewall and am finding that I may have to pull all the duct work down and out of the way to get to the others.
Old 09-27-2019, 08:23 AM
SJTD SJTD is offline
You can see the two nuts holding the heater assembly to the firewall on the engine side. You can also see the two studs that have nuts on the inside.
I have read that one can reach the nuts without removing the AC but haven't tried.
But maybe you can separate the two halves of the heater box without removing it from the firewall?
Sic friatur crustulum
Old 10-07-2019, 05:09 PM
I've read that it's possible to do it without dropping the AC too, but not sure how it's possible without having eyes on your fingertips and a double jointed arm with 4 wrists.
1984 GW
360
Comp 260H
Magnum Roller Rockers
Wiseco -21cc Forged Pistons
Performer Intake
Holley SA 670
MSD 8523
Dakota Digital custom cluster
Serehill headlamp harness
NWMP aux tank
1987 GW deceased
...but the parts live on
Old 12-26-2019, 12:34 PM
Jeep Doctor
You don't have to *remove* the A/C unit under the dash to reach the two nuts on the studs protruding into the passenger-compartment, but you do have to drop it just enough to reach in with an extension to take off those nuts.
Here is the location of those two studs on the inside of the firewall, directly vertical from where the A/C hoses come through the grommet on the firewall:
You just have to remove the screws holding the A/C unit to the bottom of the dash, and maybe one upper support strap, to lower it enough to reach them with a deep 1/2" socket (I think).
Old 12-27-2019, 02:13 PM
Originally Posted by Bob Barry
Wow! Respect!!!
keep in mind when you look up there, those two studs are sticking through the firewall pad. My 79 has a bracket that connect to the lower stud that holds the back of the A/C unit up.
Don't be scared to lower your A/C unit. It is SUPER easy. You will spend twice as much time trying to get those 2 nuts off with the A/C in place than if you just lowered it.
Just unscrew the 2 screws that hold the vent tube under the steering column then remove that tube and set aside. Then remove the screws across the front under the dash. Mine also has a small light I have to unscrew by the passenger knees. Then you remove the bracket that you have to remove anyway. That's it. No hoses being opened, no loss of freon. No hard to get to screws. no electrical connections to break. Just unscrew the front, then remove the bracket and the A/C comes down.
79 Cherokee Chief
Old 12-27-2019, 03:32 PM
Jeep Doctor
Wow! Respect!!!
Ah, they roped in a new Admin; thanks for all your hard work, then!
That description is spot-on; the picture I posted is of a Cherokee that did not have the firewall pad that a GW would have. I did do this in a GW, however, and it's just as Rang described.
Heater Core Question farrelljt General FSJ Tech 21 12-27-2012 03:34 PM
Interior Heater Core rileydcasey General FSJ Tech 10 12-14-2011 05:42 PM
Heater Core Confusion catch2otwo General FSJ Tech 7 12-13-2011 07:34 PM
Why is water pump 7/8" hose and heater core is 3/4"? rreed General FSJ Tech 20 02-18-2007 12:33 PM
